[PIC®/AVR®/dsPIC®产品] (二)FreeRTOS任务介绍
1663|10
 楼主| 奔波儿熊 发表于 2019-6-18 16:08 | 显示全部楼层 |阅读模式
1.我们使用8位单片机,比如AVR,最常用的做法是在main函数里使用while(1)循环, 状态机以及中断服务函数来实现应用程序. 这样的系统不涉及到任务的概念或者说while(1)里每一个函数调用就是一个任务,叫做前后台程序,中断服务函数作为前台程序,while(1)循环作为后台程序.这种做法的好处是实现简单,代码占用小,坏处是实时性差.下图是前后台程序的示意图.
2.我们还有另外一种选择,就是使用操作系统,比如FreeRTOS. 为了解决上面那种裸机开发的弊端--实时性差,我们通过创建多个任务,将紧急的任务优先级设置相对高一点,不紧急的任务优先级设置相对低一点, 高优先级的任务可以从低优先级任务手中抢占CPU的使用权,保证紧急任务能够优先运行.下图是抢占式操作系统中任务的调度示意图.
3.FreeRTOS的4种任务状态切换如下图所示,且任务必定处于图中所示状态中的一种. 任何时刻只有一个任务处于Running状态.
4.FreeRTOS任务的优先级可以为0~(configMAX_PRIORITIES-1)范围内的任何一个值. 数字越小,优先级越低,0是最低优先级;数字越大,优先级越高,configMAX_PRIORITIES-1是最高优先级.空闲任务的优先级为0.
5.FreeRTOS任务函数原型如下:
  1. void ATaskFunction( void *pvParameters );
FreeRTOS任务函数的典型结构如下.  任务函数不能返回,要么是一个无限循环,要么在函数退出之前执行vTaskDelete( NULL );.
  3. /* Variables can be declared just as per a normal function. Each instance
  4. of a task created using this function will have its own copy of the
  5. iVariableExample variable. This would not be true if the variable was
  6. declared static – in which case only one copy of the variable would exist
  7. and this copy would be shared by each created instance of the task. */
  8. int iVariableExample = 0;
  9. /* A task will normally be implemented as in infinite loop. */
  10. for( ;; )
  11. {
  12. /* The code to implement the task functionality will go here. */
  13. }
  14. /* Should the task implementation ever break out of the above loop
  15. then the task must be deleted before reaching the end of this function.
  16. The NULL parameter passed to the vTaskDelete() function indicates that
  17. the task to be deleted is the calling (this) task. */
  18. vTaskDelete( NULL );
  19. }
6.FreeRTOS使用TCB_t结构体存储任务的相关属性.
  1. /*
  2. * Task control block.  A task control block (TCB) is allocated for each task,
  3. * and stores task state information, including a pointer to the task's context
  4. * (the task's run time environment, including register values)
  5. */
  6. typedef struct tskTaskControlBlock {
  7.         volatile StackType_t *pxTopOfStack; /*< Points to the location of the last item placed on the tasks stack.  THIS
  8.                                                MUST BE THE FIRST MEMBER OF THE TCB STRUCT. */
  9. #if (portUSING_MPU_WRAPPERS == 1)
  10.         xMPU_SETTINGS xMPUSettings; /*< The MPU settings are defined as part of the port layer.  THIS MUST BE THE SECOND
  11.                                        MEMBER OF THE TCB STRUCT. */
  12. #endif
  13.         ListItem_t xStateListItem;   /*< The list that the state list item of a task is reference from denotes the state of
  14.                                         that task (Ready, Blocked, Suspended ). */
  15.         ListItem_t   xEventListItem; /*< Used to reference a task from an event list. */
  16.         UBaseType_t  uxPriority;     /*< The priority of the task.  0 is the lowest priority. */
  17.         StackType_t *pxStack;        /*< Points to the start of the stack. */
  18.         char         pcTaskName[configMAX_TASK_NAME_LEN];
  19.             /*< Descriptive name given to the task when created.  Facilitates debugging only. */ /*lint !e971 Unqualified
  20.        char types are allowed
  21.        for strings and single
  22.        characters only. */
  23. #if ((portSTACK_GROWTH > 0) || (configRECORD_STACK_HIGH_ADDRESS == 1))
  24.         StackType_t *pxEndOfStack; /*< Points to the highest valid address for the stack. */
  25. #endif
  26. #if (portCRITICAL_NESTING_IN_TCB == 1)
  27.         UBaseType_t
  28.             uxCriticalNesting; /*< Holds the critical section nesting depth for ports that do not maintain their own count
  29.                                   in the port layer. */
  30. #endif
  31. #if (configUSE_TRACE_FACILITY == 1)
  32.         UBaseType_t uxTCBNumber;  /*< Stores a number that increments each time a TCB is created.  It allows debuggers to
  33.                                      determine when a task has been deleted and then recreated. */
  34.         UBaseType_t uxTaskNumber; /*< Stores a number specifically for use by third party trace code. */
  35. #endif
  36. #if (configUSE_MUTEXES == 1)
  37.         UBaseType_t
  38.                     uxBasePriority; /*< The priority last assigned to the task - used by the priority inheritance mechanism. */
  39.         UBaseType_t uxMutexesHeld;
  40. #endif
  41. #if (configUSE_APPLICATION_TASK_TAG == 1)
  42.         TaskHookFunction_t pxTaskTag;
  43. #endif
  44. #if (configNUM_THREAD_LOCAL_STORAGE_POINTERS > 0)
  45.         void *pvThreadLocalStoragePointers[configNUM_THREAD_LOCAL_STORAGE_POINTERS];
  46. #endif
  47. #if (configGENERATE_RUN_TIME_STATS == 1)
  48.         uint32_t ulRunTimeCounter; /*< Stores the amount of time the task has spent in the Running state. */
  49. #endif
  50. #if (configUSE_NEWLIB_REENTRANT == 1)
  51.         /* Allocate a Newlib reent structure that is specific to this task.
  52.         Note Newlib support has been included by popular demand, but is not
  53.         used by the FreeRTOS maintainers themselves.  FreeRTOS is not
  54.         responsible for resulting newlib operation.  User must be familiar with
  55.         newlib and must provide system-wide implementations of the necessary
  56.         stubs. Be warned that (at the time of writing) the current newlib design
  57.         implements a system-wide malloc() that must be provided with locks. */
  58.         struct _reent xNewLib_reent;
  59. #endif
  60. #if (configUSE_TASK_NOTIFICATIONS == 1)
  61.         volatile uint32_t ulNotifiedValue;
  62.         volatile uint8_t  ucNotifyState;
  63. #endif
  64. /* See the comments above the definition of
  65. tskSTATIC_AND_DYNAMIC_ALLOCATION_POSSIBLE. */
  66. #if (tskSTATIC_AND_DYNAMIC_ALLOCATION_POSSIBLE        \
  67.      != 0) /*lint !e731 Macro has been consolidated for readability reasons. */
  68.         uint8_t
  69.             ucStaticallyAllocated; /*< Set to pdTRUE if the task is a statically allocated to ensure no attempt is made to
  70.                                       free the memory. */
  71. #endif
  72. #if (INCLUDE_xTaskAbortDelay == 1)
  73.         uint8_t ucDelayAborted;
  74. #endif
  75. } tskTCB;
  76. /* The old tskTCB name is maintained above then typedefed to the new TCB_t name
  77. below to enable the use of older kernel aware debuggers. */
  78. typedef tskTCB TCB_t;
7.FreeRTOS的任务调度器在进行任务切换的时候会先将当前运行任务的现场(如通用寄存器等)保存在此任务的任务堆栈中,等到此任务下次运行的时候会用堆栈中保存的数据恢复现场,恢复现场以后任务就会接着上次断开的的地方运行. 任务堆栈的地址保存在TCB_t中.
643757107 发表于 2019-6-18 22:58 | 显示全部楼层
教程不错,学习。
小卡 发表于 2019-6-20 11:03 | 显示全部楼层
不错啊~ 这个好
天灵灵地灵灵 发表于 2019-6-20 23:26 | 显示全部楼层
lcczg 发表于 2019-6-25 11:32 | 显示全部楼层
好,继续。
zhuotuzi 发表于 2019-6-26 00:36 | 显示全部楼层
好移植吗
 楼主| 奔波儿熊 发表于 2019-6-26 10:57 | 显示全部楼层
如果在同系列(主要是同内核)之间移植,还算好移植. 不同系列之间就不好移植了.
pzsh 发表于 2019-6-28 10:07 | 显示全部楼层
FreeRTOS相对uCOS来说,就是参考的文件和书籍少了点。
aoyi 发表于 2019-7-25 11:21 | 显示全部楼层
是不是所有型号单片机流程都差不多啊
drer 发表于 2019-7-25 14:05 | 显示全部楼层
讲解的非常详细
jinniuxing 发表于 2019-11-29 16:53 | 显示全部楼层
谢谢分享!
