- * @file descriptors.c
- * @version V1.00
- * $Revision: 6 $
- * $Date: 18/04/13 3:44p $
- * @brief M031 series USBD driver source file
- * @note
- * Copyright (C) 2018 Nuvoton Technology Corp. All rights reserved.
- /*!<Includes */
- #include "NuMicro.h"
- #include "micro_printer_and_hid_transfer.h"
- /*!<USB Device Descriptor */
- uint8_t gu8DeviceDescriptor[] =
- LEN_DEVICE, /* bLength */
- DESC_DEVICE, /* bDescriptorType */
- 0x10, 0x01, /* bcdUSB */
- 0x00, /* bDeviceClass */
- 0x00, /* bDeviceSubClass */
- 0x00, /* bDeviceProtocol */
- EP0_MAX_PKT_SIZE, /* bMaxPacketSize0 */
- /* idVendor */
- USBD_VID & 0x00FF,
- ((USBD_VID & 0xFF00) >> 8),
- /* idProduct */
- USBD_PID & 0x00FF,
- ((USBD_PID & 0xFF00) >> 8),
- 0x00, 0x03, /* bcdDevice */
- 0x01, /* iManufacture */
- 0x02, /* iProduct */
- 0x00, /* iSerialNumber - no serial */
- 0x01 /* bNumConfigurations */
- /*!<USB HID Report Descriptor */
- uint8_t HID_DeviceReportDescriptor[] =
- 0x06, 0x00, 0xFF, // Usage Page = 0xFF00 (Vendor Defined Page 1)
- 0x09, 0x01, // Usage (Vendor Usage 1)
- 0xA1, 0x01, // Collection (Application)
- 0x19, 0x01, // Usage Minimum
- 0x29, 0x40, // Usage Maximum //64 input usages total (0x01 to 0x40)
- 0x15, 0x00, // Logical Minimum (data bytes in the report may have minimum value = 0x00)
- 0x26, 0xFF, 0x00, // Logical Maximum (data bytes in the report may have maximum value = 0x00FF = unsigned 255)
- 0x75, 0x08, // Report Size: 8-bit field size
- 0x95, 0x40, // Report Count: Make sixty-four 8-bit fields (the next time the parser hits
- // an "Input", "Output", or "Feature" item)
- 0x81, 0x00, // Input (Data, Array, Abs): Instantiates input packet fields based on the
- // above report size, count, logical min/max, and usage.
- 0x29, 0x40, // Usage Maximum //64 output usages total (0x01 to 0x40)
- 0x91, 0x00, // Output (Data, Array, Abs): Instantiates output packet fields. Uses same
- // report size and count as "Input" fields, since nothing new/different was
- // specified to the parser since the "Input" item.
- 0xC0 // End Collection
- /*!<USB Configure Descriptor */
- uint8_t gu8ConfigDescriptor[] =
- LEN_CONFIG, /* bLength */
- DESC_CONFIG, /* bDescriptorType */
- 0x6E, 0x00, /* wTotalLength */
- 0x02, /* bNumInterfaces */
- 0x01, /* bConfigurationValue */
- 0x00, /* iConfiguration */
- 0xC0, /* bmAttributes */
- 0x32, /* MaxPower */
- /* INTERFACE descriptor */
- LEN_INTERFACE, /* bLength */
- DESC_INTERFACE, /* bDescriptorType */
- 0x00, /* bInterfaceNumber */
- 0x00, /* bAlternateSetting */
- 0x01, /* bNumEndpoints */
- 0x07, /* bInterfaceClass: printer class */
- 0x01, /* bInterfaceSubClass */
- 0x01, /* bInterfaceProtocol */
- 0x00, /* iInterface */
- /* ENDPOINT descriptor */
- LEN_ENDPOINT, /* bLength */
- DESC_ENDPOINT, /* bDescriptorType */
- (EP_OUTPUT | BULK_OUT_EP_NUM), /* bEndpointAddress */
- EP_BULK, /* bmAttributes */
- EP3_MAX_PKT_SIZE, 0x00, /* wMaxPacketSize */
- 0x00, /* bInterval */
- 0x01, /* bAlternateSetting */
- 0x02, /* bNumEndpoints */
- 0x02, /* bInterfaceProtocol */
- (EP_INPUT | BULK_IN_EP_NUM), /* bEndpointAddress */
- EP2_MAX_PKT_SIZE, 0x00, /* wMaxPacketSize */
- 0x02, /* bAlternateSetting */
- 0x03, /* bNumEndpoints */
- 0xFF, /* bInterfaceClass */
- 0x00, /* bInterfaceSubClass */
- 0xFF, /* bInterfaceProtocol */
- (EP_INPUT | INT_IN_EP_NUM), /* bEndpointAddress */
- EP_INT, /* bmAttributes */
- EP4_MAX_PKT_SIZE, 0x00, /* wMaxPacketSize */
- 0x01, /* bInterval */
- /* I/F descr: HID Transfer */
- 0x01, /* bInterfaceNumber */
- 0x03, /* bInterfaceClass */
- 0x00, /* bInterfaceProtocol */
- /* HID Descriptor */
- LEN_HID, /* Size of this descriptor in UINT8s. */
- DESC_HID, /* HID descriptor type. */
- 0x10, 0x01, /* HID Class Spec. release number. */
- 0x00, /* H/W target country. */
- 0x01, /* Number of HID class descriptors to follow. */
- DESC_HID_RPT, /* Descriptor type. */
- /* Total length of report descriptor. */
- sizeof(HID_DeviceReportDescriptor) & 0x00FF,
- ((sizeof(HID_DeviceReportDescriptor) & 0xFF00) >> 8),
- /* EP Descriptor: interrupt in. */
- (INT_IN_EP_NUM_1 | EP_INPUT), /* bEndpointAddress */
- /* wMaxPacketSize */
- EP5_MAX_PKT_SIZE & 0x00FF,
- ((EP5_MAX_PKT_SIZE & 0xFF00) >> 8),
- HID_DEFAULT_INT_IN_INTERVAL, /* bInterval */
- /* EP Descriptor: interrupt out. */
- (INT_OUT_EP_NUM | EP_OUTPUT), /* bEndpointAddress */
- EP6_MAX_PKT_SIZE & 0x00FF,
- ((EP6_MAX_PKT_SIZE & 0xFF00) >> 8),
- /*!<USB Language String Descriptor */
- uint8_t gu8StringLang[4] =
- 4, /* bLength */
- DESC_STRING, /* bDescriptorType */
- 0x09, 0x04
- /*!<USB Vendor String Descriptor */
- uint8_t gu8VendorStringDesc[] =
- 16,
- DESC_STRING,
- 'N', 0, 'u', 0, 'v', 0, 'o', 0, 't', 0, 'o', 0, 'n', 0
- /*!<USB Product String Descriptor */
- uint8_t gu8ProductStringDesc[] =
- 22, /* bLength */
- 'U', 0, 'S', 0, 'B', 0, ' ', 0, 'D', 0, 'e', 0, 'v', 0, 'i', 0, 'c', 0, 'e', 0
- /*!<USB BOS Descriptor */
- const uint8_t gu8BOSDescriptor[] =
- LEN_BOS, /* bLength */
- DESC_BOS, /* bDescriptorType */
- /* wTotalLength */
- 0x0C & 0x00FF,
- ((0x0C & 0xFF00) >> 8),
- 0x01, /* bNumDeviceCaps */
- /* Device Capability */
- 0x7, /* bLength */
- DESC_CAPABILITY,/* bDescriptorType */
- CAP_USB20_EXT, /* bDevCapabilityType */
- 0x02, 0x00, 0x00, 0x00 /* bmAttributes */
- uint8_t *gpu8UsbString[4] =
- gu8StringLang,
- gu8VendorStringDesc,
- gu8ProductStringDesc,
- 0,
- uint8_t *gu8UsbHidReport[3] =
- 0,
- HID_DeviceReportDescriptor,
- 0,
- uint32_t gu32UsbHidReportLen[3] =
- 0,
- sizeof(HID_DeviceReportDescriptor),
- 0,
- uint32_t gu32ConfigHidDescIdx[3] =
- 0,
- (sizeof(gu8ConfigDescriptor) - LEN_HID - (2*LEN_ENDPOINT)),
- 0,
- const S_USBD_INFO_T gsInfo =
- (uint8_t *)gu8DeviceDescriptor,
- (uint8_t *)gu8ConfigDescriptor,
- (uint8_t **)gpu8UsbString,
- (uint8_t **)gu8UsbHidReport,
- (uint8_t *)gu8BOSDescriptor,
- (uint32_t *)gu32UsbHidReportLen,
- (uint32_t *)gu32ConfigHidDescIdx
