/* Name: LCD12864(St7920/St7921)+超声波测距模块+STC89C52
/* HC-SR04 超声波测距模块 DEMO 程序
/* 晶振:11.0592M */
/* Designed by : Tvrostar Date:2007/09/16
/* 程序编写:新科电子
QQ: 114872428
/* taobao店铺:http://shop58463218.taobao.com/
/* 接线:模块TRIG接 P1.2 ECH0 接P1.1
/* RS(CS) 接 P3.3;
/* RW(SID) 接 P3.4;
/* E(SCLK) 接 P3.5;
/* PSB 接 GND 串行模式
#include <AT89X51.H>
#include <intrins.h>
//引脚定义
sbit RX = P1 ^ 1;
sbit TX = P1 ^ 2;
sbit CS = P3 ^ 3;
//片选 高电平有效 单片LCD使用时可固定高电平
sbit SID = P3 ^ 4;
//数据
sbit SCLK = P3 ^ 5;
//时钟
//Function Definition 函数声明
void Delay(int num);
void Init_DS18B20(void);
unsigned char ReadOneChar(void);
void WriteOneChar(unsigned char dat);
unsigned int ReadTemperature(void);
void clock_out(unsigned char dd);
unsigned char clock_in(void);
unsigned char read_clock(unsigned char ord);
void write_clock(unsigned char ord, unsigned char dd);
void Disp(void);
void id_case1_key(void);
void id_case2_key(void);
void Set_time(unsigned char sel,bit sel_1);
void Timer0_Init(void);
void Init_1302(void);
void Set_Bell(unsigned char sel, bit sel_1);
void Bell(void);
//12864
void Write_char(bit start, unsigned char ddata);
void Send_byte(unsigned char bbyte);
void Delaynms(unsigned int di);
void Lcd_init(void);
void Disp_img(unsigned char *img);
void LCD_Write_string(unsigned char X,unsigned char Y,unsigned char *s);
void LCD_set_xy( unsigned char x, unsigned char y );
unsigned char code num[]={"0123456789 :.-"};
unsigned char code waves[]={"超声波测距系统"};
unsigned char code znwk[] ={"智能微控工作室"};
unsigned char code CM[] = {"M"};
unsigned int time=0;
long S=0;
bit flag =0;
unsigned char disbuff[4]
={ 0,0,0,0,};
void Send_byte(unsigned char bbyte) //发送一个字节
unsigned char i;
for(i=0;i<8;i++)
SID=bbyte&0x80; //取出最高位
SCLK=1;
SCLK=0;
bbyte<<=1; //左移
void Delaynms(unsigned int di) //延时
unsigned int da,db;
for(da=0;da<di;da++)
for(db=0;db<10;db++);
void Clr_Scr(void)//清屏函数
Write_char(0,0x01);
//设置LCD显示的起始位置,X为行,Y为列
unsigned char address;
switch(x)
case 0: address = 0x80 + y; break;
case 1: address = 0x80 + y; break;
case 2: address = 0x90 + y; break;
case 3: address = 0x88 + y; break;
case 4: address = 0x98 + y; break;
default:address = 0x80 + y; break;
Write_char(0, address);
中英文字符串显示函数
LCD_set_xy( X, Y );
while (*s)
Write_char( 1, *s );
s ++;
Delaynms(1);
void LCD_Write_number(unsigned char s)//
数字显示函数
Write_char(1,num);
Delaynms(1);
void Lcd_Mark2(void)
Clr_Scr();//清屏
LCD_Write_string(1,0,znwk);//
LCD_Write_string(2,0,waves);//
LCD_Write_string(3,7,CM);//
void Conut(void)
time=TH0*256+TL0;
TH0=0;
TL0=0;
S=time*1.87/100; //算出来是CM
11。0592M晶振
if(flag==1)
//超出测量
flag=0;
LCD_set_xy( 3, 4 );
LCD_Write_number(13);
LCD_Write_number(12);
LCD_set_xy( 3, 5 );
else
disbuff[1]=S%1000/100;
disbuff[2]=S%1000%100/10;
disbuff[3]=S%1000%10 %10;
LCD_set_xy( 3, 4 );
LCD_Write_number(disbuff[1]);
LCD_set_xy( 3, 5 );
LCD_Write_number(disbuff[2]);
LCD_Write_number(disbuff[3]);
void delayms(unsigned int ms)
unsigned char i=100,j;
for(;ms;ms--)
while(--i)
j=10;
while(--j);
void zd0() interrupt 1
//T0中断用来计数器溢出,超过测距范围
flag=1;
//中断溢出标志
void StartModule()
//T1中断用来扫描数码管和计800MS启动模块
TX=1;
//800MS 启动一次模块
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
TX=0;
void main(void)
TMOD=0x01;
//设T0为方式1,GATE=1
TH0=0;
TL0=0;
TR0=1;
Lcd_init(); //设置液晶显示器
Clr_Scr(); //清屏
Disp_img(**);
//显示欢迎使用本产品**
Delaynms(1000);
Lcd_init(); //从图形显示状态下返回
Lcd_Mark2();
while(1)
StartModule();
//计算
while(!RX);
//当RX为零时等待
TR0=1;
//开启计数
while(RX);
//当RX为1计数并等待
TR0=0;
//关闭计数
Conut();
delayms(80);
//80MS
与程序对应的硬件系统非常MINI见:http://shop58463218.taobao.com/
