用外部中断打开互补输出,为什么互补的输出会有毛刺?
3536|6
 楼主| xiongxingzhi 发表于 2011-11-8 11:10 | 显示全部楼层 |阅读模式
/* TIM1 Peripheral Configuration */
  void TIM_Configuration(void)
  {/* Time Base configuration */
  TIM1_TimeBaseStructure.TIM_Prescaler =71;
  TIM1_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM1_TimeBaseStructure.TIM_Period = 1999;
  TIM1_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM1_TimeBaseStructure.TIM_RepetitionCounter = 0x0;
  TIM_TimeBaseInit(TIM1,&TIM1_TimeBaseStructure);
  /* Channel 1, 2,3 and 4 Configuration in PWM mode */
  TIM1_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  TIM1_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM1_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  TIM1_OCInitStructure.TIM_Pulse = CCR1_Val;
  TIM1_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM1_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  TIM1_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  TIM1_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  TIM_OC1Init(TIM1,&TIM1_OCInitStructure);
  /* Automatic Output enable, Break, dead time and lock configuration*/
  TIM1_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
  TIM1_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
  TIM1_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1;
  TIM1_BDTRInitStructure.TIM_DeadTime = 0x75;
  TIM1_BDTRInitStructure.TIM_Break = TIM_Break_Enable;
  TIM1_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;
  TIM1_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
  TIM_BDTRConfig(TIM1,&TIM1_BDTRInitStructure);
  /* TIM1 counter enable */
  TIM_Cmd(TIM1,ENABLE);
  /* Main Output Enable */
  TIM_CtrlPWMOutputs(TIM1,DISABLE);
  while(1)
CCR1_Val=VAL[0];
TIM1->CCR1 = CCR1_Val;
Delay(2);
CCR1_Val=VAL[1];
  Delay(2);
    CCR1_Val=VAL[2];
  Delay(2);
CCR1_Val=VAL[3];
Delay(2);
CCR1_Val=VAL[4];
Delay(2);
void EXTI0_IRQHandler(void)
if(EXTI_GetITStatus(EXTI_Line0) != RESET)
  TIM_CtrlPWMOutputs(TIM1,ENABLE);
  GPIO_SetBits(GPIOC,GPIO_Pin_6);
     EXTI_ClearITPendingBit(EXTI_Line0);
}中断
  void EXTI_Configuration(void)
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC,GPIO_PinSource0);
  EXTI_InitStructure.EXTI_Line = EXTI_Line0;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  EXTI_GenerateSWInterrupt(EXTI_Line0);
香水城 发表于 2011-11-8 11:20 | 显示全部楼层
你这个帖子与前一个帖子是什么关系?
https://bbs.21ic.com/viewthread.php?tid=282026
 楼主| xiongxingzhi 发表于 2011-11-8 14:06 | 显示全部楼层
2# 香水城 前一个帖子,是产生波形,这个帖子是控制开关啊
香水城 发表于 2011-11-8 14:35 | 显示全部楼层
用示波器定位一下,看看在产生毛刺的时候你的程序在做什么?
libinxtdj 发表于 2011-11-10 20:52 | 显示全部楼层
你这里定义的输出哦度是低有效,什么有定义的空闲状态又是一个高,一个低呢?这不冲突吗?
你这里为什么要使能自动输出呢?
香水城 发表于 2011-11-11 10:23 | 显示全部楼层
TIM_Configuration(void) 里面的 while (1) 是做什么用的?
ti饭饭 发表于 2013-2-23 09:49 | 显示全部楼层
仿真很屌
