如何转换成BCD啊?
1561|29
wangpe 发表于 2019-7-14 18:03 | 显示全部楼层
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
lium 发表于 2019-7-14 18:06 | 显示全部楼层
主机程序:
#include <STRING.H>
#include<REG52.H>
#define _MHZ_ 11
sbit
LED1=P0^0;
sbit
LED2=P0^1;
sbit
P0_2=P0^2;
sbit
P0_3=P0^3;
sbit
K1=P0^4;
sbit
K2=P0^5;
sbit
P0_6=P0^6;
sbit
P0_7=P0^7;
sbit
LED3=P1^0;
sbit
LED4=P1^1;
sbit
LED5=P1^2;
sbit
P1_3=P1^3;
sbit
P1_4=P1^4;
sbit
P1_5=P1^5;
sbit
K3=P1^6;
sbit
K4=P1^7;
sbit
P2_0=P2^0;
sbit
P2_1=P2^1;
sbit
P2_2=P2^2;
sbit
P2_3=P2^3;
sbit
P2_4=P2^4;
sbit
P2_5=P2^5;
sbit
P2_6=P2^6;
sbit
K5=P2^7;
int a=0;
unsigned char data1[6];
unsigned char data2[6];
void init_serial0();
void init_serial1();
void coll_data() ;
void send_data(unsigned char *data1);
void recv_data(unsigned char *data2);
void delay10ms(unsigned int count);
unsigned char ecc=0x00;
/*************** 延时程序*********** */
unsigned int i;
unsigned char j;
for(i=0; i<count; i++)
for(j=0; j<200; j++);
//for(k=0; k<150; k++);
/******************采集数据**********************/
void coll_data()
data1[0]=0xC5;
data1[1]=0xFF;
data1[2]=0xF6;
data1[3]=0xC8;
/*****************?1******************/
if(K1==0)
  delay10ms(1);
    if(K1==0)
data1[1]=data1[1]&0x7F;
    if(K2==0)
  delay10ms(1);
    if(K2==0)
data1[1]=data1[1]&0xBF;
if(K3==0)
  delay10ms(1);
    if(K3==0)
data1[1]=data1[1]&0xDF;
    if(K4==0)
  delay10ms(1);
    if(K4==0)
data1[1]=data1[1]&0xEF;
    if(K5==0)
  delay10ms(1);
    if(K5==0)
data1[1]=data1[1]&0xF7;
data1[4]=0xC5+ data1[1]+ 0xF6+0xC8;//D£?é×??ú£?oí×??ˉò?3?è?×?μí8??
/****************** ·发送数据 **********************/
int i;
/* ·¢?íêy?Y */
for(i=0; i<5; i++)
TI = 0;
SBUF = data1[i];
while(!TI);
TI = 0;
    /****************串口初始化********************/
void init_serial1()
TMOD = 0x20;
TH1 = 250;
TL1 = 250;
TR1 = 1;
PCON = 0x80;
SCON = 0x50;
/* *****************?¨ê±?÷0 **********************/
void init_serial0()
TMOD = 0x10;
TH0 = 0xB8;
TL0 = 0x00;
TR0 = 1;
ET0=1;
EA=1;
/*************** 定时器0中断*********** */
void timer0_int () interrupt 1 using 1
TH0 = 0xB8;
TL0 = 0x00;
send_data(data1);
coll_data();
/* 接收数据*/
  int i;
/* ?óê?êy?Y */
for(i=0; i<5; i++)
while(!RI);
data2[i] = SBUF;
RI = 0;
ecc=(data2[0])+(data2[1])+(data2[2])+(data2[3]);
data2[5]=0;
if((data2[0]==0xA5)&&(data2[4]==ecc))
     if((data2[1]&0x80)==0x80)
    LED1=1;
     else
        LED1=0;
   if((data2[1]&0x40)==0x40)
    LED2=1;
     else
      LED2=0;
     if((data2[1]&0x20)==0x20)
    LED3=1;
     else
     LED3=0;
     if((data2[1]&0x10)==0x10)
        LED4=1;
     else
      LED4=0;
     if((data2[1]&0x08)==0x08)
    LED5=1;
     else
     LED5=0;
/* **********************主程序******************** */
void main(void)
init_serial1();  //串口初始化
init_serial0();  //启动定时器0
TI=0;
RI=0;
IE=0x92;
while(1)
recv_data(data2); //接收程序
//////串口中断///////////
void Serial_INT() interrupt 4
  int i;
/* ?óê?êy?Y */
for(i=0; i<5; i++)
RI = 0;
while(!RI);
data2[i] = SBUF;
RI = 0;
data2[5]=0;
     // ±íê?êy?Y?áê?
/* 如果接收到程序,使灯亮 */
//if((data2[0]==0xA5)&&(data2[4]==ecc))
    LED1=1;
     else
        LED1=0;
    LED2=1;
     else
      LED2=0;
    LED3=1;
     else
     LED3=0;
        LED4=1;
     else
      LED4=0;
    LED5=1;
     else
     LED5=0;
guoyt 发表于 2019-7-14 18:09 | 显示全部楼层
有一定难度呀
hanwe 发表于 2019-7-14 18:13 | 显示全部楼层
怎么用11MHZ的晶振呢?11.0592MHZ会更好点
yufe 发表于 2019-7-14 18:16 | 显示全部楼层
还有延时程序写的不是很刁,应该这样:
void delay(uint z)
    uchar j;
    for(z;z>0;z--)
        for(j=110;j>0;j--);
yufe 发表于 2019-7-14 18:23 | 显示全部楼层
llia 发表于 2019-7-14 18:26 | 显示全部楼层
有延时程序写的不是很刁,应该这样:
void delay(uint z)
    uchar j;
    for(z;z>0;z--)
        for(j=110;j>0;j--);
llia 发表于 2019-7-14 19:11 | 显示全部楼层
楼主在中断发送数据,建议改到主函数里面发送比较好
hanwe 发表于 2019-7-14 19:14 | 显示全部楼层
单片机只有一个MCU,同时只能干一件事情
lium 发表于 2019-7-14 19:18 | 显示全部楼层
哦,那我就知道怎么回事了,多谢
