我的2812dsp中头文件有个地方看不懂
2309|1
 楼主| yyazaz 发表于 2011-11-9 15:09 | 显示全部楼层 |阅读模式
DSP, ui, se, RS, GB
struct  CSMSCR_BITS {      // bit   description
   Uint16     SECURE:1;    // 0     Secure flag
   Uint16     rsvd1:14;    // 14-1  reserved
   Uint16     FORCESEC:1;  // 15    Force Secure control bit
union CSMSCR_REG {
   Uint16       all;
   struct CSMSCR_BITS bit;
struct  CSM_REGS {
   Uint16         KEY0;       // KEY reg bits 15-0
   Uint16         KEY1;       // KEY reg bits 31-16
   Uint16         KEY2;       // KEY reg bits 47-32
   Uint16         KEY3;       // KEY reg bits 63-48
   Uint16         KEY4;       // KEY reg bits 79-64
   Uint16         KEY5;       // KEY reg bits 95-80
   Uint16         KEY6;       // KEY reg bits 111-96
   Uint16         KEY7;       // KEY reg bits 127-112
   Uint16         rsvd1;      // reserved
   Uint16         rsvd2;      // reserved
   Uint16         rsvd3;      // reserved
   Uint16         rsvd4;      // reserved
   Uint16         rsvd5;      // reserved
   Uint16         rsvd6;      // reserved
   Uint16         rsvd7;      // reserved
   union CSMSCR_REG CSMSCR;     // CSM Status & Control register
亲吻这是28的那块寄存器代表什么意思
jesuswd 发表于 2011-12-7 08:53 | 显示全部楼层
在这个文档里面有的TMS320x2833x, 2823x System Control and
Interrupts,是给FLASH 加密用的吧
