[电路资料] RK3399 芯片规格书
7354|30
幽魂 发表于 2020-2-1 15:26 | 显示全部楼层
 楼主| qq7643066 发表于 2020-2-2 19:27 | 显示全部楼层
RK3399板卡 Linux Alsa 音频开发说明文档一、安装配置
以VS-RK3399 为例:
1.声卡配置
Device Drivers > Sound card support > Advanced Linux Sound Architecture > ALSA
for SoC audio support > CODEC drivers
<*> Realtek ALC5640 CODEC
同时需要在板级文件dts 加入相应的Codec 配置
/kernel/arch/arm64/boot/dts/rockchip/rk3399-sunychip-board-mipi.dts
rt5640-sound {
                compatible = "simple-audio-card";
                simple-audio-card,format = "i2s";
                simple-audio-card,name = "rockchip,rt5640-codec";
                simple-audio-card,mclk-fs = <256>;
                simple-audio-card,widgets =
                        "Microphone", "Mic Jack",
                        "Headphone", "Headphone Jack",
                        "Speaker", "Speaker";
                simple-audio-card,routing =
                        "Mic Jack", "MICBIAS1",
                        "IN2P", "Mic Jack",
                        "IN2N", "Mic Jack",
                        "Headphone Jack", "HPOL",
                        "Headphone Jack", "HPOR",
                        "Speaker", "SPOLP",
                        "Speaker", "SPOLN",
                        "Speaker", "SPORP",
                        "Speaker", "SPORN";
                simple-audio-card,cpu {
                        sound-dai = <&i2s1>;
                simple-audio-card,codec {
                        sound-dai = <&rt5640>;
&i2c1 {
        status = "okay";
        i2c-scl-rising-time-ns = <300>;
        i2c-scl-falling-time-ns = <15>;
        rt5640: rt5640@1c{
                #sound-dai-cells = <0>;
                compatible = "realtek,rt5640";
                reg = <0x1c>;
                clocks = <&cru SCLK_I2S_8CH_OUT>;
                clock-names = "mclk";
                realtek,in1-differential;
                pinctrl-names = "default";
                //hp-con-gpio = <&gpio0 11 GPIO_ACTIVE_HIGH>;
                //hp-det-gpio = <&gpio4 28 GPIO_ACTIVE_LOW>;
                //io-channels = <&saradc 4>;
                //hp-det-adc-value = <300>;
2.Alsa-lib 及相关调试工具安装
配置勾选相应的安装包。进入到buildroot 目录,make menuconfig
Target packages > Audio and video applications > alsa-utils
可以根据实际的需求勾选相应的alsa 调试工具,一般勾选配置如上图。编译成功后在usr/bin
目录下会有相应的工具生成
二、alsa 配置文件解析及相关配置
1.alsa.conf 文件解析
ALSA 核心配置文件位于usr/share/alsa/目录下,主要配置文件为alsa.conf。其他配
置文件需不需要,位置在哪都由alsa.conf 决定。通常会有usr/share/alsa/card 和
usr/share/alsa/pcm 两个子目录,用于设置card 的相关参数,别名以及一些PCM 默认设置。
Alsa.conf 主要内容包括:
1)用hook 读取/etc/asound.conf 和~/.asoundrc 这两个配置文件
@hooks [
func load
files [
@func concat
strings [
{ @func datadir }
"/alsa.conf.d/"
"/etc/asound.conf"
"~/.asoundrc"
errors false
2)设置default pcm 的一些默认参数
defaults.ctl.card 0
defaults.pcm.card 0
defaults.pcm.device 0
defaults.pcm.subdevice -1
defaults.pcm.nonblock 1
defaults.pcm.compat 0
3)设置alsa 内置的一些plugin 接口参数,例如file:
pcm.file {
@args [ FILE FORMAT ]
@args.FILE {
type string
@args.FORMAT {
type string
default {
@func refer
name defaults.pcm.file_format
type file
slave.pcm null
file $FILE
format $FORMAT
truncate {
@func refer
name defaults.pcm.file_truncate
File plugin 的作用是将pcm 数据流存储到文件中
2.alsa.conf 主要配置
现在配置alsa.conf 文件主要是对route 通路和hw 参数进行配置。针对不同的codec,
放音和录音等都需要对route 通路和一些hw 参数进行设置。具体配置方法是在alsa.conf
配置文件中加入如下配置:
以rt5651 的放音为例:
ctl.SpeakerNormal{
type hw
card 0 # Can replace with driver"s name from /proc/asound/cardx
pcm.dmixer {
type dmix
ipc_key 1025
slave {
pcm "hw:0,0"
period_time 0
period_size 4096
buffer_size 16384
rate 44100
pcm.SpeakerNormal {
type plug
slave.pcm "dmixer"
type hooks
hooks.0 {
type ctl_elems
hook_args [
name 'DAC MIXL INF1 Switch'
value on
name 'DAC MIXR INF1 Switch'
value on
name 'Stereo DAC MIXL DAC L1 Switch'
value on
name 'Stereo DAC MIXR DAC R1 Switch'
value on
name 'OUT MIXL DAC L1 Switch'
value on
name 'OUT MIXR DAC R1 Switch'
value on
name 'HPOVOL L Switch'
value on
name 'HPOVOL R Switch'
value on
name 'HPO MIX HPVOL Switch'
value on
value on
name 'HPO L Playback Switch'
value on
name 'HPO R Playback Switch'
value on
对于route 通路具体值设置可以参考使用amixer contents 打印的格式
numid=9,iface=MIXER,name='Headphonel Playback Volume'
; type=INTEGER,access=rw---R--,values=1,min=0,max=3,step=0
: values=3
| dBscale-min=-48.00dB,step=12.00dB,mute=0
numid=10,iface=MIXER,name='Headphoner Playback Volume'
: values=3
numid=97,iface=MIXER,name='Headphone Switch'
; type=BOOLEAN,access=rw------,values=1
: values=on
numid=12,iface=MIXER,name='Lineoutn Playback Volume'
; type=INTEGER,access=rw---R--,values=1,min=0,max=1,step=0
RK 平台针对不同codec 对应的alsa.conf 文件都存放在sdk 代码的
device\rockchip\rk3399\alsa_conf 目录下,打包固件会将相应的alsa.conf 拷贝覆盖
usr/share/alsa/目录的alsa.conf
幽魂 发表于 2020-2-10 21:06 | 显示全部楼层
加油 加油 加油
 楼主| qq7643066 发表于 2020-5-5 18:41 | 显示全部楼层
rk3399 kernel编译
make ARCH=arm64 rockchip_defconfig
make -j8 ARCH=arm64 rk3399-firefly-android-sunchip.img
 楼主| qq7643066 发表于 2020-5-5 18:42 | 显示全部楼层
rk3399 开发板编译命令
kernel
android
source build/envsetup.sh
lunch rk3399_all-userdebug
make -j32
./mkimage.sh
 楼主| qq7643066 发表于 2020-5-6 11:15 | 显示全部楼层
uboot
make rk3399_box_defconfig
make ARCHV=aarch64 -j8
sw10086 发表于 2020-5-7 09:51 | 显示全部楼层
这种主板可以委托开发设计吗,包括硬件设计以及驱动调式
shanxin2012 发表于 2020-7-4 11:35 | 显示全部楼层
路过,realtek领域欢迎合作
1348795481 发表于 2020-8-3 18:04 | 显示全部楼层
sunychip.com这里面可以下载吗
