[应用相关] STM32 读取 WAV音频格式 播放出来
4662|29
 楼主| hanzhen654 发表于 2019-7-31 14:24 | 显示全部楼层
定时器初始化:
void Timerx_Init(u16 arr,u16 psc)
       NVIC_InitTypeDef NVIC_InitStructure;
       RCC->APB1ENR|=1<<1;//TIM3时钟使能
      TIM3->ARR=arr;  //设定计数器自动重装值
       TIM3->SC=psc;  //预分频器7200,得到10KHz的计数时钟
       TIM3->DIER|=1<<0;   //允许更新中断
       TIM3->DIER|=1<<6;   //允许触发中断
       TIM3->CR1|=0x01;    //使能定时器3
       //优先级设置
      NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
       NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
       NVIC_Init(&NVIC_InitStructure);
DAC初始化:
#include "dac.h"
extern u16 digital;
void MyDAC_Init(void)//DAC channel1 Configuration
    unsigned int tmpreg1=0,tmpreg2=0;
      RCC->APB2ENR|=1<<2;//使能PORTA时钟
       RCC->APB1ENR|=RCC_APB1Periph_DAC;//使能DAC时钟
      GPIOA->CRL&=0XFFF0FFFF;
       GPIOA->CRL|=0X00040000;//PA4浮空输入
    tmpreg1=DAC->CR;//Get the DAC CR value
    tmpreg1&=~(CR_CLEAR_Mask<<DAC_Channel_1);
  tmpreg2=(DAC_Trigger_Software|DAC_WaveGeneration_None|DAC_LFSRUnmask_Bits8_0|DAC_OutputBuffer_Enable);
    tmpreg1|=tmpreg2<<DAC_Channel_1;
    DAC->CR=tmpreg1;//Write to DAC CR
     DAC->CR|=CR_EN_Set<<DAC_Channel_1;//DAC通道1使能,PA4自动连接到DAC
       DAC1_SetData(0x000);
       #if 0
    tmpreg1&=~(CR_CLEAR_Mask<<DAC_Channel_2);  tmpreg2=(DAC_Trigger_Software|DAC_WaveGeneration_None|DAC_LFSRUnmask_Bits8_0|DAC_OutputBuffer_Enable);
tmpreg1|=tmpreg2<<DAC_Channel_2;
DAC->CR=tmpreg1;
       DAC->CR|=CR_EN_Set<<DAC_Channel_2;
       DAC2_SetData(0x000);
       #endif
void DAC1_SetData(u16 data)
       DAC->DHR12R1=data;//通道1的12位右对齐数据
       DAC->SWTRIGR|=0x01;//软件启动转换
void DAC2_SetData(u16 data)
       DAC->DHR12R2=data;//通道2的12位右对齐数据
       DAC->SWTRIGR|=0x02;//软件启动转换
定时器中断服务程序:
void TIM3_IRQHandler(void)
       u16 temp;
       if(TIM3->SR&0X0001)//溢出中断
              if(CHanalnum==1)//单声道
                     if(Bitnum==8)//8位精度
                            DAC->DHR12R1=wav_buf[DApc]*10/volume;
                            DAC->DHR12R2=wav_buf[DApc]*10/volume;
                            DAC->SWTRIGR |=0x01;
DApc++;
                     else if(Bitnum==16)
               temp=(((u8)(wav_buf[DApc+1]-0x80)<<4)|(wav_buf[DApc]>>4))*10/volume;
                        DAC->DHR12L1=temp;
                        DAC->DHR12L2=temp;
                        DAC->SWTRIGR|=0x01;
                        DApc+=2;
              else if(CHanalnum==2)
                     if(Bitnum==8)
                            DApc++;
                            DApc++;
                            DAC->SWTRIGR|=0x01;
                     else if(Bitnum==16)
                     {            DAC->DHR12L1=(((u8)(wav_buf[DApc+1]-0x80)<<4)|(wav_buf[DApc]>>4))*10/volume;                       DApc+=2;             DAC->DHR12L2=(((u8)(wav_buf[DApc+1]-0x80)<<4)|(wav_buf[DApc]>>4))*10/volume;
                            DApc+=2;
DAC->SWTRIGR|=0x01;
              if(DApc==16384)
        DApc=0;
        DACdone=1;
       TIM3->SR&=~(1<<0);
 楼主| hanzhen654 发表于 2019-7-31 14:26 | 显示全部楼层
WAV初始化:
u8 WAV_Init(u8* wav_buf)
       if(Check_Ifo(wav_buf,"RIFF"))
              return 1;
       wav1.wavlen=Get_num(wav_buf+4,4);
       printf("\n\rwav1.wavlen = %ld\n\r",wav1.wavlen);
//if(Check_Ifo(wav_buf+8,"WAVE"))return 2;//WAVE错误标志
//if(Check_Ifo(wav_buf+12,"fmt "))return 3;//fmt错误标志
       wav1.formart=Get_num(wav_buf+20,2);//格式类别
       printf("\n\rwav1.formart = %d\n\r",wav1.formart);
       wav1.CHnum=Get_num(wav_buf+22,2);//通道数
       printf("\n\rwav1.CHnum = %d\n\r",wav1.CHnum);
       CHanalnum=wav1.CHnum;
       wav1.SampleRate=Get_num(wav_buf+24,4);//采样率
       printf("\n\rwav1.SampleRate = %ld\n\r",wav1.SampleRate);
       wav1.speed=Get_num(wav_buf+28,4);//音频转换数率
       printf("\n\rwav1.speed = %ld\n\r",wav1.speed);
       wav1.ajust=Get_num(wav_buf+32,2);//数据块调速数
       printf("\n\rwav1.ajust = %d\n\r",wav1.ajust);
       wav1.SampleBits=Get_num(wav_buf+34,2);//样本数据位数
       printf("\n\rwav1.SampleBits = %d\n\r",wav1.SampleBits);
       Bitnum=wav1.SampleBits;
//if(Check_Ifo(wav_buf+36,"data"))return 4;//数据标志错误
       wav1.DATAlen=Get_num(wav_buf+40,4);//数据长度
       printf("\n\rwav1.DATAlen = %d\n\r",wav1.DATAlen);
       if(wav1.wavlen<0x100000)
              printf("\n\rwav1.wavlen = %dkb\n\r",(wav1.wavlen)>>10);
       else
              printf("\n\rwav1.wavlen = %dMb\n\r",(wav1.wavlen)>>20);
       if(wav1.formart==1)
              printf("\n\rWAV PCM\n\r");
       if(wav1.CHnum==1)
              printf("\n\rsingle\n\r");
       else
              printf("\n\rstereo\n\r");
       printf("\n\rwav1.SampleRate = %dkHz\n\r",(wav1.SampleRate)/1000);
       printf("\n\rwav1.speed = %dbps\n\r",(wav1.speed)/1000);
       printf("\n\rwav1.SampleBits = %dbit\n\r",wav1.SampleBits);
       return 0;
u8 Check_Ifo(u8* pbuf1,u8* pbuf2)
       u8 i;
       for(i=0;i<4;i++)
              if(pbuf1!=pbuf2)
                     return 1;
       return 0;
u32 Get_num(u8* pbuf,u8 len)
  u32 num;
       if(len==2)num=(pbuf[1]<<8)|pbuf[0];
       else if(len==4)num=(pbuf[3]<<24)|(pbuf[2]<<16)|(pbuf[1]<<8)|pbuf[0];
       return num;
WAV播放:
u8 Playwav(char *file)
       FIL fwav;
       FRESULT Res;
       UINT BR;
       unsigned char i;
       unsigned int times;
       Res = f_open(&fwav, file, FA_OPEN_EXISTING | FA_READ);
       if(Res != FR_OK)
              printf("\n\ropen file error : %d\n\r",Res);
       else
         Res = f_read(&fwav, wav_buf, sizeof(wav_buf), &BR);     /* Read a chunk of src file */
    if(Res==FR_OK)
                     WAV_Init(wav_buf);
                     DACdone=0;
                     DApc=44; //跳过头信息
                     Timerx_Init(1000000/wav1.SampleRate,72); //定时器初始化
                     times=(wav1.DATAlen>>10)-1; //计算数据大小
                     for(i=0;i<times/32;i++)//循环一次转换32KB数据
                            while(!DACdone);//等待前面16384字节转换完成                                                   DACdone=0;
                            Res = f_read(&fwav, wav_buf, 16384, &BR);
                            while(!DACdone);// 等待前面16384字节转换完成
                            DACdone=0;
                            Res = f_read(&fwav, wav_buf, 16384, &BR);//读取数据
              else
                     printf("\n\rread file error : %d\n\r",Res);
              f_close(&fwav);
       return 0;
 楼主| hanzhen654 发表于 2019-7-31 14:27 | 显示全部楼层
原帖出至:基于STM32的WAV音频格式播放器
http://www.openedv.com/forum.php?mod=viewthread&tid=32875&fromuid=45262
(出处: OpenEdv-开源电子网)
adg4510 发表于 2019-8-10 10:55 | 显示全部楼层
楼主你好,你定时器中断设置的溢出时间是多少啊
labasi 发表于 2019-8-15 11:05 | 显示全部楼层
非常感谢楼主分享
paotangsan 发表于 2019-8-15 11:07 | 显示全部楼层
非常感谢楼主分享
renzheshengui 发表于 2019-8-15 11:15 | 显示全部楼层
非常感谢楼主分享
