AT25DF641A总是读回0xFF
564|6
AT25DF641A与stm32f103的连接图应该是基本连接方式了(stm32f103中用到的是PB_15,PB_14,PB_13,PB_12分别对应接到AT25DF641A的DI,D0,CLK,CS),如后面的图所示。关键问题是写一个字节0x01数据再读回来的时候还是0xFF。代码用的是MBED中的Hotboards EEPROM修改后的(主要是原代码中没有AT25DF641A)
whoisilang|  楼主 | 2019-8-1 10:54 | 只看该作者
#include "Hotboards_eeprom.h"
#define READ     0x03
#define WRITE    0x02
#define WRDI     0x04
#define WREN     0x06
#define RDSR     0x05
#define WRSR     0x01
//<font color="#ff0000">PageSize和EepromSize是我修改过的地方</font>
const uint16_t PageSize[ ] = { 16,    16,  16,   16,   32,   32,   64,    64,    128,   256,    256,   256,   256,    256,    256,    256 };
const uint32_t EepromSize[ ] = { 256, 512, 1024, 2048, 4096, 8192, 16384, 32768, 65536, 131072, 262144,524288,1048576,2097152,4194304,8388608};
Hotboards_eeprom::Hotboards_eeprom( SPI &spi, PinName cs, uint8_t type )
    : _spi(spi), _cs_pin(cs)
    _cs_pin = cs;
    _type = type;
    _page = PageSize[ type ];
    _density = EepromSize[ type ];
* just make sure the Cs pin is not clear
void Hotboards_eeprom::init( void )
   _cs_pin = 1;
//        _cs_pin = 0;
//_spi.write( WREN );
//_cs_pin = 0;
//_spi.write( 0x01 );
//_spi.write( 0x00 );
//_cs_pin = 1;
* write a single byte in a given eeprom address, this operation will take 5ms
* address: eeprom address where tha byte will be written
* data: the byte that will be written at the given address
void Hotboards_eeprom::write( uint32_t address, uint8_t data )
    write( address, &data, 1 );
* write a given number of bytes into the eeprom atarting at a given address
* data: pointer to array of bytes that need to be written
* size: the number of bytes to write
void Hotboards_eeprom::write( uint32_t address, uint8_t *data, uint16_t size )
    uint16_t temp;
    /* just to cover your ass, check if the address is a valid direction */
    if( ( address < _density ) && ( size != 0 ) )
        /* check if the amount of bytes to be read from the requested address do not exced the eeprom
        memory map if so, then only read the bytes left*/
        if( ( address + size ) > _density )
            size = _density - address;
        /* Check how many bytes are left to be written within a single page */
        temp = _page - ( address % _page );
        if( temp >= size  )
            /* Data lenght can be written witihn the current page */
            writePage( address, data, size );
        else
            /* Data can not be written within the current page, so write only the bytes left */
            writePage( address, data, temp );
            /* update pointer to data, lenght and addres */
            data = data + temp;
            size = size - temp;
            address = address + temp;
            /* Check if the remaining data is bigger than a page size */
            while( size > _page )
                /* Write an entire page into eeprom */
                writePage( address, data, _page );
                size = size - _page;
                data = data + _page;
                address = address + _page;
            /* Write one last time if there is still data to be written */
            if( size != 0 )
* read a single byte from a given eeprom address
* address: eeprom address where the byte will be read
uint8_t Hotboards_eeprom::read( uint32_t address )
    uint8_t data;
    read( address, &data, 1 );
    return data;
* read a given number of bytes from the eeprom starting at a given address
* address: eeprom address where the bytes will be read it
* data: pointer to array where data will be stored
* size: the number of bytes to read
void Hotboards_eeprom::read( uint32_t address, uint8_t *data, uint16_t size )
    uint16_t i;
        /* operation begins, select memory */
        _cs_pin = 0;
        /* Send command Read and address, depend on device is the number of address bytes neccesary */
        sendAddress( READ, address );
        for( i = 0 ; i<size ; i++ )
            /* Read data from memory */
            *data = _spi.write( 0xAA );
            data++;
        /* operation ended, unselect memory */
        _cs_pin = 1;
void Hotboards_eeprom::sendAddress( uint8_t cmd, uint32_t address )
    if( _type < HT_EEPROM25xx_4Kb )
        /* Send the command and one byte address */
        _spi.write( cmd );
        _spi.write( address );
    else if( _type == HT_EEPROM25xx_4Kb )
        /* Send the command coded in the MSB of the address and one LSB address */
        _spi.write( cmd | ( uint8_t )( address >> 8 ) );
        _spi.write( ( uint8_t )address );
    else if( ( _type > HT_EEPROM25xx_4Kb ) && ( _type < HT_EEPROM25xx_1Mb ) )
        /* Send command plus two byte address */
        _spi.write( cmd );
        _spi.write( ( uint8_t )( address >> 8 ) );
    else if( _type >= HT_EEPROM25xx_1Mb )  //<font color="#ff0000">这个地方也是我修改过的</font>
        /* Send command plus three byte address */
        _spi.write( cmd );
        _spi.write( ( uint8_t )( address >> 16 ) );
void Hotboards_eeprom::writePage( uint32_t address, uint8_t *data, uint16_t size )
    uint16_t i;
    /* Select memory */
    _cs_pin = 0;
    /* write eneable latch */
    _spi.write( WREN );
    /* Unselect eeprom */
    _cs_pin = 1;
    /* Select memory */
    _cs_pin = 0;
    /* Send comand write and address, depend on device is the number of address bytes neccesary */
    sendAddress( WRITE, address );
    /* Send data to eeprom */
        _spi.write( *data );
        data++;
    _cs_pin = 1;
    /* wait until data has been recorded */
    wait( 0.006 );
whoisilang|  楼主 | 2019-8-1 10:55 | 只看该作者
#ifndef Hotboards_eeprom_h
#define Hotboards_eeprom_h
#include "mbed.h"
//EEPROM size in kilobits. EEPROM part numbers are usually designated in k-bits.
typedef enum
    HT_EEPROM25xx_1Kb=0,
    HT_EEPROM25xx_2Kb,
    HT_EEPROM25xx_4Kb,
    HT_EEPROM25xx_8Kb,
    HT_EEPROM25xx_16Kb,
    HT_EEPROM25xx_32Kb,
    HT_EEPROM25xx_64Kb,
    HT_EEPROM25xx_128Kb,
    HT_EEPROM25xx_256Kb,
    HT_EEPROM25xx_512Kb,
    HT_EEPROM25xx_1Mb,
                HT_EEPROM25xx_2Mb,
                HT_EEPROM25xx_4Mb,
                HT_EEPROM25xx_8Mb
}_eEEPROM;
class Hotboards_eeprom
    public :
        Hotboards_eeprom( SPI &spi, PinName cs, uint8_t type );
        void init( void );
        void write( uint32_t address, uint8_t data );
        void write( uint32_t address, uint8_t *data, uint16_t size );
        uint8_t read( uint32_t address );
        void read( uint32_t address, uint8_t *data, uint16_t size );
    protected :
        void sendAddress( uint8_t cmd, uint32_t address );
        void writePage( uint32_t address, uint8_t *data, uint16_t size );
        SPI _spi;
        DigitalOut _cs_pin;
        uint8_t _type;
        uint16_t _page;
        uint32_t _density;
#endif
whoisilang|  楼主 | 2019-8-1 17:30 | 只看该作者
问题找到了,因为没有0x39命令。结贴。
xixi2017| | 2019-8-5 23:31 | 只看该作者
发送命令错误啊?
zhuomuniao110| | 2019-8-5 23:57 | 只看该作者
这个芯片都搜不到,楼主应该先贡献一份手册。
alternate| | 2019-8-6 10:20 | 只看该作者
看来做事情之前还是要先好好看下手册
