实钟程序,通过89C52让1602液晶显示出实钟,通过key1键(功能键)设置日期,时间,key2键为按一次时间或日期加1,key3为按一次时间或日期减1,现在,更改日期时间还有时间走秒走分走时都没问题,就是小时每到24小时后星期不知道要怎么显示往前进一天,我只能实现经过24小时后星期往前进一天,但是再过24后,星期就不往前进一天了,不知道要嵌套在哪里,有没有帮帮忙的,程序如下:
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit dula=P2^6;
sbit wela=P2^7;
sbit rs=P3^5;
sbit lcden=P3^4;
sbit key1=P3^0;
sbit key2=P3^1;
sbit key3=P3^2;
sbit rd=P3^7;
uchar tt,num,a,b,k1num;
char miao,shi,fen,nian,ye,ri;
uchar code table[]=" 2000-01-01 SAR";
uchar code table1[]=" 00:00:00";
uchar code table2[]="SUN";
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com)
rs=0;
lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
rs=1;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
uchar num;
dula=0;
wela=0;
lcden=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<16;num++)
write_date(table[num]);
delay(5);
write_com(0x80+0x40);
for(num=0;num<12;num++)
write_date(table1[num]);
delay(5);
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void write_sfm(uchar add,uchar date)
uchar shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void write_nyr(uchar add,uchar date)
uchar shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+add);
void keyscan( )
rd=0;
if(key1==0)
delay(5);
if(key1==0)
{ k1num++;
while(!key1);
if(k1num==1)
TR0=0;
write_com(0x80+5);
write_com(0x0f);
if(k1num==2)
write_com(0x80+8);
if(k1num==3)
write_com(0x80+11);
if(k1num==4)
write_com(0x80+0x40+10);
if(k1num==5)
write_com(0x80+0x40+7);
if(k1num==6)
write_com(0x80+0x40+4);
if(k1num==7)
k1num=0;
write_com(0x0c);
TR0=1;
if(k1num!=0)
if(key2==0)
delay(5);
if(key2==0)
while(!key2);
if(k1num==1)
nian++;
write_nyr(4,nian);
write_com(0x80+5);
if(k1num==2)
ye++;
if(ye==13)
ye=1;
write_nyr(7,ye);
write_com(0x80+8);
if(k1num==3)
ri++;
if(ri==32)
ri=1;
write_nyr(10,ri);
write_com(0x80+11);
if(k1num==4)
miao++;
if(miao==60)
miao=0;
write_sfm(10,miao);
if(k1num==5)
fen++;
if(fen==60)
fen=0;
write_sfm(7,fen);
if(k1num==6)
shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
if(key3==0)
delay(5);
if(key3==0)
while(!key3);
if(k1num==2)
ye--;
if(ye==0)
ye=12;
write_nyr(7,ye);
write_com(0x80+8);
if(k1num==3)
ri--;
if(ri==0)
ri=31;
write_nyr(10,ri);
write_com(0x80+11);
if(k1num==4)
miao--;
if(miao==-1)
miao=59;
write_sfm(10,miao);
if(k1num==5)
fen--;
if(fen==-1)
fen=59;
write_sfm(7,fen);
if(k1num==6)
shi--;
if(shi==-1)
shi=23;
write_sfm(4,shi);
void main()
init();
while(1)
keyscan();
void timer0() interrupt 1
tt++;
if(tt==18)
tt=0;
miao++;
if(miao==60)
miao=0;
fen++;
if(fen==60)
fen=0;
shi++;
if(shi==24)
shi=0;
ri++;
write_com(0x80+13);
for(a=0;a<3;a++)
write_date(table2[a]);
delay(5);
write_sfm(4,shi);
write_sfm(7,fen);
write_sfm(10,miao);
