[应用相关] STM32duino.eu
1307|28
 楼主| goodluck09876 发表于 2019-8-26 14:50 | 显示全部楼层 |阅读模式
 楼主| goodluck09876 发表于 2019-8-26 14:51 | 显示全部楼层
 楼主| goodluck09876 发表于 2019-8-26 14:52 | 显示全部楼层
 楼主| goodluck09876 发表于 2019-8-26 14:53 | 显示全部楼层
 楼主| goodluck09876 发表于 2019-8-26 15:02 | 显示全部楼层
 楼主| goodluck09876 发表于 2019-8-26 15:03 | 显示全部楼层
 楼主| goodluck09876 发表于 2019-8-26 15:04 | 显示全部楼层
使用 ARDUINO 开发 STM32。可以借助arduino 更多的丰富的库文件。加速开发过程。
 楼主| goodluck09876 发表于 2019-8-26 15:05 | 显示全部楼层
 楼主| goodluck09876 发表于 2019-8-26 15:06 | 显示全部楼层
Nucleo nad Discovery development boards contains programmer/debugger ST-Link/V2-1. If you connect the dev board with this version of STLink, your Operating System alerts you that a new device is connected to your laptop. The behavior of ST-Link/V2-1 is the same like flash disk. It is connected like Mass Storage.
The second way is using ST-Link programmer, it is good way for oldest version of ST-Link or if you don?t have original Nucleo/Discovery board, but you have some supported STM32 and external ST-Link programmer/debugger.
 楼主| goodluck09876 发表于 2019-8-26 15:07 | 显示全部楼层
void setup()
// initialize digital pin LED_BUILTIN as an output
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
void loop()
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(500); // wait for a second
digitalWrite(LED_BUILTIN, LOW);        // turn the LED off by making the voltage LOW
