这个页面对capsense plus介绍的非常全面,分享给大家
http://china.cypress.com/?rID=47868&source=potm_banner#Training On-Demand
PSoC 3® and PSoC 5® offer the industry's first programmable solution with built-in capacitive-sensing capability that can also perform general system control functions.To accomplish this task, our solution combines two premier Cypress product offerings, the PSoC programmable system-on-chip and the industry-leading CapSense capacitive touch control technology
When designing capacitive touch sense technology into your application, it is crucial to keep in mind that the CapSense device exists within a larger framework.Careful attention to every level of detail from PCB layout to user interface to end-use operating environment will lead to robust and reliable system performance.For more in-depth information, refer Getting Started with CapSense.
What is SmartSense™?
Cypress's revolutionary, patent-pending SmartSense™ auto-tuning algorithm, which eliminates the requirement for system tuning.SmartSense enables automatic tuning of more than 10 parameters to achieve optimal touch sensing performance.
SmartSense™ Advantages
1. Auto-tuning:Competitor solutions require FW changes / use of interface boards for configuration changes, SmartSense takes care of the tuning without user intervention.
2. Time Saver:Saves a lot of time by avoiding manual tuning during development.
3. Process change:No re-tuning required when there is PCB process change / PCB vendor change (for cost reasons) / sensor characteristics change.
4. Overlay change:No re-tuning required when overlay material or thickness change.
5. Environment change:No re-tuning needed when the noise conditions change making the CapSense module
What is CapSense Tuner?
The graphical CapSense software module in Cypress's PSoC Creator™ IDE makes it easy for designers to define combinations of buttons, sliders, touch pads and proximity-sensing capacitive sensors, and offers real-time feedback of parameters such as signal-to-noise ratio (SNR), finger threshold, noise threshold, and more.
The module features include:
1. Supports user defined combinations of button, slider, touch pad, and proximity capacitive sensors
2. Provides automatic SmartSense tuning or manual tuning
3. High immunity to AC power line noise, EMC noise, and power supply voltage changes
4. Optional two scan channels (parallel synchronized) increases sensor scan rate.
5. Shield electrode support for reliable operation in the presence of water film or droplets
6. Guided sensor and terminal assignments using the CapSense customizer
