[技术求助]
THS4275的关断模式是什么呀 我找不到
304|6
shimx|  楼主 | 2019-10-13 11:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
liliang9554| | 2019-10-13 11:46 | 只看该作者
THS4275的Pin8是关断引脚
dengdc| | 2019-10-13 11:50 | 只看该作者
低电平可以控制芯片关断。
wyjie| | 2019-10-13 11:54 | 只看该作者
楼上正解
zhanghqi| | 2019-10-13 12:04 | 只看该作者
关键是我想知道这个4275的是什么作用?
heweibig| | 2019-10-13 12:07 | 只看该作者
其实数据手册有详细的介绍
Power-Down Reference Pin Operation
In addition to the power-down pin, the THS4275 also features a reference pin (REF) which allows the user to control the enable or disable power-down voltage levels applied to the PD pin. Operation of the reference pin as it relates to the power-down pin is described below.
In most split-supply applications, the reference pin is connected to ground. In some cases, the user may want to connect it to the negative or positive supply rail. In either case, the user needs to be aware of the voltage level thresholds that apply to the power-down pin.
shimx|  楼主 | 2019-10-13 12:11 | 只看该作者
哦,那我就知道怎么回事了,多谢大家
