[资料干货] RISCV的jtag调试
765|0
 楼主| kaiw 发表于 2019-11-4 21:31 | 显示全部楼层 |阅读模式
用openocd进行jtag调试时出现“Error:unknown target type riscv,please try one of arm7tdmi,....”应该怎么怎么解决啊?
运行脚本为:
adapter_khz     10000
interface ftdi
ftdi_device_desc "Dual RS232-HS"
ftdi_vid_pid 0x0403 0x6010
ftdi_layout_init 0x0008 0x001b
ftdi_layout_signal nSRST -oe 0x0020 -data 0x0020
#Reset Stretcher logic on FE310 is ~1 second long
#This doesn't apply if you use
# ftdi_set_signal, but still good to document
#adapter_nsrst_delay 1500
set _CHIPNAME riscv
jtag newtap $_CHIPNAME cpu -irlen 5 -expected-id 0x10e31913
set _TARGETNAME $_CHIPNAME.cpu
target create $_TARGETNAME riscv -chain-position $_TARGETNAME
$_TARGETNAME configure -work-area-phys 0x80000000 -work-area-size 10000 -work-area-backup 1
flash bank onboard_spi_flash fespi 0x20000000 0 0 0 $_TARGETNAME
init
#reset -- This type of reset is not implemented yet
if {[ info exists pulse_srst]} {
  ftdi_set_signal nSRST 0
  ftdi_set_signal nSRST z
  #Wait for the reset stretcher
  #It will work without this, but
  #will incur lots of delays for later commands.
  sleep 1500
halt
flash protect 0 64 last off
