Linux驱动开发之tiny6410_LED驱动
4043|6
 楼主| caoqing1314 发表于 2011-11-24 20:54 | 显示全部楼层 |阅读模式
#include <linux/miscdevice.h>
#include <linux/fs.h>
#include <linux/pci.h>
#include <mach/map.h>
#include <mach/regs-gpio.h>
#include <mach/gpio-bank-k.h>
#include "leds.h"
#define DEVICE_NAME "tiny6410_leds"
MODULE_LICENSE("GPL");
MODULE_AUTHOR("pang123hui");
static long sbc2440_leds_ioctl(struct file *filp, unsigned int cmd, unsigned long arg)
    switch(cmd) {
        unsigned tmp;
    case 0:
    case 1:
        if(arg > 4)
            //非法参数
            return -EINVAL;
        tmp = readl(S3C64XX_GPKDAT);
        tmp &= ~(1 << (3 + arg));
        tmp |= ((cmd) << (3 + arg));
        writel(tmp, S3C64XX_GPKDAT);
        return 0;
    case 1:
    case 2:
    case 3:
    case 4:
        tmp = (tmp & ~(1<<(cmd - 1 + 4)))|(arg<<(cmd -1 + 4));
        return 0;
    default:
        return -EINVAL;
static struct file_operations dev_fops = {
    .owner          = THIS_MODULE,
    .unlocked_ioctl = sbc2440_leds_ioctl,
//misc device:杂项设备,即主设备号为10的特殊字符设备
static struct miscdevice misc = {
    //次设备号,注意不要与/proc/misc中已有杂项设备次设备号冲突
    //MISC_DYNAMIC_MINOR来动态获取次设备号
    .minor = MISC_DYNAMIC_MINOR,
    //设备名称
    .name = DEVICE_NAME,
    .fops = &dev_fops,
static int __init dev_init(void)
    int ret;
        unsigned tmp;
        tmp = readl(S3C64XX_GPKCON);
        //GPKCON配置GPK4到GPK7配置为0001输出
        tmp = (tmp & ~(0xffffU<<16))|(0x1111U<<16);
        writel(tmp, S3C64XX_GPKCON);
        //GPKDAT[7:4] = 1
        //灯灭
        tmp |= (0xF << 4);
        //禁止上拉下拉
        tmp = readl(S3C64XX_GPKPUD);
        tmp &= (0x00 << 8);
        writel(tmp, S3C64XX_GPKPUD);
    //该函数会自动创建设备节点,即设备文件
    ret = misc_register(&misc);
    printk (DEVICE_NAME"\tinitialized\n");
    return ret;
static void __exit dev_exit(void)
    misc_deregister(&misc);
module_init(dev_init);
module_exit(dev_exit);
makefile
ifneq ($(KERNELRELEASE),)
    obj-m := leds.o
else
KERNELDIR := /opt/FriendlyARM/mini6410/linux/linux-2.6.38
PWD:=$(shell pwd)
all:
    make -C $(KERNELDIR) M=$(PWD) modules
clean:
    rm -rf *.ko *.o *.mod.c *.mod.o *.symvers
endif
leds_test
#include <stdio.h>
//exit
#include <stdlib.h>
#include <sys/ioctl.h>
int main(int argc, char **argv)
    int num = 0;
    int led_state = 1;
    int fd = 0;
    //参数赋值
    if(argc != 3 || sscanf(argv[1],"%d", &num) != 1 || sscanf(argv[2], "%d", &led_state) != 1 || num > 4 || led_state > 1)
        fprintf(stderr, "error\n");
        exit(1);
    printf("num = %d, led_state = %d\n", num, led_state);
    fd = open("/dev/tiny6410_leds", 0);
    if (fd < 0) {
        fd = open("/dev/tiny6410_leds0", 0);
    if (fd < 0) {
        perror("open device leds");
        exit(1);
    ioctl(fd, num, led_state);
    printf("led%d\n", num);
    close(fd);
    return 0;
 楼主| caoqing1314 发表于 2011-11-24 21:01 | 显示全部楼层
        tmp &= (0x00 << 8);
这里谁能给出完整的解释,不是只有GPK[4]到GPK[7]禁止上拉和下拉吗,这里应该不是这样设计的吧????
ycz9999 发表于 2011-11-29 01:06 | 显示全部楼层
多看看那CPU的datasheet  加油!
ycz9999 发表于 2011-11-29 01:07 | 显示全部楼层
2# caoqing1314 要多看看那CPU的datasheet
 楼主| caoqing1314 发表于 2011-11-29 17:21 | 显示全部楼层
是要看看,但是这个我理解没错,老师说这个原设计要改进
rhythm92 发表于 2013-2-1 21:45 | 显示全部楼层
mark~我也是这个板子。。。
yhhsky 发表于 2013-3-31 10:04 | 显示全部楼层
