[DemoCode下载]
NUC200测了脉宽的方法
562|5
heisexingqisi|  楼主 | 2019-11-24 20:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
NUC, PWM, TE, AN, TI
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 7 $
* $Date: 16/07/22 10:46a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Capture the PWMB Channel 1 waveform by PWMB Channel 2.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC200Series.h"
/* Macro, type and constant definitions        */
#define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
#define PLL_CLOCK           50000000
/* Global variables        */
* @brief       PWMB IRQ Handler
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     ISR to handle PWMB interrupt event
void PWMB_IRQHandler(void)
//    uint32_t u32PwmIntFlag;
    uint32_t u32CapIntFlag1;
    /* Handle PWMB Capture function */
    u32CapIntFlag1 = PWMB->CCR2;
    /* PWMB channel 2 Capture interrupt */
    if(u32CapIntFlag1 & PWM_CCR2_CAPIF2_Msk)
        PWMB->CCR2 &= (PWM_CCR_MASK | PWM_CCR2_CAPIF2_Msk);
/* Capture function to calculate the input waveform information                         */
/* u32Count[4] : Keep the internal counter value when input signal rising / falling     */
/*               happens        */
/* time    A    B     C     D                                                           */
/*           ___   ___   ___   ___   ___   ___   ___   ___                              */
/*      ____|   |_|   |_|   |_|   |_|   |_|   |_|   |_|   |_____                        */
/* index              0 1   2 3                                                         */
/* The capture internal counter down count from 0x10000, and reload to 0x10000 after    */
/* input signal falling happens (Time B/C/D)                                            */
void CalPeriodTime(PWM_T *PWM, uint32_t u32Ch)
    uint16_t u32Count[4];
    uint32_t u32i;
    uint16_t u16RisingTime, u16FallingTime, u16HighPeroid, u16LowPeroid, u16TotalPeroid;
    /* Clear Capture Falling Indicator (Time A) */
    PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_FALLING_LATCH);
    /* Wait for Capture Falling Indicator  */
    while(PWM_GetCaptureIntFlag(PWM, u32Ch) < 2);
    /* Clear Capture Falling Indicator (Time B)*/
    u32i = 0;
    while(u32i < 4)
        /* Clear Capture Falling and Rising Indicator */
        PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_FALLING_LATCH | PWM_CAPTURE_INT_RISING_LATCH);
        /* Get Capture Falling Latch Counter Data */
        u32Count[u32i++] = PWM_GET_CAPTURE_FALLING_DATA(PWM, u32Ch);
        /* Wait for Capture Rising Indicator */
        /* Clear Capture Rising Indicator */
        PWM_ClearCaptureIntFlag(PWM, u32Ch, PWM_CAPTURE_INT_RISING_LATCH);
        /* Get Capture Rising Latch Counter Data */
        u32Count[u32i++] = PWM_GET_CAPTURE_RISING_DATA(PWM, u32Ch);
    u16RisingTime = u32Count[1];
    u16FallingTime = u32Count[0];
    u16HighPeroid = u32Count[1] - u32Count[2];
    u16LowPeroid = 0x10000 - u32Count[1];
    u16TotalPeroid = 0x10000 - u32Count[2];
    printf("\nPWM generate: \nHigh Period=7199 ~ 7201, Low Period=16799 ~ 16801, Total Period=23999 ~ 24001\n");
    printf("\nCapture Result: Rising Time = %d, Falling Time = %d \nHigh Period = %d, Low Period = %d, Total Period = %d.\n\n",
           u16RisingTime, u16FallingTime, u16HighPeroid, u16LowPeroid, u16TotalPeroid);
    if((u16HighPeroid < 7199) || (u16HighPeroid > 7201) || (u16LowPeroid < 16799) || (u16LowPeroid > 16801) || (u16TotalPeroid < 23999) || (u16TotalPeroid > 24001))
        printf("Capture Test Fail!!\n");
    else
        printf("Capture Test Pass!!\n");
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for IRC22M clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external 12MHz XTAL, internal 22.1184MHz */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC22M_EN_Msk);
    /* Enable PLL and Set PLL frequency */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_PLL, CLK_CLKDIV_HCLK(2));
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable PWM module clock */
    CLK_EnableModuleClock(PWM45_MODULE);
    CLK_EnableModuleClock(PWM67_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Select PWM module clock source */
    CLK_SetModuleClock(PWM45_MODULE, CLK_CLKSEL2_PWM45_S_HXT | CLK_CLKSEL2_PWM45_EXT_HXT, 0);
    CLK_SetModuleClock(PWM67_MODULE, CLK_CLKSEL2_PWM67_S_HXT | CLK_CLKSEL2_PWM67_EXT_HXT, 0);
    /* User can select PWM module clock source from LIRC as below */
    //CLK_SetModuleClock(PWM45_MODULE, CLK_CLKSEL2_PWM45_S_LIRC | CLK_CLKSEL2_PWM45_EXT_LIRC, 0);
    //CLK_SetModuleClock(PWM67_MODULE, CLK_CLKSEL2_PWM67_S_LIRC | CLK_CLKSEL2_PWM67_EXT_LIRC, 0);
    /* Reset PWMB channel0~channel3 */
    SYS_ResetModule(PWM47_RST);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    //SystemCoreClockUpdate();
    PllClock        = PLL_CLOCK;            // PLL
    SystemCoreClock = PLL_CLOCK / 1;        // HCLK
    CyclesPerUs     = PLL_CLOCK / 1000000;  // For SYS_SysTickDelay()
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
    SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD);
    /* Set GPE multi-function pins for PWMB Channel1 and channel2 */
    SYS->GPE_MFP &= ~(SYS_GPE_MFP_PE5_Msk | SYS_GPE_MFP_PE0_Msk);
    SYS->GPE_MFP |= SYS_GPE_MFP_PE5_PWM5 | SYS_GPE_MFP_PE0_PWM6;
void UART0_Init()
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  Main Function        */
int32_t main(void)
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\nSystem clock rate: %d Hz\n", SystemCoreClock);
    printf("+------------------------------------------------------------------------+\n");
    printf("|                          PWM Driver Sample Code                        |\n");
    printf("|        |\n");
    printf("  This sample code will use PWMB channel 2 to capture\n  the signal from PWMB channel 1.\n");
    printf("  I/O configuration:\n");
    printf("    PWM5(PE.5 PWMB channel 1) <--> PWM6(PE.0 PWMB channel 2)\n\n");
    printf("Use PWMB Channel 2(PE.0) to capture the PWMB Channel 1(PE.5) Waveform\n");
    while(1)
        printf("Press any key to start PWM Capture Test\n");
        getchar();
        /* Set the PWMB Channel 1 as PWM output function.                                               */
        /* Assume PWM output frequency is 250Hz and duty ratio is 30%, user can calculate PWM settings by follows.
           duty ratio = (CMR+1)/(CNR+1)
           cycle time = CNR+1
           High level = CMR+1
           PWM clock source frequency = __HXT = 12000000
           (CNR+1) = PWM clock source frequency/prescaler/clock source divider/PWM output frequency
                   = 12000000/2/1/250 = 24000
           (Note: CNR is 16 bits, so if calculated value is larger than 65536, user should increase prescale value.)
           CNR = 23999
           duty ratio = 30% ==> (CMR+1)/(CNR+1) = 30%
           CMR = 7199
           Prescale value is 1 : prescaler= 2
           Clock divider is PWM_CSR_DIV1 : clock divider =1
        /* set PWMB channel 1 output configuration */
        PWM_ConfigOutputChannel(PWMB, PWM_CH1, 250, 30);
        /* Enable PWM Output path for PWMB channel 1 */
        PWM_EnableOutput(PWMB, 0x2);
        /* Enable Timer for PWMB channel 1 */
        PWM_Start(PWMB, 0x2);
        /* Set the PWMB channel 2  for capture function                                         */
        /* If input minimum frequency is 250Hz, user can calculate capture settings by follows.
           Capture clock source frequency = __HXT = 12000000 in the sample code.
           (CNR+1) = Capture clock source frequency/prescaler/clock source divider/minimum input frequency
           CNR = 0xFFFF
           (Note: In capture mode, user should set CNR to 0xFFFF to increase capture frequency range.)
        /* set PWMB channel 2 capture configuration */
        PWM_ConfigCaptureChannel(PWMB, PWM_CH2, 166, 0);
        /* Enable Backward Compatible: write 1 to clear CFLRI0~3 and CRLRI0~3 */
        PWMB->PBCR = 1;
        /* Enable capture falling edge interrupt for PWMB channel 2 */
        PWM_EnableCaptureInt(PWMB, PWM_CH2, PWM_CAPTURE_INT_FALLING_LATCH);
        /* Enable PWMB NVIC interrupt */
        NVIC_EnableIRQ((IRQn_Type)(PWMB_IRQn));
        /* Enable Timer for PWMB channel 2  */
        PWM_Start(PWMB, 0x4);
        /* Enable Capture Function for PWMB channel 2 */
        PWM_EnableCapture(PWMB, 0x4);
        /* Wait until PWMB channel 2 Timer start to count */
        while(PWMB->PDR2 == 0);
        /* Capture the Input Waveform Data */
        CalPeriodTime(PWMB, PWM_CH2);
        /* Stop PWMB channel 1 (Recommended procedure method 1)                                                 */
        /* Set PWM Timer loaded value(CNR) as 0. When PWM internal counter(PDR) reaches to 0, disable PWM Timer */
        /* Set PWMB channel 1 loaded value as 0 */
        PWM_Stop(PWMB, 0x2);
        /* Wait until PWMB channel 1 Timer Stop */
        while(PWMB->PDR1 != 0);
        /* Disable Timer for PWMB channel 1 */
        PWM_ForceStop(PWMB, 0x2);
        /* Disable PWM Output path for PWMB channel 1 */
        PWM_DisableOutput(PWMB, 0x2);
        /* Stop PWMB channel 2 (Recommended procedure method 1)                                                 */
        /* Disable PWMB NVIC */
        NVIC_DisableIRQ((IRQn_Type)(PWMB_IRQn));
        /* Set loaded value as 0 for PWMB channel 2 */
        PWM_Stop(PWMB, 0x4);
        /* Wait until PWMB channel 2 current counter reach to 0 */
        while(PWMB->PDR2 != 0);
        /* Disable Timer for PWMB channel 2 */
        PWM_ForceStop(PWMB, 0x4);
        /* Disable Capture Function and Capture Input path for  PWMB channel 2*/
        PWM_DisableCapture(PWMB, 0x4);
        /* Clear Capture Interrupt flag for PWMB channel 2*/
        PWM_ClearCaptureIntFlag(PWMB, PWM_CH2, PWM_CAPTURE_INT_FALLING_LATCH);
heisexingqisi|  楼主 | 2019-11-24 20:43 | 只看该作者
注意各个函数参数的意义。
幸福小强| | 2019-11-24 21:08 | 只看该作者
新唐好多系列的这个例子都是类似这种方式写的,说明库函数比较统一。
dongnanxibei| | 2019-11-27 07:11 | 只看该作者
这个方法非常有效。定时器捕获那个没这个好懂。
huahuagg| | 2019-11-27 07:26 | 只看该作者
一次测量出来多个值
734774645| | 2019-11-28 15:32 | 只看该作者
可以直接用
