LM811的PWM控制MG995舵机
5615|1
 楼主| guozhiyang 发表于 2011-11-25 22:40 | 显示全部楼层 |阅读模式
在看LM3S811用PWM控制舵机的时候,要产生一定占空比的PWM方波,经过自己的实验可以让舵机实现-90,-45,0,45,90的运转。但是自己看LM811的PWM的驱动程序源码的时候有几点要重视。在
void  PWMGenConfigure(unsigned long ulBase, unsigned long ulGen,
                unsigned long ulConfig)
    // Check the arguments.
    ASSERT(ulBase == PWM_BASE);
    ASSERT(PWMGenValid(ulGen));
    // Compute the generator's base address.
    ulGen = PWM_GEN_BADDR(ulBase, ulGen);
    // Change the global configuration of the generator.
    HWREG(ulGen + PWM_O_X_CTL) = ((HWREG(ulGen + PWM_O_X_CTL) &
                                   ~(PWM_X_CTL_MODE | PWM_X_CTL_DEBUG |
                                     PWM_X_CTL_LATCH | PWM_X_CTL_MINFLTPER |
                                     PWM_X_CTL_FLTSRC | PWM_X_CTL_DBFALLUPD_M |
                                     PWM_X_CTL_DBRISEUPD_M |
                                     PWM_X_CTL_DBCTLUPD_M |
                                     PWM_X_CTL_GENBUPD_M |
                                     PWM_X_CTL_GENAUPD_M |
                                     PWM_X_CTL_LOADUPD | PWM_X_CTL_CMPAUPD |
                                     PWM_X_CTL_CMPBUPD)) | ulConfig);
    // Set the individual PWM generator controls.
    if(ulConfig & PWM_X_CTL_MODE)
        // In up/down count mode, set the signal high on up count comparison
        // and low on down count comparison (that is, center align the
        // signals).
        HWREG(ulGen + PWM_O_X_GENA) = (PWM_X_GENA_ACTCMPAU_ONE |
                                       PWM_X_GENA_ACTCMPAD_ZERO);
        HWREG(ulGen + PWM_O_X_GENB) = (PWM_X_GENB_ACTCMPBU_ONE |
                                       PWM_X_GENB_ACTCMPBD_ZERO);
    else
        // In down count mode, set the signal high on load and low on count
        // comparison (that is, left align the signals).
        HWREG(ulGen + PWM_O_X_GENA) = (PWM_X_GENA_ACTLOAD_ONE |
        HWREG(ulGen + PWM_O_X_GENB) = (PWM_X_GENB_ACTLOAD_ONE |
其中的两句源码        HWREG(ulGen + PWM_O_X_GENA) = (PWM_X_GENA_ACTCMPAU_ONE |
                                       PWM_X_GENA_ACTCMPBU_ZERO);
在这里面有PWM_X_GENA_ACTCMPAU_ONE |PWM_X_GENA_ACTCMPBU_ZERO位或的操作,但是通过查hw_pwm.h我查到PWM_X_GENA_ACTCMPAU_ONE =0x00000030,PWM_X_GENA_ACTCMPBU_ZERO=0x00000020,但是位或以后不就是0x00000050;这样的话ActCmpAU=0x01,ActCmpAD=0x01,都是将输出信号反向。我认为它的驱动库有点问题。我把PWM_X_GENA_ACTCMPAD_ZERO<<2就可以实现一定的占空比得矩形波。我实验了可以。希望给大家的建议。
#include "hw_memmap.h"
#include "hw_types.h"
#include "sysctl.h"
#include "gpio.h"
#include "pwm.h"
#include "hw_ints.h"
#include "delay.h"
#define PH0_PWM2  GPIO_PIN_0
#define PH1_PWM3  GPIO_PIN_1
#define LED       GPIO_PIN_6
unsigned int jiaodu[]={12000,16000,12000,8000};
unsigned int jiaodu1[]={12000,20000,12000,4000};
//unsigned int jiaodu1[]={148000,140000,148000,156000};
void H_T();
void Q_J();
** Function name:       main()
** Descriptions:        主函数
** input parameters:    NONE
** output parameters:   NONE
** Returned value:      NONE
int  main (void)
    SysCtlClockSet(SYSCTL_SYSDIV_1 |                                    /*  配置6MHz外部晶振作为主时钟  */
                   SYSCTL_USE_OSC  |
                   SYSCTL_OSC_MAIN |
                   SYSCTL_XTAL_8MHZ);
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOH|SYSCTL_PERIPH_GPIOC);                        /*  使能PWM2和PWM3输出所在GPIO  */
    SysCtlPeripheralEnable(SYSCTL_PERIPH_PWM);                          /*  使能PWM模块                 */
    SysCtlPWMClockSet(SYSCTL_PWMDIV_1);                                 /*  PWM时钟配置:不分频         */
    GPIOPinTypePWM(GPIO_PORTH_BASE, GPIO_PIN_0);                        /*  PH0配置为PWM功能            */
    GPIOPinTypePWM(GPIO_PORTH_BASE, GPIO_PIN_1);                        /*  PH1配置为PWM功能            */
    PWMGenConfigure(PWM_BASE, PWM_GEN_1,                                /*  配置PWM发生器1:加减计数    */
                    PWM_GEN_MODE_UP_DOWN | PWM_GEN_MODE_NO_SYNC);
    PWMGenPeriodSet(PWM_BASE, PWM_GEN_1, 160000);                         /*  设置PWM发生器1的周期        */
   PWMPulseWidthSet(PWM_BASE, PWM_OUT_2, jiaodu[0]);                        /*  设置PWM2输出的脉冲宽度      */
   PWMPulseWidthSet(PWM_BASE, PWM_OUT_3, jiaodu[0]);                        /*  设置PWM3输出的脉冲宽度      */
  //  PWMSyncUpdate(PWM_BASE,PWM_GEN_1_BIT);
    PWMOutputState(PWM_BASE, (PWM_OUT_2_BIT | PWM_OUT_3_BIT), true);    /*  使能PWM2和PWM3的输出        */
    PWMGenEnable(PWM_BASE, PWM_GEN_1);                                  /*  使能PWM发生器1,            */
    GPIOPinTypeGPIOOutput(GPIO_PORTC_BASE,LED);
    GPIOPinWrite(GPIO_PORTC_BASE,LED,0XFF);
        /*  开始产生PWM方波             */
  //  PWMGenIntTrigEnable(PWM_BASE,PWM_GEN_1,PWM_INT_CNT_ZERO);
   // PWMIntEnable(PWM_BASE,PWM_INT_GEN_1);
   // IntEnable(INT_PWM1);
//   IntMasterEnable();
    while(1)
        Q_J();
        H_T();
void  PWM_Generator_1_ISR (void)
    const unsigned long ulTab[10] ={156000,148000,140000};
    static unsigned long n = 0;
    PWMGenIntClear(PWM_BASE,
                   PWM_GEN_1,
                   PWM_INT_CNT_ZERO);
    PWMPulseWidthSet(PWM_BASE, PWM_OUT_2, ulTab[n]);                    /*  设置PWM2输出的周期          */
    PWMPulseWidthSet(PWM_BASE, PWM_OUT_3, ulTab[2-n]);                  /*  设置PWM3输出的周期          */
    GPIOPinWrite(GPIO_PORTC_BASE,LED,0);
    n++;
    if ( n >= 3 ) {
        n = 0;
void Q_J()
  unsigned char i=1,j=1;
  PWMPulseWidthSet(PWM_BASE, PWM_OUT_2, jiaodu[i++]);                    /*  设置PWM2输出的周期          */
  //PWMPulseWidthSet(PWM_BASE, PWM_OUT_3, jiaodu);                  /*  设置PWM3输出的周期          */
  delay_ms(220);
  PWMPulseWidthSet(PWM_BASE,PWM_OUT_3,jiaodu1[j++]);
  delay_ms(220);
  PWMPulseWidthSet(PWM_BASE,PWM_OUT_2,jiaodu);
  delay_ms(230);
void H_T()
    unsigned char i=1,j=2;
  delay_ms(220);
  delay_ms(220);
  delay_ms(230);
tianm 发表于 2011-11-26 08:30 | 显示全部楼层
这个版排的这么奇怪
