[DemoCode下载] 做了个呼吸灯,发现了个天大的秘密
906|12
 楼主| 小明的同学 发表于 2019-12-23 23:01 | 显示全部楼层 |阅读模式
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
  4. * $Revision: 5 $
  5. * $Date: 15/02/06 10:22a $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    Show how to set GPIO pin mode and use pin data input/output control.
  7. * @note
  8. * Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
  9. ******************************************************************************/
  10. #include <stdio.h>
  11. #include "M058S.h"
  12. #define PLL_CLOCK           50000000
  13. extern char GetChar(void);
  14. void SYS_Init(void)
  15. {
  16.     /*---------------------------------------------------------------------------------------------------------*/
  17.     /* Init System Clock        */
  18.     /*---------------------------------------------------------------------------------------------------------*/
  19.     /* Enable Internal RC 22.1184MHz clock */
  20.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  21.     /* Waiting for Internal RC clock ready */
  22.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  23.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  24.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  25.     /* Enable external XTAL 12MHz clock */
  26.     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
  27.     /* Waiting for external XTAL clock ready */
  28.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
  29.     /* Set core clock as PLL_CLOCK from PLL */
  30.     CLK_SetCoreClock(PLL_CLOCK);
  31.     /* Enable UART module clock */
  32.     CLK_EnableModuleClock(UART0_MODULE);
  33.     /* Select UART module clock source */
  34.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
  35.     /*---------------------------------------------------------------------------------------------------------*/
  36.     /* Init I/O Multi-function        */
  37.     /*---------------------------------------------------------------------------------------------------------*/
  38.     /* Set P3 multi-function pins for UART0 RXD and TXD */
  39.     SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
  40.     SYS->P3_MFP |= (SYS_MFP_P30_RXD | SYS_MFP_P31_TXD);
  41. }
  42. void UART0_Init(void)
  43. {
  44.     /*---------------------------------------------------------------------------------------------------------*/
  45.     /* Init UART        */
  46.     /*---------------------------------------------------------------------------------------------------------*/
  47.     /* Reset UART0 */
  48.     SYS_ResetModule(UART0_RST);
  49.     /* Configure UART0 and set UART0 Baudrate */
  50.     UART_Open(UART0, 115200);
  51. }
  52. /*---------------------------------------------------------------------------------------------------------*/
  53. /* MAIN function        */
  54. /*---------------------------------------------------------------------------------------------------------*/
  55. int main(void)
  56. {
  57.     unsigned int  x=0,t=0,f=0;
  58.     /* Unlock protected registers */
  59.     SYS_UnlockReg();
  60.     /* Init System, peripheral clock and multi-function I/O */
  61.     SYS_Init();
  62.     /* Lock protected registers */
  63.     SYS_LockReg();
  64.     /* Init UART0 for printf */
  65.     UART0_Init();
  66.     printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
  67.     /* Configure P3.6 as Output mode */
  68.     GPIO_SetMode(P3, BIT6, GPIO_PMD_OUTPUT);
  69. x=0;
  70. t=5000;
  71. while(1)
  72. {
  73.    P36=1;
  74.          CLK_SysTickDelay(x+1);
  75.    P36=0;
  76.          CLK_SysTickDelay(t+1-x);
  77. if(f==0)  x=x+25;
  78. if(f==1)  x=x-25;
  79. if(x>=t) f=1;
  80. if(x<=1) f=0;
  81.
  82.   }
  83. }
  84. /*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
代码虽然简单,但是已经实现呼吸灯功能了,可以慢慢亮,然后慢慢灭。
 楼主| 小明的同学 发表于 2019-12-23 23:02 | 显示全部楼层
秘密就在那个延时函数里。
如果那个延时函数的参数是0,这就完蛋了,啥都弄不成。所以那个参数最小是1才行。
 楼主| 小明的同学 发表于 2019-12-23 23:06 | 显示全部楼层
一定要注意这个函数的参数,不能为0,必须为正整数。
 楼主| 小明的同学 发表于 2019-12-23 23:08 | 显示全部楼层
调整那些参数,让周期拉长,或者让PWM调整步长变化,都会得到不同的效果的。
 楼主| 小明的同学 发表于 2019-12-23 23:10 | 显示全部楼层
经过测试,发现步长一般不能小于周期的1%,否则就看着不爽,会觉得变化太慢。
捉虫天师 发表于 2019-12-23 23:16 | 显示全部楼层
牛啊,延时肯定不能1us都不延时的。然而这个有时候还真是需要。
所以这就是模拟PWM的局限性啊,除非自己写个延时函数。
然而只要有语句就必然占用时间。矛盾。
捉虫天师 发表于 2019-12-23 23:17 | 显示全部楼层
迫不得已才这么用,不过楼主很棒,写的通俗易懂。
捉虫天师 发表于 2019-12-23 23:18 | 显示全部楼层
楼主共享一下工程吧。
 楼主| 小明的同学 发表于 2019-12-23 23:19 | 显示全部楼层
楼主共享一下工程吧。
GPIO_Output_PWM.rar (389.77 KB, 下载次数: 16)
好,一起研究
yiy 发表于 2019-12-23 23:20 | 显示全部楼层
牛B,我要试试参数是0会怎么样。
