[STM8] stm8 串口中断唤醒
805|2
 楼主| googcheng 发表于 2019-12-30 09:20 | 显示全部楼层 |阅读模式
pc2 临时转外部中断 在调用halt()之前配置
USART_DeInit(USART1);
GPIO_Init(GPIOC, GPIO_Pin_3, GPIO_Mode_Out_PP_Low_Slow);
GPIO_Init(GPIOC, GPIO_Pin_2, GPIO_Mode_In_PU_IT);
RX_EXTI_setup();
EXTI_ClearITPendingBit(EXTI_IT_Pin2);
中断处理函数如下
  1. INTERRUPT_HANDLER(EXTI2_IRQHandler,10)
  3.     /* In order to detect unexpected events during development,
  4.        it is recommended to set a breakpoint on the following instruction.
  5.     */
  6.
  7.     //stop_flag = 1;
  8.     EXTI_ClearITPendingBit(EXTI_IT_Pin2);
  9.
  10.     //GPIO_Init(GPIOC, GPIO_Pin_2, GPIO_Mode_In_PU_No_IT);
  11.     // 1230 change
  12.     GPIOC->CR2 &= (uint8_t)~GPIO_Pin_2;
  13.
  14.     //write_usb_flag();
  15.     FLASH_Unlock(FLASH_MemType_Data);
  16.     //FLASH_EraseByte(0x1000);
  17.     //delay_ms(20);
  18.     FLASH_ProgramByte(0x1000, 0x66);
  19.     record_time_f = 1; // to record time
  20.
  21.     //write_addr
  22.     FLASH_ProgramByte(0x1002, (uint8_t)(write_addr & 0xff));
  23.     FLASH_ProgramByte(0x1003, (write_addr >> 8) & 0xff);
  24.     FLASH_Lock(FLASH_MemType_Data);
  25.
  26.
  27. }
mmuuss586 发表于 2019-12-30 09:47 | 显示全部楼层
感谢分享
 楼主| googcheng 发表于 2019-12-30 10:16 | 显示全部楼层
帮我看看这个代码有没有毛病
