[资料分享] 采用无线振动传感器并支持预防性维护的电机监控参考设计
1954|18
 楼主| dirtwillfly 发表于 2019-12-30 23:31 | 显示全部楼层 |阅读模式
TIDA-01469
描述
This reference design is a low-power wireless subsystem solution that monitors motors using vibration sensing to determine if preventative maintenance is necessary. An FFT of the vibration data can be sent out to another device using either Bluetooth low energy or sub-1GHz wireless protocols. The low power usage and wireless capabilities of this subsystem solution enables it to run on a single coin cell battery, which allows for the device to be small, inexpensive and placed in difficult-to-reach locations. This makes this reference design an ideal alternative to both expensive maintenance that could have been preventatively avoided, as well as larger, more expensive monitors that require a wired connection.
特性
  • Ultra-low-power design resulting in 10-year battery life from single CR2032 coin cell
  • Offers mechanical vibration (20ksps) and termperature sensing
  • Local computation of 2K FFT for vibration spectral analysis
  • Programmable wake-up intervals for motor diagnostics
  • Designed for SimpleLink sub-1GHz and Bluetooth Low Energy Wireless Connectivity LaunchPad (LAUNCHXL-CC1350)
 楼主| dirtwillfly 发表于 2019-12-30 23:51 | 显示全部楼层
采用无线振动传感器并支持预防性维护的电机监控参考设计.pdf (4.13 MB, 下载次数: 3)
TIDA-01469 Gerber.zip (297.03 KB, 下载次数: 2)
 楼主| dirtwillfly 发表于 2019-12-30 23:53 | 显示全部楼层
TIDA-01469 PCB.pdf (730.73 KB, 下载次数: 2)
 楼主| dirtwillfly 发表于 2019-12-30 23:54 | 显示全部楼层
TIDA-01469 Assembly Drawing.pdf (129.94 KB, 下载次数: 2)
 楼主| dirtwillfly 发表于 2019-12-30 23:55 | 显示全部楼层
TIDA-01469 BOM.pdf (65.08 KB, 下载次数: 2)
 楼主| dirtwillfly 发表于 2019-12-30 23:56 | 显示全部楼层
TIDA-01469 Schematic and Block Diagram.pdf (290.52 KB, 下载次数: 2)
 楼主| dirtwillfly 发表于 2019-12-30 23:57 | 显示全部楼层
TIDA-01469 CAD Files.zip (3.66 MB, 下载次数: 2)
nawu 发表于 2020-1-6 10:35 | 显示全部楼层
非常感谢楼主分享
qcliu 发表于 2020-1-6 10:38 | 显示全部楼层
非常感谢楼主分享
tfqi 发表于 2020-1-6 10:42 | 显示全部楼层
非常感谢楼主分享
wiba 发表于 2020-1-6 10:45 | 显示全部楼层
非常感谢楼主分享
zljiu 发表于 2020-1-6 10:49 | 显示全部楼层
非常感谢楼主分享
coshi 发表于 2020-1-6 10:53 | 显示全部楼层
非常感谢楼主分享
aoyi 发表于 2020-1-6 11:08 | 显示全部楼层
非常感谢楼主分享
drer 发表于 2020-1-6 11:12 | 显示全部楼层
非常感谢楼主分享
gwsan 发表于 2020-1-6 11:15 | 显示全部楼层
非常感谢楼主分享
kxsi 发表于 2020-1-6 11:21 | 显示全部楼层
非常感谢楼主分享
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1199
