[FPGA] MIG IP DDR3 例化编译报错求助(ERROR:Place:1333)
1374|3
 楼主| ywqxmut 发表于 2020-2-12 09:26 | 显示全部楼层 |阅读模式
使用IP生成向导生成IP后例化,
用ISE14.7,编译报错如下:
ERROR:Place:1333 - Following IOB's that have input/output programming are locked
   to the bank 1 that does not support such values
   IO Standard: Name = LVDS_25, VREF = NR, VCCO = 2.50, TERM = NONE, DIR =
   BIDIR, DRIVE_STR = NR
   List of locked IOB's:
           u_pic_gen/u_ddr3_intf/u_ddr3/memc5_wrapper_inst/mcb_ui_top_inst/mcb_raw_wrap
   per_inst/mcbx_dram_dqs
   per_inst/mcbx_dram_dqs_n
   per_inst/mcbx_dram_udqs_n
ERROR:Pack:1654 - The timing-driven placement phase encountered an error.
搜过几个类似的帖子,年代久远不说,且没有看到解决的方式。
//=============例化代码
//enable bank5对应的DDR接口 4 fifo 双向
ddr3_intf u_ddr3_intf(
.c5_sys_clk                                (clk_intf ),
.c5_sys_rst_i        (rst_n_sys ),
.c5_p0_cmd_clk                        (clk_intf),
.c5_p0_cmd_en                        (c5_p0_cmd_en),
.c5_p0_cmd_instr                (c5_p0_cmd_instr),
.c5_p0_cmd_bl                        (c5_p0_cmd_bl ),
.c5_p0_cmd_byte_addr (srm_op_addr),
.c5_p0_cmd_empty                (c5_p0_cmd_empty ),
.c5_p0_cmd_full                (c5_p0_cmd_full ),
.c5_p0_wr_clk                        (c5_p0_wr_clk ),
.c5_p0_wr_en                        (c5_p0_wr_en ),
.c5_p0_wr_mask                        (c5_p0_wr_mask ),
.c5_p0_wr_data                        (c5_p0_wr_data ),
.c5_p0_wr_full                        (c5_p0_wr_full ),
.c5_p0_wr_empty                (c5_p0_wr_empty )
//.c5_p0_wr_count                (c5_p0_wr_count ),
//.c5_p0_wr_underrun        (c5_p0_wr_underrun ),
//.c5_p0_wr_error                (c5_p0_wr_error ),
//.c5_p0_rd_clk                        (c5_p0_rd_clk ),
//.c5_p0_rd_en                        (c5_p0_rd_en ),
//.c5_p0_rd_data                        (c5_p0_rd_data ),
//.c5_p0_rd_full                        (c5_p0_rd_full ),
//.c5_p0_rd_empty                (c5_p0_rd_empty ),
//.c5_p0_rd_count                (c5_p0_rd_count ),
//.c5_p0_rd_overflow        (c5_p0_rd_overflow ),
//.c5_p0_rd_error                (c5_p0_rd_error )
//=============例化代码
 楼主| ywqxmut 发表于 2020-2-12 09:32 | 显示全部楼层
论坛内有几个同样问题,有的自行解决没有说明解决经过,有的不了了之,可惜我不能贴url链接整理到该帖
 楼主| ywqxmut 发表于 2020-2-12 10:09 | 显示全部楼层
真正是在线等,挺着急的@GoldSunMonkey @ jameswangchip @ yulunna
打扰一下各位管理员如果知道怎么回事麻烦抽空不吝解答。
 楼主| ywqxmut 发表于 2020-2-12 15:27 | 显示全部楼层
