用STM32控制读取AD7656的转换数据,结果不对~~
8377|7
请教各位大侠,我用FPGA自身晶振分频4KHz信号作为AD7656开始转换的信号,然后当BUSY下降沿触发STM32的中断,进入中断后依照以下时序,先置低CS,然后置低RD,读取AD的数据结果,给AD的输入信号是三路0V,和三路2V直流信号,目前能顺利进入中断,但得到的数据完全不对……
时序图如下:
引脚连接如下:
启动AD转换引脚:ADCLK 由FPGA自身晶振分频给出2K/4K/10K Hz(程序调试时,信号不停的给AD)
AD完成BUSY引脚:与STM32普通引脚PA12相连,用来触发中断
AD片选CS引脚:与STM32的FSMC_NE3相连
AD读RD引脚:与STM32的FSMC_NOE相连
AD设置为并行输出,DB0-DB15与STM32的数据总线相连
程序代码如下:
void main(void)
    SystemInit();  // 晶振初始化 系统寄存器初始化
    FSMC_SRAM_Init(); //FSMC 总线初始化
     EXIT_Configuration();  //外部中断配置
    NVIC_Configuration();  // 嵌套式向量表配置  中断配置需要
     while(1);
void EXTI15_10_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line12) !=RESET)
   u16 i=0;
   EXTI_ClearITPendingBit(EXTI_Line12);  /*中断挂起清除*/
   GPIO_ResetBits(GPIOG,GPIO_Pin_10);   /*片选CS置低*/
   Delay(20);
   for(i=0;i<6;i++)
    GPIO_ResetBits(GPIOD,GPIO_Pin_4);   /*RD置低*/
    Delay(10);
    buf=*(u16 *)(0x68000000+i*1);  /*这行和下一行用来对比*/
    buftemp=*(u16 *)(0x68000000);
    Delay(10);
    GPIO_SetBits(GPIOD,GPIO_Pin_4);
   GPIO_SetBits(GPIOG,GPIO_Pin_10);
   Delay(10);
void FSMC_SRAM_Init(void)
  FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
  FSMC_NORSRAMTimingInitTypeDef  p;
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, ENABLE);  //FSMC总线初始化使能
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOG | RCC_APB2Periph_GPIOE |
                         RCC_APB2Periph_GPIOF | RCC_APB2Periph_AFIO, ENABLE);
/*-- GPIO Configuration ------------------------------------------------------*/
  /* SRAM Data lines configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_8 | GPIO_Pin_9 |
                                GPIO_Pin_10 | GPIO_Pin_14 | GPIO_Pin_15;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 |
                                GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 |
                                GPIO_Pin_15;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
  /* SRAM Address lines configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 |
                                GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_12 | GPIO_Pin_13 |
  GPIO_Init(GPIOF, &GPIO_InitStructure);
                                GPIO_Pin_4 | GPIO_Pin_5;
  GPIO_Init(GPIOG, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12 | GPIO_Pin_13;
  /* NOE and NWE configuration */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  /* NE3 configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
/* GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  GPIO_Init(GPIOD, &GPIO_InitStructure);  */
  /* NBL0, NBL1 configuration */
/*  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
/*-- FSMC Configuration ------------------------------------------------------*/
p.FSMC_AddressSetupTime = 1;
  p.FSMC_AddressHoldTime = 0;
  p.FSMC_DataSetupTime = 2;
  p.FSMC_BusTurnAroundDuration = 0;
  p.FSMC_CLKDivision = 0;
  p.FSMC_DataLatency = 0;
  p.FSMC_AccessMode = FSMC_AccessMode_A;
  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM3;
  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
  FSMC_NORSRAMInitStructure.FSMC_MemoryType = FSMC_MemoryType_SRAM;
  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;
  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode = FSMC_BurstAccessMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;
  //FSMC_NORSRAMInitStructure.FSMC_AsyncWait = FSMC_AsyncWait_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &p;
  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &p;
  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);
  /* Enable FSMC Bank1_SRAM Bank */
  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM3, ENABLE);
void EXIT_Configuration(void)
  EXTI_InitTypeDef EXTI_InitStructure;
  RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;  /*PA12-busy*/
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOA,GPIO_PinSource12);
  EXTI_InitStructure.EXTI_Line = EXTI_Line12;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;   //下降沿为触发
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
void NVIC_Configuration(void)
   NVIC_InitTypeDef NVIC_InitStructure;
   /* Configure one bit for preemption priority */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_3);
  /* Enable the EXTI9_5 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel =  EXTI15_10_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
zylxcu| | 2014-2-17 15:26 | 只看该作者
论坛玩这个的不多??
zylxcu| | 2014-2-21 16:13 | 只看该作者
楼主结贴了吗
zchong| | 2014-2-23 11:22 | 只看该作者
示波器看片选、读信号,如果这些都没有问题,就查一下端口的初始化有没有不对的地方,时钟有没有打开等等。
zylxcu| | 2014-2-28 11:34 | 只看该作者
DMA这块怎么设置,
ly869930903| | 2015-4-19 15:54 | 只看该作者
我想请教个问题,我将编码器产生的10位格雷码,并行接到PB0~9,如何同时读出这个10位格雷码呀
Seves| | 2016-4-3 21:10 | 只看该作者
你有没有用外部存储器?像flash什么的,我看你没写,但是又用了FSMC
gjbb1| | 2016-5-25 10:06 | 只看该作者
是读出的数据有问题,还是不读数据,可以先看一下电压是不是对
