[蓝牙芯片] 【CH579开发板评测】+HT1621
1537|4
 楼主| Cjy_JDxy 发表于 2020-3-22 09:49 | 显示全部楼层 |阅读模式
今天搞了一下HT1621
代码:
#include "CH57x_common.h"
#define Smg_a    0x80
#define Smg_b    0x40
#define Smg_c    0x20
#define Smg_d    0x01
#define Smg_e    0x02
#define Smg_f    0x08
#define Smg_g    0x04
#define Smg_dp   0x10
#define Bmp0Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
#define Bmp1Map          Smg_b | Smg_c
#define Bmp2Map          Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
#define Bmp3Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
#define Bmp4Map          Smg_b | Smg_c | Smg_f | Smg_g
#define Bmp5Map          Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp6Map          Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp8Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define Bmp9Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
#define Bmp7Map          Smg_a | Smg_b | Smg_c
#define BmpAMap          Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
#define BmpBMap          Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpCMap          Smg_a | Smg_d | Smg_e | Smg_f
#define BmpDMap          Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
#define BmpEMap          Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
#define BmpFMap          Smg_a | Smg_e | Smg_f | Smg_g
#define CS_0           GPIOA_ResetBits( GPIO_Pin_15 )
#define CS_1           GPIOA_SetBits( GPIO_Pin_15 )
#define WR_0           GPIOA_ResetBits( GPIO_Pin_14 )
#define WR_1           GPIOA_SetBits( GPIO_Pin_14 )
#define DA_0           GPIOA_ResetBits( GPIO_Pin_13 )
#define DA_1           GPIOA_SetBits( GPIO_Pin_13 )
#define DELAYC  120
const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //?????
void delay(unsigned int x)
        unsigned int i;
        for(i=x;i>0;i--);
void COMMAND_HT1621(unsigned char comm)
        unsigned char i;
        CS_0;
        delay(DELAYC);
        WR_0;
        delay(DELAYC);
        for(i=0;i<3;i++)        //???
                if((0x04<<i)&0x04)  DA_1;    //100
                else                DA_0;
                delay(DELAYC);
                WR_0;
                delay(DELAYC);
                WR_1;
                delay(DELAYC);
        for(i=0;i<9;i++)        //?????
                if((comm<<i)&0x80)  DA_1;    //100
                else                DA_0;
                delay(DELAYC);
                WR_0;
                delay(DELAYC);
                WR_1;
                delay(DELAYC);
        CS_1;
void HT1621_Display(void)
        unsigned char i;
        CS_0;                        //??CS
        delay(DELAYC);
        WR_0;
        delay(DELAYC);
                if((0x05<<i)&0x04)  DA_1;
                else                DA_0;
                delay(DELAYC);
                WR_0;
                delay(DELAYC);
                WR_1;
                delay(DELAYC);
        for(i=0;i<6;i++)                   //???
                if((20<<i)&0x20)    DA_1;  //20?? SEG??
                  else                DA_0;
                delay(DELAYC);
                WR_0;
                delay(DELAYC);
                WR_1;
                delay(DELAYC);
        for(i=0;i<8;i++)                   //???
                if((DpyNum[5]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(DELAYC);
                WR_0;
                delay(DELAYC);
                WR_1;
                delay(DELAYC);
                if((DpyNum[4]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(DELAYC);
                WR_0;
                delay(DELAYC);
                WR_1;
                delay(DELAYC);
                if((DpyNum[3]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(DELAYC);
                WR_0;
                delay(DELAYC);
                WR_1;
                delay(DELAYC);
                if((DpyNum[2]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(DELAYC);
                WR_0;
                delay(DELAYC);
                WR_1;
                delay(DELAYC);
                if((DpyNum[1]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(DELAYC);
                WR_0;
                delay(DELAYC);
                WR_1;
                delay(DELAYC);
                if((DpyNum[0]<<i)&0x80)   DA_1;
                else                      DA_0;
                delay(DELAYC);
                WR_0;
                delay(DELAYC);
                WR_1;
                delay(DELAYC);
        CS_1;                          //??CS
void LCD_Init(void)
        COMMAND_HT1621(0x01);         //SYS EN
        COMMAND_HT1621(0x03);         //LCD ON
        COMMAND_HT1621(0x29);         //4 COM  1/3 BIAS
        HT1621_Display();             //clear screen
int main()
                long int i;
    GPIOB_SetBits( GPIO_Pin_0 );
    GPIOB_ModeCfg( GPIO_Pin_0, GPIO_ModeOut_PP_5mA );
    GPIOA_ModeCfg( GPIO_Pin_13, GPIO_ModeOut_PP_5mA );
    GPIOA_ModeCfg( GPIO_Pin_14, GPIO_ModeOut_PP_5mA );
    GPIOA_ModeCfg( GPIO_Pin_15, GPIO_ModeOut_PP_5mA );
                LCD_Init();
                DpyNum[0] = Smg_a|Smg_d|Smg_g;              //"?"
                DpyNum[1] = SegCode[1];
                DpyNum[2] = SegCode[3];
                DpyNum[3] = SegCode[5];
                DpyNum[4] = SegCode[7];
                DpyNum[5] = SegCode[9];
                HT1621_Display();               //??LCD
    while(1)
                        GPIOB_InverseBits( GPIO_Pin_0 );
                        for(i=0;i<3000000;i++);
效果图:
hanzhen654 发表于 2020-3-22 19:55 | 显示全部楼层
HT1621是什么?什么模块?小液晶吗?
hanzhen654 发表于 2020-3-22 19:56 | 显示全部楼层
带的不是有数码管液晶吗?还加液晶干嘛
 楼主| Cjy_JDxy 发表于 2020-3-22 20:21 | 显示全部楼层
段式液晶。。。。。。。
 楼主| Cjy_JDxy 发表于 2020-3-22 20:23 | 显示全部楼层
带的不是有数码管液晶吗?还加液晶干嘛
两个液晶一起用啊
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
