[DemoCode下载]
PWM的刹车
559|2
antusheng|  楼主 | 2020-3-26 21:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
EC_Mini51_PWM_Trigger_ADC_and_PWM_Brake_V1.00.zip (8.92 MB)
antusheng|  楼主 | 2020-3-26 21:51 | 只看该作者
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 3 $
* $Date: 19/6/25 3:57p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    PWM trigger ADC and PWM brake sample for Mini51DE series MCU
* @note
* Copyright (C) 2019 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "Mini51Series.h"
volatile   uint32_t u32Flag;
void ADC_IRQHandler(void)
    /* Get ADC comparator interrupt flag */
    u32Flag = ADC_GET_INT_FLAG(ADC, ADC_CMP0_INT | ADC_CMP1_INT);
    if (u32Flag & ADC_CMP0_INT)
        printf("Channel 0 input < 0x200\n");
    if (u32Flag & ADC_CMP1_INT)
        printf("Channel 0 input >= 0x200\n");
    ADC_CLR_INT_FLAG(ADC, u32Flag);
void EINT1_IRQHandler(void)
    P55 = 0; /* debug IO */
    printf("INT1");
    P5->ISRC |= 0x04;   /* CLR INT1 interrupt Flag */
    PWM->PFBCON |= PWM_PFBCON_BKF_Msk;  /* CLR Brake Function Flag */
void PWM_IRQHandler(void)
    static uint32_t cnt;
    static uint32_t out;
    /* Channel 2 frequency is 1000Hz, every 1 second enter this IRQ handler 1000 times. */
    if (++cnt == 100)
        if (out)
            PWM_EnableOutput(PWM, BIT2);
        else
            PWM_DisableOutput(PWM, BIT2);
        out ^= 1;
        cnt = 0;
    /* Clear channel 2 period and trigger ADC interrupt flag */
    PWM_ClearPeriodIntFlag(PWM, 2);
    PWM_ClearADCTriggerFlag(PWM, 2, PWM_TRIGGER_ADC_CNTR_IS_CNR);
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable external 12MHz XTAL, internal 22.1184MHz */
    CLK->PWRCON = CLK_PWRCON_XTL12M | CLK_PWRCON_IRC22M_EN_Msk;
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL_STB_Msk | CLK_CLKSTATUS_IRC22M_STB_Msk);
    /* Enable IP clock */
    CLK_EnableModuleClock(UART_MODULE);
    CLK_EnableModuleClock(ADC_MODULE);
    CLK_EnableModuleClock(PWM23_MODULE);
    /* Select IP clock source */
    CLK_SetModuleClock(UART_MODULE, CLK_CLKSEL1_UART_S_XTAL, CLK_CLKDIV_UART(1));
    CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(4));
    CLK_SetModuleClock(PWM23_MODULE, CLK_CLKSEL1_PWM23_S_HCLK, 0);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set P1 multi-function pins for UART RXD, TXD */
    SYS->P0_MFP = SYS_MFP_P00_TXD | SYS_MFP_P01_RXD;
    /* Set P2.4 multi-function pins for PWM Channel 2 */
    SYS->P2_MFP |= SYS_MFP_P24_PWM2;
    /* Set P5.3 to ADC channel 0 input pin */
    SYS->P5_MFP |= SYS_MFP_P53_AIN0;
    /* Analog pin OFFD to prevent leakage */
    P5->OFFD |= (1 << 3) << GPIO_OFFD_OFFD_Pos;
    /* Set P5.5 to GPIO for INT1 debug */
    SYS->P5_MFP |= SYS_MFP_P55_GPIO;
    GPIO_SetMode(P5, BIT5, GPIO_PMD_OUTPUT);
    /* set P5.2 to INT1 mode to use the PWM Brake function */
    SYS->P5_MFP |= SYS_MFP_P52_INT1;
    /* Lock protected registers */
    SYS_LockReg();
    GPIO_SetMode(P5, BIT2, GPIO_PMD_QUASI);
int32_t main(void)
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    SYS_Init();
    /* Init UART to 115200-8n1 for print message */
    UART_Open(UART, 115200);
    printf("\nThis sample code will output PWM channel 2 (pin 24) to trigger ADC channel 0 (pin 41),\n");
    printf("and setting ADC conversion event source to PWM trigger,\n");
    printf("and setting Brake Function event source to INT1 (pin 20),\n");
    printf("the INT1 interrupt event is seting falling trigger,\n");
    printf("so user need use INT1 pin connect to VCC then connect to VSS,\n");
    printf("that well generate brake to stop PWM waveform. ADC also stops conversion.\n");
    printf("**------------------------------------------------------------------------------------**\n");
    /* Enable channel 0 */
    ADC_Open(ADC, 0, 0, 0x01);
    /* Power on ADC */
    ADC_POWER_ON(ADC);
    /* Set ADC trigger source to PWM and trigger delay to 1 HCLK */
    ADC_EnableHWTrigger(ADC, ADC_TRIGGER_BY_PWM, 1);
    /* Enable ADC interrupt */
    ADC_EnableInt(ADC, ADC_ADF_INT);
    /* Clear ADC interrupt */
    /* Configure and enable Comparator 0 to monitor channel 0 input less than 0x200, match count 16 */
    ADC_ENABLE_CMP0(ADC, 0, ADC_CMP_LESS_THAN, 0x200, 16);
    /* Configure and enable Comparator 1 to monitor channel 0 input greater or equal to 0x200, match count 16 */
    ADC_ENABLE_CMP1(ADC, 0, ADC_CMP_GREATER_OR_EQUAL_TO, 0x200, 16);
    /* Enable ADC comparator 0 and 1 interrupt */
    ADC_EnableInt(ADC, ADC_CMP0_INT);
    ADC_EnableInt(ADC, ADC_CMP1_INT);
    NVIC_EnableIRQ(ADC_IRQn);
    /* PWM2 frequency is 1000Hz, duty 50% */
    PWM_ConfigOutputChannel(PWM, 2, 1000, 50);
    PWM_EnableDeadZone(PWM, 2, 200);
    /* Set PWM channel 2 counter matching CNR trigger ADC */
    PWM->TRGCON0 |= PWM_TRGCON0_CNT2TRGEN_Msk;
    PWM_SET_ALIGNED_TYPE(PWM, 2, PWM_CENTER_ALIGNED);
    /* Enable output of PWM channel 2 */
    PWM_EnableOutput(PWM, 1 << 2);
    /* Enable PWM channel 2 period interrupt */
    PWM_EnablePeriodInt(PWM, 2, PWM_PERIOD_INT_MATCH_CNR);
    NVIC_EnableIRQ(PWM_IRQn);
    /* PWM PFBCON: PWMBKO2 Mask */
    PWM->PFBCON |= PWM_PFBCON_PWMBKO2_Msk;
    /* PWM brake Flag clear */
    /* PWM BRKIE */
    PWM->PIER |= PWM_PIER_BRKIE_Msk;
    PWM->PHCHGNXT |= PWM_PHCHGNXT_CE1_Msk;
    /* Comparator 0 as fault break 1 source */
    PWM->PFBCON |= PWM_FB1_EINT1;
    PWM->PFBCON &= ~PWM_PFBCON_CPO1BKEN_Msk;
    /* EN P5.2 INT1 Falling */
    P5->IEN |= 0x04;
    NVIC_EnableIRQ(EINT1_IRQn);
    /* Enable PWM channel 2 counter */
    PWM_Start(PWM, 1 << 2);
    while (1);
/*** (C) COPYRIGHT 2019 Nuvoton Technology Corp. ***/
huangcunxiake| | 2020-3-26 22:31 | 只看该作者
前来观摩学习。
