- /* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved. */
- // Nuvoton Technoledge Corp.
- // Website: http://www.nuvoton.com
- // E-Mail : MicroC-8bit@nuvoton.com
- // Date : Apr/21/2017
- // File Function: N76E003 Timer0/1 Mode2 demo code
- #include "N76E003.h"
- #include "Common.h"
- #include "Delay.h"
- #include "SFR_Macro.h"
- #include "Function_define.h"
- //***************** The Following is in define in Fucntion_define.h ***************************
- //****** Always include Function_define.h call the define you want, detail see main(void) *******
- #if 0
- //#define TIMER0_MODE0_ENABLE TMOD&=0x0F
- //#define TIMER0_MODE1_ENABLE TMOD&=0x0F;TMOD|=0x10
- //#define TIMER0_MODE2_ENABLE TMOD&=0x0F;TMOD|=0x20
- //#define TIMER0_MODE3_ENABLE TMOD&=0x0F;TMOD|=0x3F
- //#define TIMER1_MODE0_ENABLE TMOD&=0xF0
- //#define TIMER1_MODE1_ENABLE TMOD&=0xF0;TMOD|=0x01
- //#define TIMER1_MODE2_ENABLE TMOD&=0xF0;TMOD|=0x02
- //#define TIMER1_MODE3_ENABLE TMOD&=0xF0;TMOD|=0xF3
- #endif
- #if 1
- #define TIMER0_RELOAD_VALUE 50
- #define TIMER1_RELOAD_VALUE 50
- #else
- #define TIMER0_RELOAD_VALUE 250
- #define TIMER1_RELOAD_VALUE 250
- #endif
- * TIMER 0 interrupt subroutine
- void Timer0_ISR (void) interrupt 1 //interrupt address is 0x000B
- P12 = ~P12; // GPIO1 toggle when interrupt
- * TIMER 1 interrupt subroutine
- void Timer1_ISR (void) interrupt 3 //interrupt address is 0x001B
- P03 = ~P03; //P0.3 toggle when interrupt
- * Main function
- void main (void)
- Set_All_GPIO_Quasi_Mode;
- TIMER0_MODE2_ENABLE;
- TIMER1_MODE2_ENABLE;
- TH0 = (256-TIMER0_RELOAD_VALUE); //initial counter values
- TL0 = (256-TIMER0_RELOAD_VALUE);
- TH1 = (256-TIMER1_RELOAD_VALUE);
- TL1 = (256-TIMER1_RELOAD_VALUE);
- set_ET0; //enable Timer0 interrupt
- set_ET1; //enable Timer1 interrupt
- set_EA; //enable interrupts
- set_TR0; //Timer0 run
- set_TR1; //Timer1 run
- while(1);
