[FPGA]
【Intel FPGA】Advanced Synthesis Cookbook
1219|3
Advanced Synthesis Cookbook for  FPGA
链接回复可见
游客,如果您要查看本帖隐藏内容请回复
多种算法的说明和源码(CORDIC,ECC,8B10B,AES......)
如果你对于现有的一些算法(FPGA方向)有一些迷惑或者很难去理解,可以去看看这本由Altera官方出的白皮书,内附各种算法的源代码及代码说明。
其中,各个文件夹下是源代码(Verilog编写),pdf文件为说明文档(全英)。
文档简介:
    The Advanced Synthesis Cookbook is a collection of circuit building blocks and related discussions, and presumes you are familiar with Altera® hardware cells and the Quartus® II software tools. The Stratix® II logic cell is powerful, which helps the synthesis tools achieve good results without hand tuning. The cell features open up opportunities for dramatic hand-crafted “tricks.” These building blocks are intended to demonstrate these tricks.
    For more information about HDL coding styles, refer to the Recommended HDL Coding Styles chapter in volume 1 of the Quartus II Handbook. For more information about Stratix II device architecture, refer to the Stratix II Device Family Data Sheet section in volume 1 of the Stratix II Device Handbook.
   Each section includes a list of example files. Many of these example files contain more than one method of implementation controlled by a parameter. You can use these example files for testing and to better understand the derivation of some of the more complex optimizations. There are also many cases where the ideal implementation depends on the surrounding circuitry. The discussion and comments should help with selection. The example files are available on the Altera website at the following
rongzhai| | 2020-3-31 15:39 | 只看该作者
支持一下楼主
mack12345| | 2020-8-11 15:46 | 只看该作者
不错的
920319444| | 2020-8-14 16:19 | 只看该作者
哇 真不错
