 * [url=home.php?mod=space&uid=288409]@file[/url]     gpio.c
 * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
 * $Revision: 2 $
 * $Date: 15/05/04 3:27p $
 * [url=home.php?mod=space&uid=247401]@brief[/url]    GPIO driver source file
 * @note
 * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include "NUC100Series.h"
/** @addtogroup Standard_Driver Standard Driver
/** @addtogroup GPIO_Driver GPIO Driver
/** @addtogroup GPIO_EXPORTED_FUNCTIONS GPIO Exported Functions
 * @brief       Set GPIO operation mode
 * @param[in]   port        GPIO port. It could be PA, PB, PC, PD, PE or PF.
 * @param[in]   u32PinMask  The single or multiple pins of specified GPIO port.
 *                          It could be BIT0 ~ BIT15 for PA, PB, PC, PD and PE GPIO port.
 *                          It could be BIT0 ~ BIT3 for PF GPIO port.
 * @param[in]   u32Mode     Operation mode. . It could be \n
 *                          GPIO_PMD_INPUT, GPIO_PMD_OUTPUT, GPIO_PMD_OPEN_DRAIN, GPIO_PMD_QUASI.
 * [url=home.php?mod=space&uid=266161]@return[/url]      None
 * [url=home.php?mod=space&uid=1543424]@Details[/url]     This function is used to set specified GPIO operation mode.
void GPIO_SetMode(GPIO_T *port, uint32_t u32PinMask, uint32_t u32Mode)
    uint32_t i;
    for(i = 0; i < GPIO_PIN_MAX; i++)
        if(u32PinMask & (1 << i))
            port->PMD = (port->PMD & ~(0x3 << (i << 1))) | (u32Mode << (i << 1));
 * @brief       Enable GPIO interrupt
 * @param[in]   u32Pin          The pin of specified GPIO port.
 *                              It could be 0 ~ 15 for PA, PB, PC, PD and PE GPIO port.
 *                              It could be 0 ~ 3 for PF GPIO port.
 * @param[in]   u32IntAttribs   The interrupt attribute of specified GPIO pin. It could be \n
 *                              GPIO_INT_RISING, GPIO_INT_FALLING, GPIO_INT_BOTH_EDGE, GPIO_INT_HIGH, GPIO_INT_LOW.
 * @return      None
 * @details     This function is used to enable specified GPIO pin interrupt.
void GPIO_EnableInt(GPIO_T *port, uint32_t u32Pin, uint32_t u32IntAttribs)
    port->IMD |= (((u32IntAttribs >> 24) & 0xFFUL) << u32Pin);
    port->IEN |= ((u32IntAttribs & 0xFFFFFFUL) << u32Pin);
 * @brief       Disable GPIO interrupt
 * @return      None
void GPIO_DisableInt(GPIO_T *port, uint32_t u32Pin)
    port->IMD &= ~(1UL << u32Pin);
    port->IEN &= ~((0x00010001UL) << u32Pin);
/*@}*/ /* end of group GPIO_EXPORTED_FUNCTIONS */
/*@}*/ /* end of group GPIO_Driver */
/*@}*/ /* end of group Device_Driver */
/*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
新版的库函数已经没有这个问题了。
