STM32串口发送多第一个字节
522|1
 楼主| 车水马龙 发表于 2020-4-3 17:35 | 显示全部楼层 |阅读模式
STM32F051调试串口2作为485通讯端口时,发现每次发送都多第一个字节,具体代码:
void UART2_Init()
        GPIO_InitTypeDef  GPIO_InitStructure;
        USART_InitTypeDef USART_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE );
        RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOA, ENABLE);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource2,GPIO_AF_1);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource3,GPIO_AF_1);
        *    USART2_TX -> PA2 , USART2_RX ->    PA3
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
        GPIO_InitStructure.GPIO_PuPd =  GPIO_PuPd_NOPULL;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;          //推挽输出
        GPIO_ResetBits(GPIOA,GPIO_Pin_1);
        USART_InitStructure.USART_BaudRate = 115200;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        USART_Init(USART2, &USART_InitStructure);
        NVIC_SetPriority(USART2_IRQn, 0); /* (4) */
        NVIC_EnableIRQ(USART2_IRQn); /* (5) */
        USART2->CR1 |= ((1<<5)|(1<<4));//打开接收中断和IDLE中断
        USART_Cmd(USART2, ENABLE);
void USART2_Send_byte(uint8_t val)
    USART_SendData(USART2, val);
    while (USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET);    //等待发送完成
void UART2_s_process(volatile uint8_t *buffer, uint8_t len)
    uint8_t i;
    GPIO_SetBits(GPIOA,GPIO_Pin_1);
    delay_ms(2);
    for (i = 0;i < len;i ++)
        USART2_Send_byte(buffer);
调试界面:
第一个字节在波特率9600时是08,波特率115200时是84,大婶们帮忙看下代码部分哪不正常?
香水城 发表于 2020-4-3 19:38 | 显示全部楼层
while(USART_GetFlagStatus(USARTx, USART_FLAG_TC) == RESET);
==> while(USART_GetFlagStatus(USARTx, USART_FLAG_TXE) == RESET); 验证下
