[电源技术资料]
1-4节锂电池充电同步降压 内置mosIC
593|0
General Description
The ZCC6688 is a 3A Li-Ion battery charger. It utilizes
a 500KHz synchronous buck converter topology to
reduce power dissipation during charging. Low power
dissipation, an internal MOSFET allow a physically
small charger that can be embedded in a wide range
of handheld applications. The ZCC6688 includes
complete charge termination circuitry, automatic
recharge and a ±1% 4.2V /8.4V /12.6V /16.8V float
voltage.
Battery charge current, charge timeout and end-of-
charge indication parameters are set with external
components. Additional features include shorted cell
detection; temperature qualified
charging and
overvoltage protection. The ZCC6688 is available in a
low profile ESSOP10 package.
Features
 Input voltage range 4V~22V
 Dynamic input current allocation for maximum
charging rate
 3.0A Maximum Charge Current
 No External MOSFETs and Blocking Diode
Required
 Efficiency up to 90%
 Constant-Current/Constant-Voltage Operation
with Thermal Regulation to Maximize Charge
Rate Without Risk of Overheating
 Optional Battery Temperature Monitoring Before
and During Charge Automatic Sleep Mode for
Low-Power
 Over Current Protection
 Consumption Available in ESSOP10
 RoHS Compliant and 100% Lead (Pb)-Free
ZCC6688 V2.3.pdf (1020.45 KB)
