[STM32N6] 【STM32N6570-DK测评】视频录制与播放
13137|5
 楼主| xhackerustc 发表于 2025-5-11 21:13 | 显示全部楼层 |阅读模式
#申请原创#
  @21小跑堂
STM32N6集成有硬件H264 Encoder,也集成了sdmc控制器,板级设计上又加了tf卡槽,所以自然而然想到摄像头拍摄录制视频存入sd卡,所以笔者很想实现下这个功能。会偷懒的程序员才是好的程序员,ST官方有没有实现了这个功能呢?还真给笔者找到了,在STM32Cube_FW_N6的
  1. Projects/STM32N6570-DK/Applications/VENC/VENC_SDCard/
  2. Projects/STM32N6570-DK/Applications/VENC/VENC_SDCard_ThreadX/
前者是裸机环境,后者为ThreadX RTOS环境,笔者现在对ThreadX不是太感冒,兴趣完全迁移到了zephyr RTOS了,所以就VENC_SDCard吧。可能因STM32N6很新的缘故,这个VENC_SDCard还未来得及加上fatfs的支持,编码好的H264流是当字节流直接存在tf卡上的,无任何文件系统,fatfs的支持可以放TODO List中。
因VENC_SDCard已自包含,笔者不想再架起CubeMX这种大杀器了,直接写了个CMakeLists.txt,内容如下:
  1. set(CMAKE_SYSTEM_NAME Generic)
  2. set(CMAKE_SYSTEM_VERSION 1)
  3. set(CMAKE_TRY_COMPILE_TARGET_TYPE "STATIC_LIBRARY")
  4. cmake_minimum_required(VERSION 3.20)
  5. set(CMAKE_C_COMPILER arm-none-eabi-gcc)
  6. set(CMAKE_CXX_COMPILER arm-none-eabi-g++)
  7. set(CMAKE_ASM_COMPILER arm-none-eabi-gcc)
  8. set(CMAKE_AR arm-none-eabi-ar)
  9. set(CMAKE_OBJCOPY arm-none-eabi-objcopy)
  10. set(CMAKE_OBJDUMP arm-none-eabi-objdump)
  11. set(SIZE arm-none-eabi-size)
  12. set(CMAKE_FIND_ROOT_PATH_MODE_PROGRAM NEVER)
  13. set(CMAKE_FIND_ROOT_PATH_MODE_LIBRARY ONLY)
  14. set(CMAKE_FIND_ROOT_PATH_MODE_INCLUDE ONLY)
  15. set(CMAKE_FIND_ROOT_PATH_MODE_PACKAGE ONLY)
  16. add_compile_options(-mthumb -mcpu=cortex-m55 -mfloat-abi=hard -mfpu=fpv5-d16 -mcmse -fsingle-precision-constant)
  17. add_compile_options(-ffunction-sections -fdata-sections -fno-builtin -fno-common -Wdouble-promotion -Werror -Wno-unused-parameter -Wno-incompatible-pointer-types)
  18. add_compile_options(-O2)
  19. project(stm32n6 C ASM)
  20. set(CMAKE_CXX_STANDARD 11)
  21. set(CMAKE_C_STANDARD 99)
  22. include_directories(Drivers/CMSIS/Include
  23.                     Drivers/CMSIS/Device/ST/STM32N6xx/Include
  24.                     Drivers/STM32N6xx_HAL_Driver/Inc
  25.                     Drivers/BSP/STM32N6570-DK
  26.                     Drivers/BSP/Components/Common
  27.                     Utilities/lcd
  28.                     Drivers/BSP/Components/imx335
  29.                     Middlewares/ST/STM32_ISP_Library/isp/Inc
  30.                     Middlewares/ST/STM32_ISP_Library/evision/Inc
  31.                     Middlewares/Third_Party/VideoEncoder/inc
  32.                     Middlewares/Third_Party/VideoEncoder/source/common
  33.                     Middlewares/Third_Party/VideoEncoder/source/h264
  34.                     Projects/STM32N6570-DK/Applications/VENC/VENC_SDCard/Appli/Inc)
  35. add_definitions(-DSTM32N657xx)
  36. file(GLOB_RECURSE SOURCES
  37.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_cortex.c"
  38.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_xspi.c"
  39.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_dma.c"
  40.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_dma_ex.c"
  41.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_rcc.c"
  42.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_rcc_ex.c"
  43.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_gpio.c"
  44.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_pwr.c"
  45.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_pwr_ex.c"
  46.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal.c"
  47.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_exti.c"
  48.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_uart.c"
  49.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_ltdc.c"
  50.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_dma2d.c"
  51.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_rif.c"
  52.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_jpeg.c"
  53.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_dcmipp.c"
  54.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_tim.c"
  55.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_tim_ex.c"
  56.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_sd.c"
  57.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_ll_venc.c"
  58.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_ll_sdmmc.c"
  59.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_i2c.c"
  60.                 "Drivers/STM32N6xx_HAL_Driver/Src/stm32n6xx_hal_i2c_ex.c"
  61.                 "Drivers/BSP/STM32N6570-DK/stm32n6570_discovery.c"
  62.                 "Drivers/BSP/STM32N6570-DK/stm32n6570_discovery_lcd.c"
  63.                 "Drivers/BSP/STM32N6570-DK/stm32n6570_discovery_sd.c"
  64.                 "Drivers/BSP/STM32N6570-DK/stm32n6570_discovery_camera.c"
  65.                 "Drivers/BSP/STM32N6570-DK/stm32n6570_discovery_bus.c"
  66.                 "Drivers/BSP/Components/imx335/*.c"
  67.                 "Utilities/lcd/stm32_lcd.c"
  68.                 "Middlewares/ST/VideoEncoder_EWL/*.c"
  69.                 "Middlewares/ST/STM32_ISP_Library/isp/Src/isp_algo.c"
  70.                 "Middlewares/ST/STM32_ISP_Library/isp/Src/isp_core.c"
  71.                 "Middlewares/ST/STM32_ISP_Library/isp/Src/isp_services.c"
  72.                 "Middlewares/ST/STM32_ISP_Library/isp/Src/isp_tool_com.c"
  73.                 "Middlewares/ST/STM32_ISP_Library/isp/Src/isp_cmd_parser.c"
  74.                 "Middlewares/Third_Party/VideoEncoder/source/h264/*.c"
  75.                 "Middlewares/Third_Party/VideoEncoder/source/common/*.c"
  76.                 "Projects/STM32N6570-DK/Applications/VENC/VENC_SDCard/Appli/Src/*.c"
  77.                 "Projects/STM32N6570-DK/Applications/VENC/VENC_SDCard/STM32CubeIDE/Appli/Src/*.c"
  78.                 "Projects/STM32N6570-DK/Applications/VENC/VENC_SDCard/STM32CubeIDE/Appli/Startup/startup_stm32n657xx.s"
  79.                 )
  80. set(LINKER_SCRIPT ${CMAKE_SOURCE_DIR}/Projects/STM32N6570-DK/Applications/VENC/VENC_SDCard/STM32CubeIDE/Appli/STM32N657XX_LRUN.ld)
  81. add_link_options(
  82.                 -mthumb -mcpu=cortex-m55 -mfloat-abi=hard -mfpu=fpv5-d16 -mcmse
  83.                 -Wl,--gc-sections,--print-memory-usage,-Map,${PROJECT_NAME}.map
  84.                 --specs=nano.specs
  85.                 --specs=nosys.specs)
  86. add_link_options(-T ${LINKER_SCRIPT})
  87. add_executable(${PROJECT_NAME}.elf ${SOURCES} ${LINKER_SCRIPT})
  88. # target_link_libraries(${PROJECT_NAME}.elf printfloat)
  89. target_link_libraries(${PROJECT_NAME}.elf ${CMAKE_SOURCE_DIR}/Middlewares/ST/STM32_ISP_Library/evision/Lib/libn6-evision-st-ae_gcc.a)
  90. target_link_libraries(${PROJECT_NAME}.elf ${CMAKE_SOURCE_DIR}/Middlewares/ST/STM32_ISP_Library/evision/Lib/libn6-evision-awb_gcc.a)
  91. set(HEX_FILE ${PROJECT_BINARY_DIR}/${PROJECT_NAME}.hex)
  92. set(BIN_FILE ${PROJECT_BINARY_DIR}/${PROJECT_NAME}.bin)
  93. set(LST_FILE ${PROJECT_BINARY_DIR}/${PROJECT_NAME}.lst)
  94. add_custom_command(TARGET ${PROJECT_NAME}.elf POST_BUILD
  95.         COMMAND ${CMAKE_OBJCOPY} -Oihex [        DISCUZ_CODE_467        ]lt;TARGET_FILE:${PROJECT_NAME}.elf> ${HEX_FILE}
  96.         COMMAND ${CMAKE_OBJCOPY} -Obinary [        DISCUZ_CODE_467        ]lt;TARGET_FILE:${PROJECT_NAME}.elf> ${BIN_FILE}
  97.         COMMAND ${CMAKE_OBJDUMP} --all-headers --demangle --disassemble [        DISCUZ_CODE_467        ]lt;TARGET_FILE:${PROJECT_NAME}.elf> > ${LST_FILE}
  98.         COMMAND ${SIZE} --format=berkeley [        DISCUZ_CODE_467        ]lt;TARGET_FILE:${PROJECT_NAME}.elf>
  99. )
充分利用大sram
咱直接把代码加载进sram跑,尽量避免烧录xspi nor flash,这是不是有linux开发那味儿了。不过这么一来有个问题,FSBL有部分初始化code未运行,所以需要把FSBL/Src/system_stm32n6xx_fsbl.c的SystemInit()的代码完全拷贝添加到Appli/Src/system_stm32n6xx_s.c的SystemInit()中。
编译
  1. cmake -B /tmp/build
  2. cmake --build /tmp/build -j8
在/tmp/build/目录下即有stm32n6.bin生成,此文件即我们要加载进sram运行的bin文件。万事具备上酸菜,sorry上openocd
加载到sram运行
一终端执行
  1. openocd/src/openocd -f interface/stlink.cfg -c "transport select dapdirect_swd"  -f target/stm32n6.cfg -c "adapter speed 8000"
另一终端执行
  1. telnet 127.0.0.1 4444
然后在此openocd的telnet命令session下依次执行如下命令
  1. halt
  2. load_image /tmp/build/stm32n6.bin 0x34000400
  3. reg pc 0x34019038
  4. resume
现在LCD应该亮屏并显示摄像头拍到的东西,如图
错误出现与解决
但是如果观察STLINK的虚拟串口的输出,会发现奇怪的错误
What, "error initializing encoder -4"什么意思,难道VENC_SDCard代码有bug?但是VENC_SDCard的README文件明明提到可以运行,甚至怎么从tf卡dump h264数据流步骤都写清楚了。这里又是一个大坑,笔者花了很长时间调试跟踪,最后发现这确实是VENC_SDCard的代码中一个bug,至少对于arm-none-eabi-gcc toolchain来说确实有bug。VENC_SDCard依赖很多中间件,其中之一是VideoEncoder,这个库会用到malloc()函数从堆上分配内存,熟悉arm-none-eabi-gcc toolchain的工程师都知道,其libc是newlibc,它的malloc()实现需要用户提供sbrk()函数,但是我们看下VENC_SDCard给arm-none-eabi-gcc提供的sbrk()函数,它的位置在STM32CubeIDE/Appli/Src/sysmem.c
再看看ld文件,它的位置在STM32CubeIDE/Appli/STM32N657XX_LRUN.ld
这里栈放在了STM32N6的DTCM中,即0x30000000开始的128KB TCM,而STM32N6的secure world的SRAM都位于0x34000000,所以下面这个判断总是成立: 22.jpg
即总会认为堆已经用尽,快要增长到栈中去了,所以总是返回-1, errno被设成了ENOMEM,从而libc的malloc()会失败,于是下面这段代码EWLcalloc()会失败:
于是代码返回H264ENC_MEMORY_ERROR,这个H264ENC_MEMORY_ERROR的值正是-4, 这也就是上面"error initializing encoder -4"的来历。问题出在什么地方,linkscript把栈放在DTCM中,但是sysmem.c为做对应调整,仍然还是用的原来栈在SRAM中的版本。知道了原因修改就很简单了,笔者把STM32CubeIDE/Appli/Src/sysmem.c sbrk()函数修改如下
  1. void *_sbrk(ptrdiff_t incr)
  3.   extern uint8_t _end; /* Symbol defined in the linker script */
  4.   extern uint8_t _estack; /* Symbol defined in the linker script */
  5.   extern uint32_t _Min_Heap_Size; /* Symbol defined in the linker script */
  6.   const uint32_t stack_limit = (uint32_t)&_end + (uint32_t)_Min_Heap_Size;
  7.   const uint8_t *max_heap = (uint8_t *)stack_limit;
  8.   uint8_t *prev_heap_end;
  9.   /* Initialize heap end at first call */
  10.   if (NULL == __sbrk_heap_end)
  11.   {
  12.     __sbrk_heap_end = &_end;
  13.   }
  14.   /* Protect heap from growing into the reserved MSP stack */
  15.   if (__sbrk_heap_end + incr > max_heap)
  16.   {
  17.     errno = ENOMEM;
  18.     return (void *)-1;
  19.   }
  20.   prev_heap_end = __sbrk_heap_end;
  21.   __sbrk_heap_end += incr;
  22.   return (void *)prev_heap_end;
  23. }
再次编译加载到sram运行,一切变得那么丝滑
串口截图
录制结束把tf卡插读卡器接入电脑,运行如下命令读出
  1. dd if=/dev/sdc of=/tmp/dump.bin bs=512 count=25000
这个dump.bin其实已经是正儿八经的H264视频文件,file探测下文件显示:
用mpv等软件也能播放,只是提示无timestamp:
可运行如下命令设置下30帧/s的帧率copy成转成另外一个视频文件:
  1. ffmpeg -f h264 -framerate 30 -i /tmp/dump.bin -c copy /tmp/out.mp4
这个文件再用mpv软件播放已经不抱怨无timestamp了
 楼主| xhackerustc 发表于 2025-5-11 21:18 | 显示全部楼层
笔者发现的STM32Cube_FW_N6这个bug应该还没人报过,所以笔者是第一个发现并给出解决方案的?
tpgf 发表于 2025-5-27 08:33 | 显示全部楼层
为了降低用户的开发难度,开发板提供了配套的软件开发工具包,包括驱动程序、示例代码、开发文档等
mzznqqq 发表于 2025-7-5 02:34 | 显示全部楼层
您好,我在尝试使用STM32N6570-DK录视频,然后我发现官方的例程能够录制视频,但是我实在是不知道怎么将SD卡的数据导出出来,有幸读到了您的这篇文章“【STM32N6570-DK测评】视频录制与播放”,遇到了一些问题,如果您有时间的话,可以请您帮我看一下我出现的问题吗?感激不尽。问题如下:
1.我在运行您文章中的CMakeLists.txt,出现了这样的结果:[100%] Linking C executable stm32n6.elf,而且也成功生成了bin,hex等文件,但是我发现他有报错
            DTCM:        128 KB       128 KB    100.00%
Generating binary, hex and listing files
/bin/sh: 1: /tmp/build/stm32n6.elf: Exec format error
不知道这是否会造成后续的问题
2.我在openocd/src/openocd -f interface/stlink.cfg -c "transport select dapdirect_swd"  -f target/stm32n6.cfg -c "adapter speed 8000"运行这一段代码的时候一直报错,我尝试了很多办法都没能解决,如果有可能的话希望你能帮我看看,这是我运行的命令:openocd -f interface/stlink.cfg -f target/stm32n6x.cfg -c "adapter speed 1000"报错:
xPack Open On-Chip Debugger 0.12.0-01004-g9ea7f3d64-dirty (2023-01-30-15:03)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : auto-selecting first available session transport "hla_swd". To override use 'transport select <transport>'.
Error: The selected transport doesn't support this target
target/stm32n6x.cfg:60: Error:
in procedure 'script'
at file "embedded:startup.tcl", line 28
at file "target/stm32n6x.cfg", line 60
我搜到的信息是说:
openocd版本太低,不支持是stm32n6,我下的是12.0,已经是我能搜到的最新的版本了
我尝试使用stm32h7x.cfg,出现了这样的报错:
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 8000 kHz
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : clock speed 8000 kHz
恳请不吝赐教
mzznqqq 发表于 2025-7-5 02:39 | 显示全部楼层
Ketose 发表于 2025-7-8 15:56 | 显示全部楼层
收一块STM32N6开发板。
