flash SFUD
508|0
 楼主| 冷冻链 发表于 2020-4-9 15:00 | 显示全部楼层 |阅读模式
在学习flash过程中看到这几行代码(拷贝 SFUD demo)
enum {
    SFUD_SST25_DEVICE_INDEX = 0,
#define SFUD_FLASH_DEVICE_TABLE                                                \
    [SFUD_SST25_DEVICE_INDEX] = {.name = "SST25VF016B", .spi.name = "SPI1"},       \
typedef struct {
    char *name;                                  /**< serial flash name */
    size_t index;                                /**< index of flash device information table  @see flash_table */
    sfud_flash_chip chip;                        /**< flash chip information */
    sfud_spi spi;                                /**< SPI device */
    bool init_ok;                                /**< initialize OK flag */
    bool addr_in_4_byte;                         /**< flash is in 4-Byte addressing */
    struct {
        void (*delay)(void);                     /**< every retry's delay */
        size_t times;                            /**< default times for error retry */
    } retry;
    void *user_data;                             /**< some user data */
#ifdef SFUD_USING_QSPI
    sfud_qspi_read_cmd_format read_cmd_format;   /**< fast read cmd format */
#endif
#ifdef SFUD_USING_SFDP
    sfud_sfdp sfdp;                              /**< serial flash discoverable parameters by JEDEC standard */
#endif
} sfud_flash, *sfud_flash_t;
static sfud_flash flash_table[] = SFUD_FLASH_DEVICE_TABLE;
我不明白上述代码中的宏定义,和静态数组,有哪位大神可以帮忙解释一下
