[MCU] MSP432评测7-----TN9
874|9
 楼主| Cjy_JDxy 发表于 2020-4-17 19:25 | 显示全部楼层 |阅读模式
今晚搞了一下TN9(红外体温计模块)
代码:
#include "msp.h"
#define uchar unsigned char
#define uint unsigned int
void ACK_0() { P4->OUT&=~BIT4;}  //
void ACK_1() { P4->OUT|=BIT4;}
#define DATA            (P4IN&0x01)
#define CLOCK           (P4IN&0x04)
float Temp;
float Temp1,Temp2;
unsigned char ReadData[5];
unsigned int a,b;
//????:Delay()
void Delay(unsigned char us)  //5,7,9
  while(--us);
//????:Delayms()
void Delayms(unsigned int ims)
  unsigned int i,j;
    for(i=0;i<ims;i++)
      for(j=0;j<65;j++) { Delay(1); }
void TN_IRACK_EN(void)
        ACK_0();
  Delay(1);
void TN_IRACK_UN(void)
        ACK_1();
  Delay(1);
void InitIO(void)
        P4DIR=0x10;
        P4SEL1=0;
        P4SEL0=0;
        P4REN=0x05;
        P4OUT=0x05;
void TN_ReadData(unsigned char Flag)
        unsigned char i,j,k,BitState=0;
        for(k=0;k<7;k++)
                for(j=0;j<5;j++)
                        for(i=0;i<8;i++)
                                while(1)
                                        if(CLOCK==0)
                                                break;
                                        Delay(1);
                                Delay(1);
                                if(DATA==1)
                                        BitState=1;
                                else
                                        BitState=0;
                                ReadData[j]= ReadData[j]<<1;
                                ReadData[j]= ReadData[j]|BitState;
        Delay(1);
                                while(1)
                                        if(CLOCK==0x04)
                                                break;
                                        Delay(1);
                if(ReadData[0]==Flag)
                        k=8;
        TN_IRACK_UN();
float TN_GetData(unsigned char X)
        //Ack_Clk_Data_init;
  InitIO();
        TN_ReadData(X);
        Temp=(ReadData[1]<<8)|ReadData[2];
        Temp=(float)Temp/16.00-273.15;
        return Temp;
float TN_GetTemp(unsigned char mode)
        float T;
                TN_IRACK_UN();
                TN_IRACK_EN();
                if(mode==0)
                        T=TN_GetData(0x4c);
                else
                        T=TN_GetData(0x66);
        return T;
int main(void)
    volatile uint32_t i;
    WDT_A->CTL = WDT_A_CTL_PW | WDT_A_CTL_HOLD;  // Stop watchdog timer
    // The following code toggles P1.0 port
    P1->DIR |= BIT0 ;                             // Configure P1.0 as output
                InitIO();
    while(1)
        Temp1=TN_GetTemp(0);
        Temp2=TN_GetTemp(1);
        a=((unsigned int)(Temp1*10));
                                b=((unsigned int)(Temp2*10));
        P1->OUT ^= 0x01;
        Delayms(500);
效果图:
a表示体温,b是环境温度。235表示23.5度,214表示21.4度
工程:
21ic小喇叭 发表于 2020-4-20 14:51 | 显示全部楼层
感谢分享,奖励您100家园币
晓伍 发表于 2020-5-9 16:10 | 显示全部楼层
非常感谢楼主分享
八层楼 发表于 2020-5-9 16:11 | 显示全部楼层
楼主的模块种类丰富啊
观海 发表于 2020-5-9 16:11 | 显示全部楼层
我怎么就没时间鼓捣这些东西呢
guanjiaer 发表于 2020-5-9 16:12 | 显示全部楼层
红外体温计 有使用的局限性吗
heimaojingzhang 发表于 2020-5-9 16:12 | 显示全部楼层
测温范围是多少啊
 楼主| Cjy_JDxy 发表于 2020-5-9 16:17 | 显示全部楼层
我怎么就没时间鼓捣这些东西呢
那是你太忙了
 楼主| Cjy_JDxy 发表于 2020-5-9 16:18 | 显示全部楼层
红外体温计 有使用的局限性吗
温度范围小吧,得对着测温物体
 楼主| Cjy_JDxy 发表于 2020-5-9 16:24 | 显示全部楼层
-10----+50
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
