cypress IO口模拟IIC分享
1285|1
 楼主| hedongliang 发表于 2020-4-22 15:08 | 显示全部楼层 |阅读模式
做FCT程序时,需要IO口模拟IIC给自身IIC收发,IO虽然也是双向模式,但没有配置说明,也是弄了好久,分享一下,看宏定义配置就可以了!
#define FCT_SCLK_H                         do{FCT_SCL_Write(1);} while(0)
#define FCT_SCLK_L                         do{FCT_SCL_Write(0);} while(0)
#define FCT_DATA_H                         do{FCT_SDA_Write(1);} while(0)
#define FCT_DATA_L                         do{FCT_SDA_Write(0);} while(0)
#define FCT_DATA_READ                           FCT_SDA_Read()
#define FCT_DATA_IN                                FCT_SDA_SetDriveMode(FCT_SDA_DM_RES_UPDWN)
#define FCT_DATA_OUT                        FCT_SDA_SetDriveMode(FCT_SDA_DM_STRONG)
void fct_iic_Send_Byte(uint8 txd)
        uint8 t;
        FCT_DATA_OUT;
        FCT_SCLK_L;// 拉低时钟开始数据传输
        delay_us(2);
        for(t=0; t<8; t++)
                if((txd&0x80)>>7)
                        FCT_DATA_H;
                else
                        FCT_DATA_L;
                txd<<=1;
                delay_us(2);
                FCT_SCLK_H;
                delay_us(4);
                FCT_SCLK_L;
                delay_us(2);
        delay_us(10);
uint8 fct_iic_Read_Byte_ex(void)
        uint8 n_read_data = 0;
        uint8 n_Kt = 0;
        FCT_SCLK_L;
        FCT_DATA_IN;
        while(n_Kt < 8)
        n_read_data <<= 1;
        FCT_SCLK_H;
        delay_us(5);
        if( FCT_DATA_READ )
            n_read_data |= 0x01;
        else
            n_read_data &= 0xFE;
        FCT_SCLK_L;
        n_Kt++;
        delay_us(5);
    FCT_DATA_OUT;
    FCT_DATA_L;
    delay_us(5);
    FCT_SCLK_H;
    delay_us(5);
        FCT_SCLK_L;
        delay_us(5);
    return n_read_data;
laocuo1142 发表于 2020-8-17 15:20 | 显示全部楼层
学习了
