STM32F103 点亮LED的另一种写法
258|0
冷冻链|  楼主 | 2019-11-1 15:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#ifndef __BSP_LED_
#define __BSP_LED_
#include <MM32x103.h> // 这个换成STM32的库文件就行
#include "type.h"  // 这个文件就是重定义了一些数据类型,博客里面有
#define LED1_RUN_GRP         GPIOC
#define LED1_RUN_IDX          GPIO_Pin_6
#define LED1_RUN_OFF()       GPIO_ResetBits(LED1_RUN_GRP, LED1_RUN_IDX)
#define LED1_RUN_ON()        GPIO_SetBits(LED1_RUN_GRP, LED1_RUN_IDX)
#define LED1_RUN_IS_OFF()  GPIO_ReadOutputDataBit(LED1_RUN_GRP, LED1_RUN_IDX)
#define LED2_RUN_GRP         GPIOA
#define LED2_RUN_IDX          GPIO_Pin_11
#define LED2_RUN_OFF()       GPIO_ResetBits(LED2_RUN_GRP, LED2_RUN_IDX)
#define LED2_RUN_ON()        GPIO_SetBits(LED2_RUN_GRP, LED2_RUN_IDX)
#define LED2_RUN_IS_OFF()  GPIO_ReadOutputDataBit(LED2_RUN_GRP, LED2_RUN_IDX)
#define LED3_RUN_GRP         GPIOA
#define LED3_RUN_IDX          GPIO_Pin_12
#define LED3_RUN_OFF()       GPIO_ResetBits(LED3_RUN_GRP, LED3_RUN_IDX)
#define LED3_RUN_ON()        GPIO_SetBits(LED3_RUN_GRP, LED3_RUN_IDX)
#define LED3_RUN_IS_OFF()  GPIO_ReadOutputDataBit(LED3_RUN_GRP, LED3_RUN_IDX)
#define LED_COUNT   3 // LED个数自己定义
typedef enum
    RED   = 0x04,
    GREEN = 0x02,
    BLUE  = 0x01
} led_t;
typedef struct
    GPIO_TypeDef *GPIOx;
    uint32_t pos;
} led_port_t;
void GPIOConfig(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin, GPIOMode_TypeDef GPIO_Mode);
void LEDConfig((uint8_t value) // value:1/2/4 --- RED GREEN BLUE
void LEDSet(uint8_t value);
void LEDReset(uint8_t value);
void LEDToggle(uint8_t value);
#endif /* __BSP_LED_ */
