51读SD卡复位成功,初始化不成功,请求大家帮忙。
3069|2
 楼主| yjhdddf 发表于 2011-12-15 10:13 | 显示全部楼层 |阅读模式
#include "STC12C5A32S2.H"
#include "string.h"
sbit SD_CS =P2^0; //SD卡片选    输入
sbit SD_DI =P2^1; //SD卡同步数据  输入
sbit SD_CLK=P2^2; //SD卡同步时钟  输入
sbit SD_DO =P2^3; //SD卡同步数据  输出
//函数声明
void delay(unsigned int time); //延时函数
void senddata(char dat);
//延时函数
while(time--);
//串口发送一个字节
void senddata(char dat)   //send a data
   ES = 0;
   SBUF = dat;
   while(!TI);
   TI = 0;
   ES = 1;
//串口初始化
void serialinit() //
   SCON = 0x50;
   BRT = 0xfa;
   AUXR = 0x11;
   AUXR1 = 0x80;
   ES = 1;    //Pemit serial interrupt
   EA = 1;   //Pemit all interrupt
//串口中断函数
void sio_int() interrupt 4
ES=0;
ES=1;
//往SD卡定一字节 www.mcusky.com
void SdWrite(unsigned char  n)
  unsigned char i;
  for(i=8;i;i--)
    SD_CLK=0;
    SD_DI=(n&0x80);
    n<<=1;
    SD_CLK=1;
  SD_DI=1;
//从SD卡读一字节 www.mcusky.com
unsigned char SdRead()
unsigned char n,i;
for(i=8;i;i--)
   SD_CLK=0;
   SD_CLK=1;
   n<<=1;
   if(SD_DO) n|=1;
return n;
//读SD卡响应 www.mcusky.com
unsigned char SdResponse()
  unsigned char i=0,response;
  while(i<=8)
    response=SdRead();
    if(response==0x00)
      break;
    if(response==0x01)
      break;
    i++;
  return response;
void SdCommand(unsigned char command, unsigned long argument, unsigned char CRC)
  SdWrite(command|0x40);
  SdWrite(((unsigned char *)&argument)[0]);
  SdWrite(((unsigned char *)&argument)[1]);
  SdWrite(((unsigned char *)&argument)[2]);
  SdWrite(((unsigned char *)&argument)[3]);
  SdWrite(CRC);
unsigned char SdInit(void)
  int delay=0, trials=0;
  unsigned char i;
  unsigned char response;
  SD_CS=1;
  for(i=0;i<=9;i++)
    SdWrite(0xff);
  SD_CS=0;
  senddata(0);
  //Send Command 0 to put MMC in SPI mode
  SdCommand(0x00,0,0x95);
  response=SdResponse();
  senddata(response);
  if(response!=0x01)
    return 0;
  while(response==0x01)
    SD_CS=1;
    SdWrite(0xff);
    SD_CS=0;
    SdCommand(0x01,0x00ffc000,0xff);
    senddata(response);
  SD_CS=1;
  SdWrite(0xff);
  return 1;
void main()
   int i;
   i=1;
   serialinit();
   i=SdInit(); //SD卡初始化
   senddata(i);
   //for(j=0;j<512;j++)  pbuf[j]=0;
   //SD_Read_Sector(0x00000000,pbuf);
   /* for(j=0;j<512;j++)
     senddata(pbuf[j]);
while(1)
 楼主| yjhdddf 发表于 2011-12-23 15:56 | 显示全部楼层
问题已经解决  SD卡与SDHC卡 初始化不同。
wukunshan 发表于 2011-12-23 17:06 | 显示全部楼层
