确认到 LED 连接在 PA8 和 PD2 引脚上. 因此在工程中main.c(位于Core/Src目录下)文件中增加以下测试代码:
- #define LED0_Pin GPIO_PIN_8
- #define LED0_GPIO_Port GPIOA
- #define LED1_Pin GPIO_PIN_2
- #define LED1_GPIO_Port GPIOD
- #define LED_ON GPIO_PIN_RESET
- #define LED_OFF GPIO_PIN_SET
- * [url=home.php?mod=space&uid=247401]@brief[/url] Init led
- * @retval None
- void led_init(void)
- GPIO_InitTypeDef GPIO_InitStruct = {0};
- /* GPIO Ports Clock Enable */
- __HAL_RCC_GPIOD_CLK_ENABLE();
- __HAL_RCC_GPIOA_CLK_ENABLE();
- /*Configure GPIO pin : LED0_Pin */
- GPIO_InitStruct.Pin = LED0_Pin;
- GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
- GPIO_InitStruct.Pull = GPIO_PULLUP;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
- HAL_GPIO_Init(LED0_GPIO_Port, &GPIO_InitStruct);
- /*Configure GPIO pin : LED1_Pin */
- GPIO_InitStruct.Pin = LED1_Pin;
- HAL_GPIO_Init(LED1_GPIO_Port, &GPIO_InitStruct);
- * @brief The application entry point.
- * @retval int
- int main(void)
- HAL_Init();
- SystemClock_Config();
- MX_GPIO_Init();
- led_init();
- while (1)
- HAL_GPIO_WritePin(LED0_GPIO_Port, LED0_Pin, LED_ON);
- HAL_GPIO_WritePin(LED1_GPIO_Port, LED1_Pin, LED_ON);
- HAL_Delay(200);
- HAL_GPIO_WritePin(LED0_GPIO_Port, LED0_Pin, LED_OFF);
- HAL_GPIO_WritePin(LED1_GPIO_Port, LED1_Pin, LED_OFF);
- HAL_Delay(200);
进行编译, 编译成功后将生成 A1.elf 文件.
