[应用相关]
进不了接收数据的中断
536|16
yinxiangh|  楼主 | 2020-5-13 23:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用169做主机发送数据,然后用5529接收数据,现在发现169在发送数据,但是在5529中怎么也进不了接收数据的中断,上拉电阻也加了
liliang9554| | 2020-5-13 23:24 | 只看该作者
楼主程序可以公开吗?贴程序看下吧,这么说看不出什么原因
wangzsa| | 2020-5-13 23:28 | 只看该作者
STM32 还是模拟iic吧 ,硬件iic不是有bug
juventus9554| | 2020-5-13 23:31 | 只看该作者
楼主如何确认确实已经发送了呢
yinxiangh|  楼主 | 2020-5-13 23:34 | 只看该作者
169主机的代码:#include <msp430.h>/file:///C:\Users\ADMINI~1\AppData\Local\Temp\)QN1UH78VKP2T7)IA]ZM(FW.gifar TXData = 0;
int main (void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P3SEL |= 0x0A;                            // Select I2C pins
  P1OUT |= 0x00;
  U0CTL |= I2C + SYNC;                      // Recommended init procedure
  U0CTL &= ~I2CEN;                          // Recommended init procedure
  I2CTCTL |= I2CSSEL1;                      // SMCLK
  I2CNDAT = 0x01;                           // Write one byte
  I2CSA = 0x0048;                           // Slave Address is 048h
  I2CIE = TXRDYIE;                          // Enable RXRDYIFG interrupt
  U0CTL |= I2CEN;                           // Enable I2C
//  I2CDCTL |=0x00;
  __enable_interrupt();                     // Enable interrupts
  while (1)
    U0CTL |= MST;                           // Master mode
    I2CTCTL |= I2CSTT + I2CSTP + I2CTRX;    // Initiate transfer
    __bis_SR_register(CPUOFF);              // Enter LPM0
// Common ISR for I2C Module
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=USART0TX_VECTOR
__interrupt void I2C_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(USART0TX_VECTOR))) I2C_ISR (void)
#else
#error Compiler not supported!
#endif
     I2CDRB = 0x5A;                         // TX data
     while (I2CBUSY & I2CDCTL);             // I2C ready?
     P1OUT |= 0x01;
     P1DIR |= 0x01;
     __bic_SR_register_on_exit(CPUOFF);     // Clear LPM0
5529从机的代码:
#include <msp430.h>
volatile unsigned char RXData;
int main(void)
  P3SEL |= 0x03;                            // Assign I2C pins to USCI_B0
  P1OUT = 0;
  UCB0CTL1 |= UCSWRST;                      // Enable SW reset
  UCB0CTL0 = UCMODE_3 + UCSYNC;             // I2C Slave, synchronous mode
  UCB0I2COA = 0x48;                         // Own Address is 048h
  UCB0CTL1 &= ~UCSWRST;                     // Clear SW reset, resume operation
  UCB0IE |= UCRXIE;                         // Enable RX interrupt
  while (1)
    __bis_SR_register(LPM0_bits + GIE);     // Enter LPM0, enable interrupts(就停在这里了)
    __no_operation();                       // Set breakpoint >>here<< and read
  }                                         // RXData
// USCI_B0 Data ISR
#pragma vector = USCI_B0_VECTOR
__interrupt void USCI_B0_ISR(void)
void __attribute__ ((interrupt(USCI_B0_VECTOR))) USCI_B0_ISR (void)
#else
#endif
{                                  // Vector 10: RXIFG
    RXData = UCB0RXBUF;                     // Get RX data
    P1DIR |= 0X01;
    P1OUT =0x01;
    __bic_SR_register_on_exit(LPM0_bits);   // Exit LPM0
huwr| | 2020-5-13 23:39 | 只看该作者
是不是 在调试中,还是独立运行中发现的问题?
happy_10| | 2020-5-13 23:42 | 只看该作者
看你的反应,应该是没有进去中断,所以没有退出睡眠。。
wenfen| | 2020-5-13 23:45 | 只看该作者
使用示波器测量一下电平的电压是否稳定。。
tian111| | 2020-5-13 23:48 | 只看该作者
iic的硬件问题不好解决。
songqian17| | 2020-5-13 23:51 | 只看该作者
能够接收到电平变化吗?
shimx| | 2020-5-13 23:55 | 只看该作者
这个不一定是单片机的问题吧。
zwll| | 2020-5-14 20:03 | 只看该作者
能确定有中断发生吗
juventus9554| | 2020-5-14 20:07 | 只看该作者
如果使用单纯的数据接收应该问题不大。
dingy| | 2020-5-14 20:09 | 只看该作者
最好通过单步调试测试一下。
renyaq| | 2020-5-14 20:12 | 只看该作者
单步调试试试IO电平是否变化。。
supernan| | 2020-5-14 20:16 | 只看该作者
单片机不是内置的有上拉电阻吗,
yinxiangh|  楼主 | 2020-5-14 20:19 | 只看该作者
好的,我明天去单位试一下,多谢各位大侠了哈
