- /* Copyright(c) 2016 Nuvoton Technology Corp. All rights reserved. */
- // Nuvoton Technoledge Corp.
- // Website: http://www.nuvoton.com
- // E-Mail : MicroC-8bit@nuvoton.com
- // Date : Apr/21/2016
- // File Function: N76E885 ADC demo code
- #include "N76E003.h"
- #include "SFR_Macro.h"
- #include "Function_define.h"
- #include "Common.h"
- #include "Delay.h"
- //***************** The Following is in define in Fucntion_define.h ***************************
- //****** Always include Function_define.h call the define you want, detail see main(void) *******
- #if 0
- //#define Enable_ADC_BandGap ADCCON0|=SET_BIT3;ADCCON0&=0xF8; //Band-gap 1.22V
- #endif
- double Bandgap_Voltage,VDD_Voltage; //please always use "double" mode for this
- unsigned char xdata ADCdataH[5], ADCdataL[5];
- int ADCsumH=0, ADCsumL=0;
- unsigned char ADCavgH,ADCavgL;
- void READ_BANDGAP()
- UINT8 BandgapHigh,BandgapLow,BandgapMark;
- double Bandgap_Value,Bandgap_Voltage_Temp;
- set_IAPEN;
- IAPCN = READ_UID;
- IAPAL = 0x0d;
- IAPAH = 0x00;
- set_IAPGO;
- BandgapLow = IAPFD;
- BandgapMark = BandgapLow&0xF0;
- if (BandgapMark==0x80)
- BandgapLow = BandgapLow&0x0F;
- IAPAL = 0x0C;
- IAPAH = 0x00;
- set_IAPGO;
- BandgapHigh = IAPFD;
- Bandgap_Value = (BandgapHigh<<4)+BandgapLow;
- Bandgap_Voltage_Temp = Bandgap_Value*3/4;
- Bandgap_Voltage = Bandgap_Voltage_Temp - 33; //the actually banggap voltage value is similar this value.
- if (BandgapMark==0x00)
- IAPAL = 0x0C;
- IAPAH = 0x00;
- set_IAPGO;
- Bandgap_Voltage= Bandgap_Value*3/4;
- if (BandgapMark==0x90)
- IAPAL = 0x0E;
- IAPAH = 0x00;
- set_IAPGO;
- IAPAL = 0x0F;
- IAPAH = 0x00;
- set_IAPGO;
- clr_IAPEN;
- // printf ("\n BG High = %bX",BandgapHigh);
- // printf ("\n BG Low = %bX",BandgapLow);
- // printf ("\n BG ROMMAP = %e",Bandgap_Voltage);
- The main C function. Program execution starts
- here after stack initialization.
- void main (void)
- double bgvalue;
- unsigned int i;
- InitialUART0_Timer1(115200);
- READ_BANDGAP();
- printf ("\n BG ROMMAP = %e",Bandgap_Voltage);
- while (1)
- Enable_ADC_BandGap;
- CKDIV = 0x02; // IMPORTANT!! Modify system clock to 4MHz ,then add the ADC sampling clock base to add the sampling timing.
- for(i=0;i<5;i++) // All following ADC detect timing is 200uS run under 4MHz.
- clr_ADCF;
- set_ADCS;
- while(ADCF == 0);
- ADCdataH[i] = ADCRH;
- ADCdataL[i] = ADCRL;
- CKDIV = 0x00; // After ADC sampling, modify system clock back to 16MHz to run next code.
- Disable_ADC;
- for(i=2;i<5;i++) // use the last 3 times data to make average
- ADCsumH = ADCsumH + ADCdataH[i];
- ADCsumL = ADCsumL + ADCdataL[i];
- ADCavgH = ADCsumH/3;
- ADCavgL = ADCsumL/3;
- bgvalue = (ADCavgH<<4) + ADCavgL;
- VDD_Voltage = (0x1000/bgvalue)*Bandgap_Voltage;
- printf ("\n VDD voltage = %e", VDD_Voltage);
- Timer0_Delay1ms(500);
- ADCsumH = 0;
- ADCsumL = 0;
