外部中断选择重复问题
309|0
 楼主| 石头张 发表于 2019-11-20 18:44 | 显示全部楼层 |阅读模式
我现在做一个东西有用到10个按键,前期在画图时没有考虑到,导致现在按键对应GPIO口在中断时有重复,key1-PB12、key2-PB13、key3-PB14、key4-PD9、key5-PD10、key6-PD11、key7-PD12、key8-PD15、key9-PC6、key10-PA8、key1和key7下面配置中断还对?
void EXTI_KEY1_Config(void)
        EXTI_InitTypeDef EXTI_InitStructure;
        /* config the extiline(PC13) clock and AFIO clock */
        //RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO,ENABLE);
        /* config the NVIC(PB12) */
        NVIC_Configuration();
        /* EXTI line gpio config(PB12) */
        GPIO_InitStructure.GPIO_Pin = PIN_KEY10 ;                       /********KEY1********/
      GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
      GPIO_Init(PORT_KEY10, &GPIO_InitStructure);
        /* EXTI line(PB12) mode config */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOB, GPIO_PinSource12);
  EXTI_InitStructure.EXTI_Line = EXTI_Line12;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
void EXTI_KEY7_Config(void)
                        /* EXTI line gpio config(PD12) */
        GPIO_InitStructure.GPIO_Pin = PIN_KEY4 ;
  GPIO_Init(PORT_KEY4, &GPIO_InitStructure);
        /* EXTI line(PD12) mode config */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOD, GPIO_PinSource12);
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; //
在终端服务子程序中怎么判断?这时怎么判断是哪个按键在作用?
void EXTI15_10_IRQHandler(void)
        if(EXTI_GetITStatus(EXTI_Line12) != RESET) //
                LED1_TOGGLE;
                EXTI_ClearITPendingBit(EXTI_Line12);     //
