[PIC32/SAM] SAM D21Curiosity Nano+KEIL+LED
2906|31
 楼主| Cjy_JDxy 发表于 2020-5-19 07:07 | 显示全部楼层 |阅读模式
板子到了,插上电源,仿真器就显示出来。
今天搞了一下KEIL下点灯程序。工程配置:
代码:
#include "samd21.h"
void SystemInit()
        //do nothing
void LED_Init(void)
        PORT->Group[1].DIRSET.reg = PORT_PB10;
        PORT->Group[1].OUTSET.reg = PORT_PB10;
void LED_ON(void)
        PORT->Group[1].OUTCLR.reg = PORT_PB10;
void LED_OFF(void)
void SysTick_Handler(void)
        if(PORT->Group[1].OUTSET.reg == PORT_PB10)
                LED_ON();
        else
                LED_OFF();
void configure_osc8m(SYSCTRL_OSC8M_Type osc8m)
        osc8m.bit.ENABLE = 1;
        SYSCTRL->OSC8M = osc8m;
void configure_osc8m_8m(void)
        SYSCTRL_OSC8M_Type osc8m;
        osc8m = SYSCTRL->OSC8M;
        osc8m.bit.PRESC = SYSCTRL_OSC8M_PRESC_0_Val;
        osc8m.bit.RUNSTDBY = 0;
        osc8m.bit.ONDEMAND = 1;
        configure_osc8m(osc8m);
void configure_dfll(SYSCTRL_DFLLCTRL_Type dfllctrl, SYSCTRL_DFLLMUL_Type dfllmul, SYSCTRL_DFLLVAL_Type dfllval)
        SYSCTRL->DFLLCTRL.reg = dfllctrl.reg & ~SYSCTRL_DFLLCTRL_ONDEMAND;
        while (!(SYSCTRL->PCLKSR.reg & SYSCTRL_PCLKSR_DFLLRDY)) {
                /* Wait for DFLL sync */
        SYSCTRL->DFLLMUL.reg         = dfllmul.reg;
        SYSCTRL->DFLLVAL.reg         = dfllval.reg;
        dfllctrl.bit.ENABLE = 1;
        /* Write full configuration to DFLL control register */
        SYSCTRL->DFLLCTRL.reg = dfllctrl.reg;
void configure_dfll_open_loop(void)
        SYSCTRL_DFLLCTRL_Type dfllctrl;
        SYSCTRL_DFLLMUL_Type dfllmul;
        SYSCTRL_DFLLVAL_Type dfllval;
        dfllctrl.bit.LLAW                 = 0;
        dfllctrl.bit.STABLE         = 0;
        dfllctrl.bit.QLDIS                 = 0;
        dfllctrl.bit.CCDIS                 = 0;
        dfllctrl.bit.ONDEMAND = 1;
        dfllctrl.bit.MODE                 = 0;
        dfllval.bit.COARSE                 = (*((uint8_t*)(0x806020+7)))>>2;//0x1f / 4; /* Midpoint */
        dfllval.bit.FINE                         = (*((uint32_t*)(0x806020+8))) & 0x3FF;//0xff / 4; /* Midpoint */
        dfllmul.bit.CSTEP                 = 1;
        dfllmul.bit.FSTEP                 = 1;
        dfllmul.bit.MUL                         = 6; /* Multiply 8MHz by 6 to get 48MHz */
        configure_dfll(dfllctrl, dfllmul, dfllval);
        NVMCTRL->CTRLB.bit.RWS = 2;
void configure_gclk(GCLK_GENCTRL_Type genctrl, GCLK_GENDIV_Type gendiv)
        while (GCLK->STATUS.reg & GCLK_STATUS_SYNCBUSY) {
                /* Wait for synchronization */
        /* Select the correct generator */
        GCLK->GENDIV.bit.ID = gendiv.bit.ID;
        /* Write the new generator configuration */
        GCLK->GENDIV  = gendiv;
        genctrl.bit.GENEN = GCLK->GENCTRL.bit.GENEN;
        GCLK->GENCTRL = genctrl;
void configure_gclk_gen_dfll(void)
        /* Change system clock to DFLL */
        GCLK_GENCTRL_Type genctrl;
        GCLK_GENDIV_Type gendiv;
        genctrl.reg = 0;
        gendiv.reg = 0;
        genctrl.bit.ID = GCLK_CLKCTRL_GEN_GCLK0_Val;
        gendiv.bit.ID = GCLK_CLKCTRL_GEN_GCLK0_Val;
        genctrl.bit.SRC = GCLK_SOURCE_DFLL48M;
        genctrl.bit.DIVSEL = 0;
        genctrl.bit.IDC = 0;
        genctrl.bit.OOV = 0;
        genctrl.bit.RUNSTDBY = 0;
        genctrl.bit.OE = 0;
        gendiv.bit.DIV = 0;
        configure_gclk(genctrl, gendiv);
int main(void)
        long int i;
        configure_osc8m_8m();
        configure_dfll_open_loop();
        configure_gclk_gen_dfll();
        LED_Init();
        while(1)
                LED_ON();
                for(i=5000000;i>0;i--);
                LED_OFF();
效果图:
工程:
@ningling_21 :没有,看英文的吧  发表于 2020-5-23 10:07
有没这个芯片的中文手册  发表于 2020-5-23 09:51
@ningling_21 :是啊,搞不懂  发表于 2020-5-23 09:16
这个板子,插针孔怎么不在一条直线上,好像有点歪歪扭扭不好焊  发表于 2020-5-22 22:23
 楼主| Cjy_JDxy 发表于 2020-5-19 08:16 | 显示全部楼层
21小喇叭
CoolSilicon 发表于 2020-5-19 11:04 | 显示全部楼层
花开三朵,各表一枝~~~
优秀啊~
 楼主| Cjy_JDxy 发表于 2020-5-19 11:08 | 显示全部楼层
花开三朵,各表一枝~~~
优秀啊~
谢谢
ningling_21 发表于 2020-5-20 13:39 | 显示全部楼层
KEIL 的哪个版本?
 楼主| Cjy_JDxy 发表于 2020-5-20 13:40 | 显示全部楼层
ningling_21 发表于 2020-5-20 20:05 | 显示全部楼层
里面自带有SAMD21芯片包吗
 楼主| Cjy_JDxy 发表于 2020-5-20 20:06 | 显示全部楼层
里面自带有SAMD21芯片包吗
没有。
kavent 发表于 2020-5-20 21:22 | 显示全部楼层
其实不如直接用 studio7了!通过 START配置,底层基本不用自己写,不要太香! keil好在简洁,可惜   microchip没有花大精力去搞!
ningling_21 发表于 2020-5-20 21:30 | 显示全部楼层
其实不如直接用 studio7了!通过 START配置,底层基本不用自己写,不要太香! keil好在简洁,可惜   microc ...
STUDIO 7 安了几个小时没安上
好吧,不想说啥了!你下载最新的,老的版本安装的时候,联网状态下会自动安装新的,下载需要时间!  发表于 2020-5-25 13:33
ningling_21 发表于 2020-5-23 11:40 | 显示全部楼层
这个原理图好像和板子对不上?
 楼主| Cjy_JDxy 发表于 2020-5-23 11:41 | 显示全部楼层
这个原理图好像和板子对不上?
你从哪儿搞得原理图?
ningling_21 发表于 2020-5-23 11:42 | 显示全部楼层
你从哪儿搞得原理图?
你发的文档里的
 楼主| Cjy_JDxy 发表于 2020-5-23 11:43 | 显示全部楼层
不是吧。
我的这样:
ningling_21 发表于 2020-5-23 13:42 | 显示全部楼层
不是吧。
我的这样:
这个文档在哪找到的,能否发一下
 楼主| Cjy_JDxy 发表于 2020-5-23 13:50 | 显示全部楼层
这个文档在哪找到的,能否发一下
已经发给你了呀。
就是这个,我下载了一下,看了没错。不知道你怎么搞得。
ningling_21 发表于 2020-5-25 21:44 | 显示全部楼层
AVR STUDIO 7 能仿真吗? 还是直接下载看结果?
ningling_21 发表于 2020-5-25 21:53 | 显示全部楼层
已经发给你了呀。
点击DEBUG后显示错误,怎么回事?可以下载,但不能调试
 楼主| Cjy_JDxy 发表于 2020-5-26 08:22 | 显示全部楼层
可以仿真
 楼主| Cjy_JDxy 发表于 2020-5-26 08:24 | 显示全部楼层
我的可以调试呀
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
