串口通讯USART2主函数不能正常运行
381|0
喷水壶|  楼主 | 2019-11-22 16:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
void USART2_Config(void)
        USART_InitTypeDef USART_InitStructure;
        /* config USART2 clock */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
        /* USART2 GPIO config */
   /* Configure USART2 Tx (PA.02) as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Configure USART2 Rx (PA.03) as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP ;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
        /* USART2 mode config */
        USART_InitStructure.USART_BaudRate = 115200;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No ;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
        USART_ITConfig(USART2, USART_IT_TXE, ENABLE);
        USART_Init(USART2, &USART_InitStructure);
  USART_Cmd(USART2, ENABLE);
        USART_ClearFlag(USART2,USART_FLAG_TC);
void USART1_Config(void)
        /* config USART1 clock */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
        /* USART1 GPIO config */
        /* Configure USART1 Tx (PA.09) as alternate function push-pull */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
        /* Configure USART1 Rx (PA.10) as input floating */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
        /* USART1 mode config */
        USART_Init(USART1, &USART_InitStructure);
        USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
        USART_Cmd(USART1, ENABLE);
void NVIC_Configuration(void)
        NVIC_InitTypeDef NVIC_InitStructure;
        /* Configure the NVIC Preemption Priority Bits */
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
        /* Enable the USARTy Interrupt */
        NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;        //我在这里改成USART1 主函数跟中断可以运行,但是USATR2只运行中断,主函数直接跳过。
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
int main(void)
        USART1_Config();
        LED_GPIO_Config();
        USART2_Config();
        NVIC_Configuration();
        //GPIO_ResetBits(GPIOB,GPIO_Pin_5);
while(1)
LED1(ON);
