jtag 出问题了
466|0
 楼主| 追光少年 发表于 2019-11-27 19:16 | 显示全部楼层 |阅读模式
JTAG, TE, AN, ST, pi
jtag info:
DLL: V4.68a, compiled Apr 12 2013 13:26:50
Firmware: jtag ARM ARM compiled Nov 14 2012 22:34:52
Hardware: ARM.00
S/N : 308622870
Feature(s) : RDI,FlashDL,FlashBP,JFlash,GDBFULL
* jtag Info: Could not measure total IR len. TDO is constant high.
* jtag Info: STM32F1xxx: Can not attach to CPU. Trying connect under reset.
* jtag Info: TotalIRLen = 9, IRPrint = 0x0011
* jtag Info: Found Cortex-M3 r1p1, Little endian.
* jtag Info: TPIU fitted.
* jtag Info: FPUnit: 6 code (BP) slots and 2 literal slots
ROMTableAddr = 0xE00FF003
Target info:
Device: STM32F103C8
VTarget = 3.306V
State of Pins:
TCK: 1, TDI: 0, TDO: 0, TMS: 0, TRES: 1, TRST: 1
Hardware-Breakpoints: 6
Software-Breakpoints: 8192
Watchpoints:          4
JTAG speed: 4800 kHz
Full Chip Erase Done.
Programming Done.
Verify OK.
Application running ...
***jtag Error: Bad JTAG communication: Write to IR: Expected 0x1, got 0x0 (TAP Command : 10) @ Off 0x5.
