FATFS文件系统中创建文件失败
980|0
 楼主| 怎么叫都可以 发表于 2018-6-7 11:32 | 显示全部楼层 |阅读模式
大家帮帮忙,使用FSTFS文件系统时创建文件失败原因,感激不尽!具体问题如下如下:
使用SPI驱动SD卡,移植的是FATFS_R0.09文件系统,可以正常读文件中的内容,但是创建文件时失败,返回错误2  FR_INT_ERR。使用电脑打卡SD卡后发现有所要创建的文件存在,但是无法打开,提示“文件或目录损坏且无法读取”
代码如下
        /* Register work area for each volume (Always succeeds regardless of disk status) */
        res = f_mount(0,&fs);
        /* Create new file on the drive 0 */
        res = f_open(&fnew, "0:1.txt", FA_CREATE_ALWAYS | FA_WRITE );
        if ( res == FR_OK )
                res = f_write(&fnew, textFileBuffer, sizeof(textFileBuffer), &bw);
                f_close(&fnew);
        else if(res == FR_EXIST)
                printf("\r\n 文件已经存在 \r\n");
仿真调试发现错误产生的函数为
res = remove_chain(dj.fs, cl);
/* Open or Create a File                                                 */
FRESULT f_open (
        FIL *fp,                        /* Pointer to the blank file object */
        const TCHAR *path,        /* Pointer to the file name */
        BYTE mode                        /* Access mode and file open mode flags */
        FRESULT res;
        DIR dj;
        BYTE *dir;
        DEF_NAMEBUF;
        fp->fs = 0;                        /* Clear file object */
#if !_FS_READONLY
        mode &= FA_READ | FA_WRITE | FA_CREATE_ALWAYS | FA_OPEN_ALWAYS | FA_CREATE_NEW;
        res = chk_mounted(&path, &dj.fs, (BYTE)(mode & ~FA_READ));
#else
        mode &= FA_READ;
        res = chk_mounted(&path, &dj.fs, 0);
#endif
        INIT_BUF(dj);
        if (res == FR_OK)
                res = follow_path(&dj, path);        /* Follow the file path */
        dir = dj.dir;
#if !_FS_READONLY        /* R/W configuration */
        if (res == FR_OK) {
                if (!dir)        /* Current dir itself */
                        res = FR_INVALID_NAME;
#if _FS_SHARE
                else
                        res = chk_lock(&dj, (mode & ~FA_READ) ? 1 : 0);
#endif
        /* Create or Open a file */
        if (mode & (FA_CREATE_ALWAYS | FA_OPEN_ALWAYS | FA_CREATE_NEW)) {
                DWORD dw, cl;
                if (res != FR_OK) {                                        /* No file, create new */
                        if (res == FR_NO_FILE)                        /* There is no file to open, create a new entry */
#if _FS_SHARE
                                res = enq_lock() ? dir_register(&dj) : FR_TOO_MANY_OPEN_FILES;
#else
                                res = dir_register(&dj);
#endif
                        mode |= FA_CREATE_ALWAYS;                /* File is created */
                        dir = dj.dir;                                        /* New entry */
                else {        /* Any object is already existing */
                        if (dir[DIR_Attr] & (AM_RDO | AM_DIR)) {        /* Cannot overwrite it (R/O or DIR) */
                                res = FR_DENIED;
                        } else {
                                if (mode & FA_CREATE_NEW)        /* Cannot create as new file */
                                        res = FR_EXIST;
                if (res == FR_OK && (mode & FA_CREATE_ALWAYS)) {        /* Truncate it if overwrite mode */
                        dw = get_fattime();                                        /* Created time */
                        ST_DWORD(dir+DIR_CrtTime, dw);
                        dir[DIR_Attr] = 0;                                        /* Reset attribute */
                        ST_DWORD(dir+DIR_FileSize, 0);                /* size = 0 */
                        cl = LD_CLUST(dir);                                        /* Get start cluster */
                        ST_CLUST(dir, 0);                                        /* cluster = 0 */
                        dj.fs->wflag = 1;
                        if (cl) {                                                        /* Remove the cluster chain if exist */
                                dw = dj.fs->winsect;
                                res = remove_chain(dj.fs, cl);   //产生  FR_INT_ERR  错误   此处 参数 cl = 0xFFFFFFFF   估计是前面对cl赋值时出错了  但不知什么原因
static
FRESULT remove_chain (
        FATFS *fs,                        /* File system object */
        DWORD clst                        /* Cluster# to remove a chain from */
        FRESULT res;
        DWORD nxt;
#if _USE_ERASE
        DWORD scl = clst, ecl = clst, resion[2];
#endif
        if (clst < 2 || clst >= fs->n_fatent) {        /* Check range */
                res = FR_INT_ERR;
                                if (res == FR_OK) {
                                        dj.fs->last_clust = cl - 1;        /* Reuse the cluster hole */
                                        res = move_window(dj.fs, dw);
        else {        /* Open an existing file */
                if (res == FR_OK) {                                                /* Follow succeeded */
                        if (dir[DIR_Attr] & AM_DIR) {                /* It is a directory */
                                res = FR_NO_FILE;
                        } else {
                                if ((mode & FA_WRITE) && (dir[DIR_Attr] & AM_RDO)) /* R/O violation */
                                        res = FR_DENIED;
        if (res == FR_OK) {
                if (mode & FA_CREATE_ALWAYS)                        /* Set file change flag if created or overwritten */
                        mode |= FA__WRITTEN;
                fp->dir_sect = dj.fs->winsect;                        /* Pointer to the directory entry */
                fp->dir_ptr = dir;
#if _FS_SHARE
                fp->lockid = inc_lock(&dj, (mode & ~FA_READ) ? 1 : 0);
                if (!fp->lockid) res = FR_INT_ERR;
#endif
#else                                /* R/O configuration */
                if (!dir) {                                                /* Current dir itself */
                } else {
                        if (dir[DIR_Attr] & AM_DIR)        /* It is a directory */
                                res = FR_NO_FILE;
#endif
        FREE_BUF();
        if (res == FR_OK) {
                fp->flag = mode;                                        /* File access mode */
                fp->sclust = LD_CLUST(dir);                        /* File start cluster */
                fp->fsize = LD_DWORD(dir+DIR_FileSize);        /* File size */
                fp->fptr = 0;                                                /* File pointer */
                fp->dsect = 0;
#if _USE_FASTSEEK
                fp->cltbl = 0;                                                /* Normal seek mode */
#endif
                fp->fs = dj.fs; fp->id = dj.fs->id;        /* Validate file object */
        LEAVE_FF(dj.fs, res);
