[综合信息] 【华大测评】+开箱点灯
1401|9
 楼主| Cjy_JDxy 发表于 2020-5-31 09:56 | 显示全部楼层 |阅读模式
LED, TI, ni, pi, IO
今天华大开发板到了,开始点灯。
安装支持包
原理图:
源程序:
#include "hc32_ddl.h"
* Local type definitions ('typedef')
* Local pre-processor symbols/macros ('#define')
/* LED0 Port/Pin definition */
#define  LED0_PORT        (PortE)
#define  LED0_PIN         (Pin06)
/* LED1 Port/Pin definition */
#define  LED1_PORT        (PortA)
#define  LED1_PIN         (Pin07)
/* LED2 Port/Pin definition */
#define  LED2_PORT        (PortB)
#define  LED2_PIN         (Pin05)
/* LED3 Port/Pin definition */
#define  LED3_PORT        (PortB)
#define  LED3_PIN         (Pin09)
/* LED0~3 toggle definition */
#define  LED0_TOGGLE()    (PORT_Toggle(LED0_PORT, LED0_PIN))
#define  LED1_TOGGLE()    (PORT_Toggle(LED1_PORT, LED1_PIN))
#define  LED2_TOGGLE()    (PORT_Toggle(LED2_PORT, LED2_PIN))
#define  LED3_TOGGLE()    (PORT_Toggle(LED3_PORT, LED3_PIN))
#define  DLY_MS           (100ul)
* Global variable definitions (declared in header file with 'extern')
* Local function prototypes ('static')
* Local variable definitions ('static')
* Function implementation - global ('extern') and local ('static')
** \brief  Main function of GPIO output
** \param  None
** \retval int32_t Return value, if needed
int32_t main(void)
    stc_port_init_t stcPortInit;
    /* configuration structure initialization */
    MEM_ZERO_STRUCT(stcPortInit);
    stcPortInit.enPinMode = Pin_Mode_Out;
    stcPortInit.enExInt = Enable;
    stcPortInit.enPullUp = Enable;
    /* LED0 Port/Pin initialization */
    PORT_Init(LED0_PORT, LED0_PIN, &stcPortInit);
    /* LED1 Port/Pin initialization */
    PORT_Init(LED1_PORT, LED1_PIN, &stcPortInit);
    /* LED2 Port/Pin initialization */
    PORT_Init(LED2_PORT, LED2_PIN, &stcPortInit);
    /* LED3 Port/Pin initialization */
    PORT_Init(LED3_PORT, LED3_PIN, &stcPortInit);
    while(1)
        LED0_TOGGLE();
        Ddl_Delay1ms(DLY_MS);
        LED1_TOGGLE();
        LED2_TOGGLE();
        LED3_TOGGLE();
        /* de-init if necessary */
        //PORT_DeInit();
* EOF (not truncated)
工程配置:
效果图:
观海 发表于 2020-6-3 15:50 | 显示全部楼层
非常感谢楼主分享
heimaojingzhang 发表于 2020-6-3 15:50 | 显示全部楼层
分享很细致
keaibukelian 发表于 2020-6-3 15:51 | 显示全部楼层
这个包是自己下载还是光盘自带啊
labasi 发表于 2020-6-3 15:51 | 显示全部楼层
非常不错的测评
 楼主| Cjy_JDxy 发表于 2020-6-3 15:52 | 显示全部楼层
这个包是自己下载还是光盘自带啊
自带
guojunhope 发表于 2020-6-8 15:00 | 显示全部楼层
很想知道你看原理图用的什么软件,那个“朗读”很吸引人!
 楼主| Cjy_JDxy 发表于 2020-6-8 15:04 | 显示全部楼层
好像网页版的,默认打开。
神圣雅诗人 发表于 2020-7-26 14:52 | 显示全部楼层
这个多少钱
詹求实 发表于 2020-7-28 22:48 | 显示全部楼层
官方的板子不错,资源很丰富,就是有点丑了,哈哈。
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
