[综合信息]
【华大测评】+串口+AD
1762|14
今天搞了一下串口+AD.
原理图:
插上电源线以后,设备管理器里显示串口7
程序:
#include "hc32_ddl.h"
* Local type definitions ('typedef')
* Local pre-processor symbols/macros ('#define')
* If you remap the mapping between the channel and the pin with the function
* ADC_ChannleRemap, define ADC_CH_REMAP as non-zero, otherwise define as 0.
#define ADC_CH_REMAP                (0u)
/* ADC clock selection definition. */
#define ADC_CLK_PCLK                (1u)
#define ADC_CLK_MPLLQ               (2u)
#define ADC_CLK_UPLLR               (3u)
/* Select PCLK as ADC clock. */
#define ADC_CLK                     (ADC_CLK_UPLLR)
/* ADC1 channel definition for this example. */
#define ADC1_SA_NORMAL_CHANNEL      (ADC1_CH0 | ADC1_CH10)
#define ADC1_SA_AVG_CHANNEL         (ADC1_CH12 | ADC1_CH13)
#define ADC1_SA_CHANNEL             (ADC1_SA_NORMAL_CHANNEL | ADC1_SA_AVG_CHANNEL)
#define ADC1_SA_CHANNEL_COUNT       (4u)
#define ADC1_AVG_CHANNEL            (ADC1_SA_AVG_CHANNEL)
#define ADC1_CHANNEL                (ADC1_SA_CHANNEL)
/* ADC1 channel sampling time.     ADC1_CH0  ADC1_CH10  ADC1_CH12   ADC1_CH13 */
#define ADC1_SA_CHANNEL_SAMPLE_TIME { 0x30,     0x80,      0x50,      0x60 }
/* ADC2 channel definition for this example. */
#define ADC2_SA_NORMAL_CHANNEL      (ADC2_CH0 | ADC2_CH2)
#define ADC2_SA_AVG_CHANNEL         (ADC2_CH5)
#define ADC2_SA_CHANNEL             (ADC2_SA_NORMAL_CHANNEL | ADC2_SA_AVG_CHANNEL)
#define ADC2_SA_CHANNEL_COUNT       (3u)
#define ADC2_AVG_CHANNEL            (ADC2_SA_AVG_CHANNEL)
#define ADC2_CHANNEL                (ADC2_SA_CHANNEL)
/* ADC2 channel sampling time.      ADC2_CH0  ADC2_CH2  ADC2_CH5  */
#define ADC2_SA_CHANNEL_SAMPLE_TIME { 0x60,     0x50,     0x40 }
/* ADC resolution definitions. */
#define ADC_RESOLUTION_8BIT         (8u)
#define ADC_RESOLUTION_10BIT        (10u)
#define ADC_RESOLUTION_12BIT        (12u)
#define ADC1_RESOLUTION             (ADC_RESOLUTION_12BIT)
#define ADC2_RESOLUTION             (ADC_RESOLUTION_10BIT)
/* Scan mode definitions. */
#define ADC1_SCAN_MODE              (AdcMode_SAOnce)
#define ADC2_SCAN_MODE              (AdcMode_SAContinuous)
/* ADC reference voltage. The voltage of pin VREFH. */
#define ADC_VREF                    (3.288f)
/* ADC accuracy. */
#define ADC1_ACCURACY               (1ul << ADC1_RESOLUTION)
/* ADC2 continuous conversion times. */
#define ADC2_CONTINUOUS_TIMES       (3u)
/* Timeout value definitions. */
#define TIMEOUT_MS                  (10u)
* Global variable definitions (declared in header file with 'extern')
* Local function prototypes ('static')
static void SystemClockConfig(void);
static void AdcConfig(void);
static void AdcClockConfig(void);
static void AdcInitConfig(void);
static void AdcChannelConfig(void);
static void AdcSetChannelPinMode(const M4_ADC_TypeDef *ADCx,
                                 uint32_t u32Channel,
                                 en_pin_mode_t enMode);
static void AdcSetPinMode(uint8_t u8AdcPin, en_pin_mode_t enMode);
* Local variable definitions ('static')
static uint16_t m_au16Adc1Value[ADC1_CH_COUNT];
static uint16_t m_au16Adc2Value[ADC2_CH_COUNT];
static stc_clk_sysclk_cfg_t m_stcSysclkCfg =
    /* Default system clock division. */
    .enHclkDiv  = ClkSysclkDiv1,  // Max 168MHz
    .enExclkDiv = ClkSysclkDiv2,  // Max 84MHz
    .enPclk0Div = ClkSysclkDiv1,  // Max 168MHz
    .enPclk1Div = ClkSysclkDiv2,  // Max 84MHz
    .enPclk2Div = ClkSysclkDiv4,  // Max 60MHz
    .enPclk3Div = ClkSysclkDiv4,  // Max 42MHz
    .enPclk4Div = ClkSysclkDiv2,  // Max 84MHz
* Function implementation - global ('extern') and local ('static')
** \brief  Main function.
** \param  None.
** \retval int32_t return value, if needed.
int32_t main(void)
    uint8_t u8Count;
    /* Configuring a new system clock if you need. */
    SystemClockConfig();
    /* Config ADC. */
    AdcConfig();
    /* Config UART for printing. Baud rate 115200. */
    Ddl_UartInit();
    /***************** Configuration end, application start **************/
    /* ADC1 sequence A single scan. */
    /* Start ADC1, wait ADC1 scan converting done, read ADC1 data. */
    ADC_PollingSa(M4_ADC1, m_au16Adc1Value, ADC1_CH_COUNT, TIMEOUT_MS);
    /* ADC2 sequence A continuous scan. */
    u8Count = 0u;
    ADC_StartConvert(M4_ADC2);
    while (u8Count < ADC2_CONTINUOUS_TIMES)
        if (Set == ADC_GetEocFlag(M4_ADC2, ADC_SEQ_A))
            ADC_GetChData(M4_ADC2, ADC2_SA_CHANNEL, m_au16Adc2Value, ADC2_SA_CHANNEL_COUNT);
            ADC_ClrEocFlag(M4_ADC2, ADC_SEQ_A);
            u8Count++;
            // TODO: USE THE m_au16Adc2Value.
     *  DO NOT forget to stop ADC when your mode is
     *  AdcMode_SAContinuous or AdcMode_SAContinuousSBOnce
     *  unless you need.
    ADC_StopConvert(M4_ADC2);
    while (1u)
        /* ADC1 channel 10 maps pin ADC12_IN10 by default. */
        printf("\nADC12_IN10 value %d.", m_au16Adc1Value[10u]);
        printf("\nADC12_IN10 voltage is %.4fV.",
            ((float)m_au16Adc1Value[10u] * ADC_VREF) / (float)ADC1_ACCURACY);
        /* Main loop cycle is 500ms. */
        Ddl_Delay1ms(500u);
** \brief  Configuring a new system clock.
**         System clock frequency: 168MHz.
**         System clock source:    MPLL.
**         MPLL clock source:      XTAL(8MHz).
    stc_clk_xtal_cfg_t stcXtalCfg;
    stc_clk_mpll_cfg_t stcMpllCfg;
    stc_sram_config_t  stcSramConfig;
    MEM_ZERO_STRUCT(stcXtalCfg);
    MEM_ZERO_STRUCT(stcMpllCfg);
    /* Set bus clock division first. */
    CLK_SysClkConfig(&m_stcSysclkCfg);
    /* Switch system clock source to MPLL. */
    /* Use XTAL as MPLL source. */
    stcXtalCfg.enFastStartup = Enable;
    stcXtalCfg.enMode = ClkXtalModeOsc;
    stcXtalCfg.enDrv  = ClkXtalLowDrv;
    CLK_XtalConfig(&stcXtalCfg);
    CLK_XtalCmd(Enable);
    /* Set MPLL out 168MHz. */
    stcMpllCfg.pllmDiv = 1u;
    /* sysclk = 8M / pllmDiv * plln / PllpDiv */
    stcMpllCfg.plln    = 42u;
    stcMpllCfg.PllpDiv = 2u;
    stcMpllCfg.PllqDiv = 16u;
    stcMpllCfg.PllrDiv = 16u;
    CLK_SetPllSource(ClkPllSrcXTAL);
    CLK_MpllConfig(&stcMpllCfg);
    /* Flash read wait cycle setting. */
    EFM_Unlock();
    EFM_SetLatency(EFM_LATENCY_5);
    EFM_Lock();
    /* If the system clock frequency is higher than 100MHz and SRAM1, SRAM2, SRAM3 or Ret_SRAM is used,
       the wait cycle must be set. */
    stcSramConfig.u8SramIdx     = Sram12Idx | Sram3Idx | SramRetIdx;
    stcSramConfig.enSramRC      = SramCycle2;
    stcSramConfig.enSramWC      = SramCycle2;
    stcSramConfig.enSramEccMode = EccMode0;
    stcSramConfig.enSramEccOp   = SramNmi;
    stcSramConfig.enSramPyOp    = SramNmi;
    SRAM_Init(&stcSramConfig);
    CLK_MpllCmd(Enable);
    /* Wait MPLL ready. */
    while(Set != CLK_GetFlagStatus(ClkFlagMPLLRdy))
    /* Set system clock source. */
    CLK_SetSysClkSource(CLKSysSrcMPLL);
** \brief  ADC configuration, including clock configuration, initial configuration
**         and channel configuration.
** \param  None.
** \retval None.
    AdcClockConfig();
    AdcInitConfig();
    AdcChannelConfig();
** \brief  ADC clock configuration.
** \note   1) ADCLK max frequency is 60MHz.
**         2) If PCLK2 and PCLK4 are selected as the ADC clock,
**            the following conditions must be met:
**            a. ADCLK(PCLK2) max 60MHz;
**            b. PCLK4 : ADCLK = 1:1, 2:1, 4:1, 8:1, 1:2, 1:4
#if (ADC_CLK == ADC_CLK_PCLK)
    /* Set bus clock division, depends on the system clock frequency. */
    m_stcSysclkCfg.enPclk2Div = ClkSysclkDiv64;
    m_stcSysclkCfg.enPclk4Div = ClkSysclkDiv16;
    CLK_SetPeriClkSource(ClkPeriSrcPclk);
#elif (ADC_CLK == ADC_CLK_MPLLQ)
    if (CLKSysSrcMPLL == CLK_GetSysClkSource())
         * Configure MPLLQ(same as MPLLP and MPLLR) when you
         * configure MPLL as the system clock.
    else
        /* Set MPLL out 240MHz. */
        /* mpll = 8M / pllmDiv * plln */
        stcMpllCfg.plln    = 30u;
        stcMpllCfg.PllpDiv = 16u;
    CLK_SetPeriClkSource(ClkPeriSrcMpllp);
#elif (ADC_CLK == ADC_CLK_UPLLR)
    stc_clk_upll_cfg_t stcUpllCfg;
    MEM_ZERO_STRUCT(stcUpllCfg);
    /* Use XTAL as UPLL source. */
    /* Set UPLL out 240MHz. */
    stcUpllCfg.pllmDiv = 2u;
    /* upll = 8M(XTAL) / pllmDiv * plln */
    stcUpllCfg.plln    = 60u;
    stcUpllCfg.PllpDiv = 16u;
    stcUpllCfg.PllqDiv = 16u;
    stcUpllCfg.PllrDiv = 16u;
    CLK_UpllConfig(&stcUpllCfg);
    CLK_UpllCmd(Enable);
    CLK_SetPeriClkSource(ClkPeriSrcUpllr);
#endif
** \brief  ADC initial configuration.
    stc_adc_init_t stcAdcInit;
    MEM_ZERO_STRUCT(stcAdcInit);
#if (ADC1_RESOLUTION == ADC_RESOLUTION_8BIT)
    stcAdcInit.enResolution = AdcResolution_8Bit;
#elif (ADC1_RESOLUTION == ADC_RESOLUTION_10BIT)
    stcAdcInit.enResolution = AdcResolution_10Bit;
#else
    stcAdcInit.enResolution = AdcResolution_12Bit;
#endif
    stcAdcInit.enDataAlign  = AdcDataAlign_Right;
    stcAdcInit.enAutoClear  = AdcClren_Disable;
    stcAdcInit.enScanMode   = ADC1_SCAN_MODE;
    /* 1. Enable ADC1. */
    PWC_Fcg3PeriphClockCmd(PWC_FCG3_PERIPH_ADC1, Enable);
    /* 2. Initialize ADC1. */
    ADC_Init(M4_ADC1, &stcAdcInit);
#if (ADC2_RESOLUTION == ADC_RESOLUTION_8BIT)
#elif (ADC2_RESOLUTION == ADC_RESOLUTION_10BIT)
#else
#endif
    stcAdcInit.enScanMode   = ADC2_SCAN_MODE;
    /* 1. Enable ADC2. */
    PWC_Fcg3PeriphClockCmd(PWC_FCG3_PERIPH_ADC2, Enable);
    /* 2. Initialize ADC2. */
    ADC_Init(M4_ADC2, &stcAdcInit);
** \brief  ADC channel configuration.
    stc_adc_ch_cfg_t stcChCfg;
    uint8_t au8Adc1SaSampTime[ADC1_SA_CHANNEL_COUNT] = ADC1_SA_CHANNEL_SAMPLE_TIME;
    uint8_t au8Adc2SaSampTime[ADC2_SA_CHANNEL_COUNT] = ADC2_SA_CHANNEL_SAMPLE_TIME;
    MEM_ZERO_STRUCT(stcChCfg);
    stcChCfg.u32Channel  = ADC1_SA_CHANNEL;
    stcChCfg.u8Sequence  = ADC_SEQ_A;
    stcChCfg.pu8SampTime = au8Adc1SaSampTime;
    /* 1. Set the ADC pin to analog mode. */
    AdcSetChannelPinMode(M4_ADC1, ADC1_CHANNEL, Pin_Mode_Ana);
    /* 2. Add ADC channel. */
    ADC_AddAdcChannel(M4_ADC1, &stcChCfg);
    /* 3. Configure the average channel if you need. */
    ADC_ConfigAvg(M4_ADC1, AdcAvcnt_32);
    /* 4. Add average channel if you need. */
    ADC_AddAvgChannel(M4_ADC1, ADC1_AVG_CHANNEL);
    stcChCfg.u32Channel  = ADC2_SA_CHANNEL;
    stcChCfg.pu8SampTime = au8Adc2SaSampTime;
    AdcSetChannelPinMode(M4_ADC2, ADC2_CHANNEL, Pin_Mode_Ana);
    ADC_AddAdcChannel(M4_ADC2, &stcChCfg);
    ADC_ConfigAvg(M4_ADC2, AdcAvcnt_64);
    ADC_AddAvgChannel(M4_ADC2, ADC2_AVG_CHANNEL);
** \brief  Config the pin which is mapping the channel to analog or digit mode.
    uint8_t u8ChIndex;
#if (ADC_CH_REMAP)
    uint8_t u8AdcPin;
#else
    uint8_t u8ChOffset = 0u;
#endif
    if (M4_ADC1 == ADCx)
        u32Channel &= ADC1_PIN_MASK_ALL;
    else
        u32Channel &= ADC2_PIN_MASK_ALL;
#if (!ADC_CH_REMAP)
        u8ChOffset = 4u;
#endif
    u8ChIndex = 0u;
    while (0u != u32Channel)
        if (u32Channel & 0x1ul)
#if (ADC_CH_REMAP)
            u8AdcPin = ADC_GetChannelPinNum(ADCx, u8ChIndex);
            AdcSetPinMode(u8AdcPin, enMode);
#else
            AdcSetPinMode((u8ChIndex+u8ChOffset), enMode);
#endif
        u32Channel >>= 1u;
        u8ChIndex++;
** \brief  Set an ADC pin as analog input mode or digit mode.
    en_port_t enPort = PortA;
    en_pin_t enPin   = Pin00;
    bool bFlag       = true;
    stc_port_init_t stcPortInit;
    MEM_ZERO_STRUCT(stcPortInit);
    stcPortInit.enPinMode = enMode;
    stcPortInit.enPullUp  = Disable;
    switch (u8AdcPin)
    case ADC1_IN0:
        enPort = PortA;
        enPin  = Pin00;
        break;
    case ADC1_IN1:
        enPort = PortA;
        enPin  = Pin01;
        break;
    case ADC1_IN2:
        enPort = PortA;
        enPin  = Pin02;
        break;
    case ADC1_IN3:
        enPort = PortA;
        enPin  = Pin03;
        break;
    case ADC12_IN4:
        enPort = PortA;
        enPin  = Pin04;
        break;
    case ADC12_IN5:
        enPort = PortA;
        enPin  = Pin05;
        break;
    case ADC12_IN6:
        enPort = PortA;
        enPin  = Pin06;
        break;
    case ADC12_IN7:
        enPort = PortA;
        enPin  = Pin07;
        break;
    case ADC12_IN8:
        enPort = PortB;
        enPin  = Pin00;
        break;
    case ADC12_IN9:
        enPort = PortB;
        enPin  = Pin01;
        break;
    case ADC12_IN10:
        enPort = PortC;
        enPin  = Pin00;
        break;
    case ADC12_IN11:
        enPort = PortC;
        enPin  = Pin01;
        break;
    case ADC1_IN12:
        enPort = PortC;
        enPin  = Pin02;
        break;
    case ADC1_IN13:
        enPort = PortC;
        enPin  = Pin03;
        break;
    case ADC1_IN14:
        enPort = PortC;
        enPin  = Pin04;
        break;
    case ADC1_IN15:
        enPort = PortC;
        enPin  = Pin05;
        break;
    default:
        bFlag = false;
        break;
    if (true == bFlag)
        PORT_Init(enPort, enPin, &stcPortInit);
* EOF (not truncated)
效果图:
caizhiwei| | 2020-6-1 11:32 | 只看该作者
代码用代码格式贴出来更好哦
Cjy_JDxy|  楼主 | 2020-6-1 11:35 | 只看该作者
caizhiwei 发表于 2020-6-1 11:32
代码用代码格式贴出来更好哦
我不知道代码格式怎么用
Cjy_JDxy 2020-6-2 08:45 回复TA
@William1994 :现在我会了
William1994 2020-6-2 08:22 回复TA
楼主假装没有逛过论坛,不会贴代码,所有的东西都是文字的方式。
coshi| | 2020-6-1 16:57 | 只看该作者
非常感谢楼主分享
aoyi| | 2020-6-1 16:58 | 只看该作者
我发现楼主什么都会
drer| | 2020-6-1 16:58 | 只看该作者
采集精度如何
gwsan| | 2020-6-1 16:58 | 只看该作者
多少位的ad啊
kxsi| | 2020-6-1 16:59 | 只看该作者
调试方便吗
Cjy_JDxy|  楼主 | 2020-6-1 17:45 | 只看该作者
aoyi 发表于 2020-6-1 16:58
我发现楼主什么都会
不能那么说
Cjy_JDxy|  楼主 | 2020-6-1 17:47 | 只看该作者
还可以
Cjy_JDxy|  楼主 | 2020-6-1 17:48 | 只看该作者
12位
Cjy_JDxy|  楼主 | 2020-6-1 17:49 | 只看该作者
方便
yljon| | 2020-6-2 09:35 | 只看该作者
也想申请一块板子玩一玩
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
