[DemoCode下载] ML51最低功耗模式演示
1825|31
 楼主| 734774645 发表于 2020-5-31 21:58 | 显示全部楼层 |阅读模式
  1. /*---------------------------------------------------------------------------------------------------------*/
  2. /*        */
  3. /* Copyright(c) 2019 Nuvoton Technology Corp. All rights reserved.                                         */
  4. /*        */
  5. /*---------------------------------------------------------------------------------------------------------*/
  6. //***********************************************************************************************************
  7. //  Website: http://www.nuvoton.com
  8. //  E-Mail : MicroC-8bit@nuvoton.com
  9. //***********************************************************************************************************
  10. //***********************************************************************************************************
  11. //  File Function: ML51 simple GPIO toggle out demo code
  12. //***********************************************************************************************************
  13. #include "ML51.h"
  14. /**
  15. * [url=home.php?mod=space&uid=247401]@brief[/url]       ACMP interrupt subroutine
  16. * @param       None
  17. * [url=home.php?mod=space&uid=266161]@return[/url]      None
  18. * [url=home.php?mod=space&uid=1543424]@Details[/url]
  19. */
  20. /**
  21. * @brief       ACMP negtive input use Bandgap voltage
  22. * @param       None
  23. * @return      None
  24. * @details
  25. */
  26. void WKT_ISR(void) interrupt 17            // Vector [url=home.php?mod=space&uid=72445]@[/url]  0x8B
  27. {
  28.     clr_WKCON_WKTF;
  29.         P14 = 0;
  30. //      _delay_();
  31.       P14 = 1;
  32. //      _delay_();
  33.           P14 = 0;
  34. }
  35. void ACMP_ISR (void) interrupt 23
  36. {
  37.   SFRS = 0x00;
  38.   if ((ACMPSR&SET_BIT2)==SET_BIT2)
  39.   {
  40.     ACMPSR&=CLR_BIT2;
  41.     P14 ^=1;
  42.   }
  43.   else if ((ACMPSR&SET_BIT0)==SET_BIT0)
  44.   {
  45.     ACMPSR&=CLR_BIT0;
  46.     P14 ^=1;
  47.   }
  48. }
  49. void main (void)
  50. {
  51.   unsigned char i;
  52. /* Setting Multi function pin setting for GPIO toggle
  53.    * include gipo.c in Common for GPIO mode setting
  54. */
  55.     MFP_P13_GPIO;
  56.     P13_QUASI_MODE;
  57.     MFP_P14_GPIO;
  58.     P14_QUASI_MODE;
  59.     for(i=0;i<0x05;i++)
  60.     {
  61.       P14 = 0;
  62.       _delay_();
  63.       P14 = 1;
  64.       _delay_();
  65.     }
  66.
  67.     #if 1
  68.     MFP_P23_ACMP0_P1;
  69.     MFP_P24_ACMP0_N0;
  70.     MFP_P41_ACMP0_O;
  71. ///* ACMP VBG intial
  72. ///* Initial ACMP0 P2.3 as positive and Bandgap as negetive input, Output to P4.1 */
  73. //    ACMP_Open(ACMP0, ACMP_CTL_POSSEL_P1, ACMP_CTL_NEGSEL_VBG,0, ACMP_CTL_ACMP0_OUTPUT_ENABLE, ACMP_CTL_HYSTERESIS_ENABLE);
  74. ///* Initial ACMP interrupt enable, wakeup function dis ble.*/
  75. //    ACMP_INTEnable(ACMP0, ACMP_CTL_WAKEUP_ENABLE, ACMP_CTL_INT_ENABLE);
  76.
  77. /* ACMP VREF intial
  78.    * include acmp.c in Library for ACMP initial and interrupt setting. */
  79. //    VREF_Open(2);
  80. /* Initial ACMP0 P2.3 as positive and Bandgap as negetive input, Output to P4.1 */
  81.     ACMP_Open(ACMP0, ACMP_CTL_POSSEL_P1, ACMP_CTL_NEGSEL_CRV, ACMP_CTL_CRV_VREF, ACMP_CTL_ACMP0_OUTPUT_ENABLE, ACMP_CTL_HYSTERESIS_ENABLE);
  82. /* CRV Value = CRV source voltage * (2+CRV1CTL)/12. so for this example = VREF/2.*/
  83.     ACMP_CRVValue(ACMP0, 4);
  84. /* Initial ACMP interrupt enable, wakeup function disable.*/
  85.     ACMP_INTEnable(ACMP0, ACMP_CTL_WAKEUP_ENABLE, ACMP_CTL_INT_ENABLE);
  86.
  87.     WKT_Open(38400,256,100);
  88.     WKT_Interrupt(Enable);
  89.
  90.     ENABLE_GLOBAL_INTERRUPT;
  91.     #endif
  92. //    BOD_Enable(VBOD24,BOD_RESET_ENABLE);
  93. //    BOD_LowPower_Enable(LPBOD_MODE2,BOD_FT_ENABLE);
  94.     LVR_Enable();
  95.     BOD_Disable();
  96.     POR_Disable();
  97. //    LVR_Disable();
  98. //    LowPowerLVR_Enable();
  99. //    BIAS_ALL_DIGITAL();
  100.     SFRS = 1;
  101.     CKDIV = 0x0c;
  102. /* Enable Low power run mode */
  103. //  FsysSelect(FSYS_LIRC);
  104. //  set_PCON_LPR;
  105.   //set_PCON_IDLE;
  106.   //set_PCON_PD;
  107.     while(1)
  108.     {
  109.     //      P14 = 0;
  110.     //      P14 = 1;
  111.       set_PCON_PD;
  112.     }
  113.
  114. }
 楼主| 734774645 发表于 2020-5-31 21:59 | 显示全部楼层
Low power run mode use low power LVR function, the lowest run mode enable
598330983 发表于 2020-5-31 22:05 | 显示全部楼层
不错不错,受教了。
xinxianshi 发表于 2020-5-31 22:40 | 显示全部楼层
低功耗系列绝非浪得虚名
zhuotuzi 发表于 2020-5-31 22:48 | 显示全部楼层
试试最低有多低。
gejigeji521 发表于 2020-5-31 23:35 来自手机 | 显示全部楼层
低功耗系列必须好用
xuanhuanzi 发表于 2020-6-2 23:33 | 显示全部楼层
低功耗学习的好资料
gygp 发表于 2020-6-3 15:17 | 显示全部楼层
在哪里演示的呢?
chenci2013 发表于 2020-6-3 15:18 | 显示全部楼层
进入掉电模式吗
biechedan 发表于 2020-6-3 15:18 | 显示全部楼层
正常运行模式典型功耗可达 80 uA/MHz
wangdezhi 发表于 2020-6-3 15:18 | 显示全部楼层
isseed 发表于 2020-6-3 15:19 | 显示全部楼层
这个是官网的代码吗
xietingfeng 发表于 2020-6-3 15:19 | 显示全部楼层
suzhanhua 发表于 2020-6-3 15:19 | 显示全部楼层
系列最高速可达 24 MHz啊
mituzu 发表于 2020-6-3 15:19 | 显示全部楼层
新唐低功耗51单片机
hellosdc 发表于 2020-6-3 15:20 | 显示全部楼层
用的就是官方例程
uiint 发表于 2020-6-3 15:20 | 显示全部楼层
这个完整的工程文件呢
isseed 发表于 2020-6-3 15:21 | 显示全部楼层
怎么知道是否进入了这个低功耗的模式呢
wangdezhi 发表于 2020-6-3 15:21 | 显示全部楼层
谢谢楼主的资料了。
xietingfeng 发表于 2020-6-3 15:21 | 显示全部楼层
谢谢楼主的资料了。
