[MCU] 软件i2c读多字节只能读出第一个字节
3498|26
 楼主| qinchxiong 发表于 2020-6-11 14:22 | 显示全部楼层
ayb_ice 发表于 2020-6-11 14:11
可以忽略这个应答的结果,直接往下读试试
读完一个字节,我发出ack(0),但下一个字节读到的是0,实际是slave没有再送出下一个字节,波形图上最后8个clk,SDA都是低
ayb_ice 发表于 2020-6-11 14:29 | 显示全部楼层
读完一个字节,我发出ack(0),但下一个字节读到的是0,实际是slave没有再送出下一个字节,波形图上最后8 ...
我改下,100% OK,
#include "i2c_master.h"
#define         SCL_H         I2C1_SCL_Write(1)
#define         SCL_L         I2C1_SCL_Write(0)
#define         SDA_H         I2C1_SDA_Write(1)
#define         SDA_L         I2C1_SDA_Write(0)
#define I2C_SDA_READ  I2C1_SDA_Read()
#define     IO_DELAY        3
#define     IO_DELAY_2X     4
#define     IO_DELAY_3X     8
#define     IO_DELAY_4X     10
#define     IO_DELAY_5X     12
#define SDA_INPUT()                SDA_H
uint8_t IC7211_WriteI2C_Byte(uint8_t reg,uint8_t data)
      return i2c_write_byte(IC7211_I2C_ADDR,reg,&data,1);
uint8_t IC7211_WriteI2C_NByte(uint8_t reg,uint8_t data,uint8_t size)
      return i2c_write_byte(IC7211_I2C_ADDR,reg,&data,size);
uint8_t IC7211_ReadI2C_Byte(uint8_t reg)
      uint8_t data;
      i2c_read_byte(IC7211_I2C_ADDR,reg,&data,1);
      return data;
uint8_t IC7211_ReadI2C_NByte(uint8_t reg,uint8_t *buffer, uint32_t size)
      i2c_read_byte(IC7211_I2C_ADDR,reg, buffer, size);
      return 1;
uint8_t ic7211_check_id(void)
        uint32_t nChipID;
        uint32_t fw_byte_count;
        char output[50];
        uint8_t buffer[2]={0x0};
        uint32_t ID;
        IC7211_WriteI2C_Byte(0xFF, 0x80);
        IC7211_WriteI2C_Byte(0xEE, 0x01);//IIC Enable
        IC7211_WriteI2C_Byte(0xff, 0xa0);
//        uint8_t bA000 = IC7211_ReadI2C_Byte(0x00);
//        uint8_t bA001 = IC7211_ReadI2C_Byte(0x01);
//        nChipID = ((bA000 << 8) | bA001);
        IC7211_ReadI2C_NByte(0x00,buffer,2);
        memset(output,0,sizeof(output));
        sprintf(output,  "\r\n ChipID=0x%x|buffer=0x%x 0x%x|ID=0x%x  \r\n", nChipID,buffer[0],buffer[1],(buffer[0]<<8)|buffer[1]);
        UART_UartPutString((const char*)output);
        return nChipID == 0x1605;
static void start_i2c(void)
        SDA_H;
        CyDelayUs(IO_DELAY);
        SCL_H;
        CyDelayUs(IO_DELAY_5X);
        SDA_L;
        CyDelayUs(IO_DELAY_3X);
        SCL_L;
        CyDelayUs(IO_DELAY_2X);
static void stop_i2c(void)
        SDA_L;
        SCL_H;
        SDA_H;
static uint8_t read_ack(void)                        //接收应答信号函数
        uint8_t ack;                                    //定义一个位变量,来暂存应答状态。
                SDA_INPUT();
        SCL_H;                                            //拉高时钟线。
        ack = I2C_SDA_READ;                                //读取应答信号的状态。
        SCL_L;                                            //拉低时钟线。
        return ack;                                        //返回应答信号的状态,0表示应答,1表示非应答。
static uint8_t wait_read_ack(void)
        if (!read_ack())
                return 1;
        return 0;
static uint8_t  i2c_send_byte(uint8_t data)
        uint8_t bit_cnt;
            uint8_t size = 0;
        for(bit_cnt = 0; bit_cnt < 8; bit_cnt++)
                if((data<<bit_cnt) & 0x80)
                        SDA_H;
                else
                        SDA_L;
                SCL_H;
                SCL_L;
    //释放SDA总线,等待从设备应答
        if(wait_read_ack() != 0)
                size = 0;
        else
                size = 1;
            return size;
static void ack_i2c(uint8_t a)
        if(a == 0)
                SDA_L;
        else
                SDA_H;
        SCL_H;
        SCL_L;
static uint8_t  recv_byte(void)
        uint8_t retc = 0;
        uint8_t bit_cnt;
//CyDelayUs(IO_DELAY_4X);
        SDA_INPUT();
        for (bit_cnt = 0; bit_cnt < 8; bit_cnt++)
                SCL_H;
                retc = retc<<1;
                if (I2C_SDA_READ != 0)
                        retc = retc | 0x1;
                SCL_L;
        return retc;
uint8_t i2c_write_byte(uint8_t slave, uint8_t sub_addr, uint8_t *buffer, uint8_t len)
        uint8_t i;
           uint8_t size;
        if(buffer == NULL || len == 0)
            return 0;
        start_i2c();
        size = i2c_send_byte(slave);
        if(size == 0)
             stop_i2c();
             return  size;
        size = i2c_send_byte(sub_addr);
        if(size == 0)
             stop_i2c();
             return size;
        for(i = 0; i < len; i++)
             size = i2c_send_byte(*buffer);
             if(size == 0)
                 stop_i2c();
                 return  size;
             buffer++;
        stop_i2c();
        return len;
uint8_t i2c_read_byte(uint8_t slave, uint8_t sub_addr, uint8_t *buffer, uint8_t len)
        uint8_t i;
        uint8_t size;
        uint8_t output[50];
            return 0;
        start_i2c();
        if(size == 0)
             stop_i2c();
             *buffer = 0x00;
             return size;
        if (size == 0)
             stop_i2c();
             *buffer = 0x00;
             return  size;
        start_i2c();
        size = i2c_send_byte(slave+1);
        if (size == 0)
              stop_i2c();
              *buffer = 0x00;
              return  size;
        for (i = 0; i < len - 1; i++)
              *buffer = recv_byte();
              ack_i2c(0);
              buffer++;
        ack_i2c(1);
        stop_i2c();
        return  len;
 楼主| qinchxiong 发表于 2020-6-11 14:38 | 显示全部楼层
可以忽略这个应答的结果,直接往下读试试
我试一下你的代码
 楼主| qinchxiong 发表于 2020-6-11 15:17 | 显示全部楼层
我改下,100% OK,
现在可以了,根本原因是那2句SDA_INPUT, 如你所说需要先输出1,问题解决了,感谢!准双向口要做输入口时,需要先写1
ayb_ice 发表于 2020-6-11 15:22 | 显示全部楼层
现在可以了,根本原因是那2句SDA_INPUT, 如你所说需要先输出1,问题解决了,感谢!准双向口要做输入口时, ...
我早提醒你了,你没听
 楼主| qinchxiong 发表于 2020-6-11 15:47 | 显示全部楼层
我早提醒你了,你没听
之前有点彷徨,我想到了这里,昨晚网上查资料动态修改io方向,看别人讨论要修改寄存器,所以在官网下载了文档研究,结果打不开,但实际上写1就可以设置为输入模式了,另外read 单字节没有问题,所以SDA的方向配置比较模糊,这个平台不是太熟悉。总之很感谢你!
红心J 发表于 2020-6-12 15:00 | 显示全部楼层
       uint8_t ack = 1;
可定不可以多次发时钟;时钟高电平时,检测ACK,若未检测到,就连续检测,直到检测到,才将SCL拉低,完成ACK检测时序,或者规定个时延检测不到时认为出错,进行出错处理。
