STM32 USB虚拟串口上传数据失败
2678|1
saystar|  楼主 | 2011-12-21 16:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用的是万利的板,我试着收到数据后发回主机,可是主机收不到,奇怪的是事实上buffer里是有数的,我试着加入按键主动返回数据,结果是把之前想返回的数和按键反馈得数一起发回来了,当USB发给板子数据后就回不来,按键响应OK。这个问题烦恼很久了可是查不到答案,那位有类似经验帮忙一下啊?
代码如下:
main程式:
while (1)
    if ((count_out != 0) && (bDeviceState == CONFIGURED))
      datalen=count_out;
      for(i=0;i<=count_out;i++){mybuffer[i]=buffer_out[i];}
      Mydata_To_USB_Send_Data(&mybuffer[0],datalen);
      count_out = 0;
发数据:
void Mydata_To_USB_Send_Data(u8* data_buffer, u8 Nb_bytes){
  UserToPMABufferCopy(data_buffer, ENDP1_TXADDR, Nb_bytes);
  SetEPTxCount(ENDP1, Nb_bytes);
  SetEPTxValid(ENDP1);
按键就没问题:
if ((JoyState() != 0))
      mykey=JoyState();
      while((JoyState() != 0));
        mybuffer[0]=mykey;
        Mydata_To_USB_Send_Data(&mybuffer[0],1);
saystar|  楼主 | 2011-12-21 17:09 | 只看该作者
配置函数(我把能设的都设了)
void Set_System(void)
  /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration -----------------------------*/
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if (HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* ADCCLK = PCLK2/4 */
    RCC_ADCCLKConfig(RCC_PCLK2_Div4);
    /* PLLCLK = 4MHz * 14 = 56 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while (RCC_GetSYSCLKSource() != 0x08)
  /* Enable GPIOA, GPIOD and USART1 clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |RCC_APB2Periph_GPIOC
         | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO
                         | RCC_APB2Periph_USART1, ENABLE);
  /* TIM2 clocks enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  /* Enable USB_DISCONNECT GPIO clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIO_DISCONNECT, ENABLE);
/* Enable peripheral clocks --------------------------------------------------*/
  /* Enable DMA clock */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  /* Enable ADC1 and GPIOC clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOC, ENABLE);
  /* Configure USB pull-up pin */
  GPIO_InitStructure.GPIO_Pin = USB_DISCONNECT_PIN;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  GPIO_Init(USB_DISCONNECT, &GPIO_InitStructure);
  /* Configure USART1 Rx (PA.10) as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /* Configure USART1 Tx (PA.09) as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  /* Configure PC.04 -- PC.11 as Output push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5 |GPIO_Pin_6 | GPIO_Pin_7
        | GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
    /* Configure PE.00 -- PE.15 as Output push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
  /* Configure the JoyStick IOs */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
    /* Configure PC.00 (ADC Channel10) as analog input -------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  GPIO_InitStructure.GPIO_Pin = DEV_RESET|DEV_PWRDN;
  GPIO_Init(PORT_RESETPWDN, &GPIO_InitStructure);
个人签名:生在中国又卒于中国,真是祸不单行啊!
19
