硬件仿真全速急停
732|0
 楼主| 冰糖炖雪梨 发表于 2018-6-29 14:46 | 显示全部楼层 |阅读模式
/*Include---------------------------*/
#include"stm32f10x_lib.h"                //包含所有的头文件
#include<stdio.h>
//----------------函数声明--------------------
void Delay_MS(u16 dly);
void RCC_Configuration(void);
void GPIO_Configuration(void);
void USART1_Configuration(void);
void SYSTICK_Configuration(void);
* Function Name  : main
* Description    : Main program.
* Input          : None
* Output         : None
* Return         : None
int main(void)
        #ifdef DEBUG
        debug();
        #endif
        u8 sec,min;
        u16 RxData;
        //u8 ID_num[12];
        //u16  data;
        //------------初始化------------
        RCC_Configuration();
        SYSTICK_Configuration();
        GPIO_Configuration();
        USART1_Configuration();
        sec=20;
        min=1;
        /*        printf("
The ID:
                for(i=0;i<12;i++)
                        ID_num = *(u8 *)(0x1FFFF7E9+i);
                        printf("%x",ID_num);
                //ID  是否等于 ffd3e4324b38388127143ff  如果等于置标志flag=1
        printf("         The time is :
        while(1)
                FlagStatus Status;
                Status = SysTick_GetFlagStatus(SysTick_FLAG_COUNT);
                RxData = USART_ReceiveData(USART1);
                if(RxData!=0)
                                if(Status == RESET)
                        else
                                if(sec==60)
                                        sec=0;
                                        min++;
                                sec++;
                                printf("         %d:%d",min,sec);
                                printf("         %d",RxData);
* Function Name  : Delay_Ms
* Description    : delay 1 ms.
* Input          : dly (ms)
* Output         : None
* Return         : None
        u16 i,j;
        for(i=0;i<dly;i++)
                for(j=1000;j>0;j--);
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
        //----------使用外部RC晶振-----------
        RCC_DeInit();                        //初始化为缺省值
        RCC_HSEConfig(RCC_HSE_ON);        //使能外部的高速时钟
        while(RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET);        //等待外部高速时钟使能就绪
        FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);        //Enable Prefetch Buffer
        FLASH_SetLatency(FLASH_Latency_2);                //Flash 2 wait state
        RCC_HCLKConfig(RCC_SYSCLK_Div1);                //HCLK = SYSCLK
        RCC_PCLK2Config(RCC_HCLK_Div1);                        //PCLK2 =  HCLK
        RCC_PCLK1Config(RCC_HCLK_Div2);                        //PCLK1 = HCLK/2
        RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);        //PLLCLK = 8MHZ * 9 =72MHZ
        RCC_PLLCmd(ENABLE);                        //Enable PLLCLK
        while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);        //Wait till PLLCLK is ready
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);        //Select PLL as system clock
        while(RCC_GetSYSCLKSource()!=0x08);                //Wait till PLL is used as system clock source
        //---------打开相应外设时钟--------------------
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO,ENABLE);        //使能APB2外设的GPIOA的时钟
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
* Function Name  : GPIO_Configuration
* Description    : 初始化GPIO外设
* Input          : None
* Output         : None
* Return         : None
        GPIO_InitTypeDef        GPIO_InitStructure;                //声明一个结构体变量
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;         //选择PC.10(TXD) 和 PC.11
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;         //管脚频率为50MHZ
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;         //输出模式为复用推挽输出
        GPIO_Init(GPIOA,&GPIO_InitStructure);                                 //初始化GPIOC寄存器
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;         //选择PC.10(TXD) 和 PC.11(RXD)         //管脚频率为50MHZ
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;         //输出模式为浮空输入
        GPIO_Init(GPIOA,&GPIO_InitStructure);                                 //初始化GPIOA寄存器
        //将USART3的TXD和RXD重映射到PC10和pc11
        //GPIO_PinRemapConfig(GPIO_PartialRemap_USART3,ENABLE);
        USART_InitTypeDef  U3;
        U3.USART_BaudRate =9600;
        U3.USART_WordLength = USART_WordLength_8b;
        U3.USART_StopBits = USART_StopBits_1;
        U3.USART_Parity = USART_Parity_No;
        U3.USART_Mode = USART_Mode_Rx|USART_Mode_Tx;
        U3.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_Init(USART1, &U3);
        USART_Cmd(USART1,ENABLE);
* Function Name  : SYSTICK_Configuration
* Description    : 初始化SYSTICK系统定时器
* Input          : None
* Output         : None
* Return         : None
        SysTick_CounterCmd(SysTick_Counter_Disable);
        SysTick_ITConfig(DISABLE);
        SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_DiARM);
        SysTick_SetReload(9000*1000);
        SysTick_CounterCmd(SysTick_Counter_Enable);
* Function Name  : fputc
* Description    : 重定向这个C库(stdio)printf函数  文件流——》串口USART1
* Input          : ch,*f
* Output         : None
* Return         : None
int fputc(int ch,FILE *f)
        //ch送给USART1
        USART_SendData(USART1, ch);
        //等待发送完毕
        while(USART_GetFlagStatus(USART1, USART_FLAG_TC)==RESET) ;
        //返回ch
        return(ch);
