pwm波的输出电压总是高一倍怎么回事啊,是不是我的程序写错了
480|0
 楼主| 白闻不如怡见 发表于 2018-6-30 10:24 | 显示全部楼层 |阅读模式
pwm波的输出电压总是高一倍怎么回事啊,我自己写了一下pwm的程序,但是测量时电压总是不对,我设置100的占空比理应输出0.32v但是实际数出0.63v其他的也是一样大一倍,下面是我写的程序static void TIM5_GPIO_Config(void)
  /* TIM3 clock enable */
  //PCLK1¾­¹ý2±¶Æµºó×÷ΪTIM2µÄʱÖÓÔ´µÈÓÚ72MHz
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5, ENABLE);
  /* GPIOA and GPIOB clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);
  /*GPIOA Configuration: TIM2 channel 1 AND 2 and  3 and 4 as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin =   GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;        // ¸´ÓÃÍÆÍìÊä³ö
  GPIO_Init(GPIOA, &GPIO_InitStructure);
static void TIM5_Mode_Config(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 999;       //µ±¶¨Ê±Æ÷´Ó0¼ÆÊýµ½999£¬¼´Îª1000´Î£¬ÎªÒ»¸ö¶¨Ê±ÖÜÆÚ
  TIM_TimeBaseStructure.TIM_Prescaler = 0;      //ÉèÖÃÔ¤·ÖƵ£º²»Ô¤·ÖƵ£¬¼´Îª72MHz
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1 ;  //ÉèÖÃʱÖÓ·ÖÆµÏµÊý£º²»·ÖƵ
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //ÏòÉϼÆÊýģʽ
  TIM_TimeBaseInit(TIM5, &TIM_TimeBaseStructure);
void TIM5_Mode1_Config(u16 CCR1_Val)
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  TIM5_Mode_Config();
  /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;      //ÅäÖÃΪPWMģʽ1
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = CCR1_Val;     //ÉèÖÃÌø±äÖµ£¬µ±¼ÆÊýÆ÷¼ÆÊýµ½Õâ¸öֵʱ£¬µçƽ·¢ÉúÌø±ä
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;  //µ±¶¨Ê±Æ÷¼ÆÊýֵСÓÚCCR1_ValʱΪ¸ßµçƽ
  TIM_OC1Init(TIM5, &TIM_OCInitStructure);    //ʹÄÜͨµÀ2
  TIM_OC1PreloadConfig(TIM5, TIM_OCPreload_Enable);
   TIM_ARRPreloadConfig(TIM5, ENABLE);       // ʹÄÜTIM3ÖØÔØ¼Ä´æÆ÷ARR
    /* TIM3 enable counter */
  TIM_Cmd(TIM5, ENABLE);                   //ʹÄܶ¨Ê±Æ÷3
void TIM5_Mode2_Config(u16 CCR2_Val)
  TIM5_Mode_Config();
  /* PWM1 Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_Pulse = CCR2_Val;    //ÉèÖÃͨµÀ2µÄµçÆ½Ìø±äÖµ£¬Êä³öÁíÍâÒ»¸öÕ¼¿Õ±ÈµÄPWM
  TIM_OC2Init(TIM5, &TIM_OCInitStructure);    //ʹÄÜͨµÀ2
  TIM_OC2PreloadConfig(TIM5, TIM_OCPreload_Enable);
void TIM5_Mode3_Config(u16 CCR3_Val)
  TIM5_Mode_Config();
  /* PWM1 Mode configuration: Channel3 */
  TIM_OCInitStructure.TIM_Pulse = CCR3_Val;  //ÉèÖÃͨµÀ3µÄµçÆ½Ìø±äÖµ£¬Êä³öÁíÍâÒ»¸öÕ¼¿Õ±ÈµÄPWM
  TIM_OC3Init(TIM5, &TIM_OCInitStructure);   //ʹÄÜͨµÀ3
  TIM_OC3PreloadConfig(TIM5, TIM_OCPreload_Enable);
void TIM5_Mode4_Config(u16 CCR4_Val)
  TIM5_Mode_Config();
  /* PWM1 Mode configuration: Channel4 */
  TIM_OCInitStructure.TIM_Pulse = CCR4_Val;  //ÉèÖÃͨµÀ4µÄµçÆ½Ìø±äÖµ£¬Êä³öÁíÍâÒ»¸öÕ¼¿Õ±ÈµÄPWM
  TIM_OC4Init(TIM5, &TIM_OCInitStructure);  //ʹÄÜͨµÀ4
  TIM_OC4PreloadConfig(TIM5, TIM_OCPreload_Enable);
